My new 550 wheels to fit my 308 project. | FerrariChat
Discussion in '308/328' started by Pizzaman Chris, Apr 12, 2007.
  1. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    #1 Pizzaman Chris, Apr 12, 2007
    Hi boys,
    Well, after a couple of months doing some research on 18" wheels on 308s, reading threads/posts and checking the different pictures of Chris Morses 308 with 360 wheels and Mark E with 550 wheels, i decided to get myself some nice 550 wheels.
    The wheels just got delivered today and do they look SWEEET!
    2nd picture Mark E
    3rd picture Chris M
    They look awesome guys. Hope you don't mine me posting them.:)
    Now the fun begins.:D
  2. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,138
    E ' ' '/ F
    Snike Fingersmith
    Kewl
    Magnesium or Aluminum?
  3. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Aluminum.
    After you told me of the recall i made sure.
    Thanks for that info in the other thread.:)
  4. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    Sweet momma! These look cool!
    What rims did you have on before? And what do the 18 inches do for handling?
    I was thinking of swapping my 15 inch rims for 16 inches. Might go one size up now....
    Hans
  5. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Thanks Hans.
    I have the 390mm wheels too.
    On the handling the guys that installed 360 wheels say it had greatly improved the ride.
  6. Matt308
    Matt308 Formula Junior
    Feb 16, 2004
    487
    CO
    Matt
    Very cool, Chris! Now, you have to get some photos up here when you finish with all these little projects you have going.
  7. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Chris,
    What tires are you going to install. The wheels really look like they are in excellent condition. Do you have to install spacers on the front or rear??
    best,
    chris
  8. exproject
    exproject Karting
    Sep 9, 2006
    106
    Denton, TX
    Cameron R.
    Got 360 wheels on my Mondi, love em. Plus it makes the car look so much better.
  9. thecarreaper
    thecarreaper F1 World Champ
    18,071
    Savannah
    this is a great, tasteful mod. i just wonder if it would be a good idea to first go thru the bushings and ball joints on an older car before doing this as the loading on the control arms must be very different with these wheels.
    they look great. post more pics asap!
  10. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    very well done.
    can't wait to see the final photos!!
    best
    rt
  11. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    I was thinking of going with the Goodyear F1 GS-D3.
    I still have to do some homework on size. Maybe Fronts 225/40/18 and Back 265/35/18??
    I had called Daniel at Ricambi and he said the fronts i needed 20mm spacers and 80mm bolts and the back, after i narrow them down to 9.5, he said standard 360 52mm bolts will do with no spacers.
  12. Glen_Lloyd
    Glen_Lloyd Formula Junior
    Dec 13, 2003
    785
    Lloydminster AB
    Glen
    Is the offset on the 550 wheels the same as 360 wheels? If it is the 9.5" width without suspension work might rub, mine at 8.5" is very tight. If the offset is towards the outside; the tire and wheel may extend outside the fender, this is what happens with 360 wheels on convex wheeled 328's. Measure carefully.
    Good Luck
    http://ferrarichat.com/forum/showthread.php?t=143166
  13. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Yep, i was going to do my bushings and ball joints, but that's the fall/winter project. :)
    And yes, there will be more pictures.
  14. regisgtb4
    regisgtb4 Formula Junior
    463
    tx
    willis
    I had a chance to weigh a 355 front wheel and a 16 X 8 factory mag and the 355 went 18.2 lbs while the 308 mag16x8 went 12lbs. If you ever drove early cars with wires and then swapped to the mags you notice that the wires are slower to rev up and the wires let you keep momentum when you back off the gas making for decreased braking power.No way would I put on more rotational weight. I ditched the 390trx junk and goy a set of factory 16s and run mich pilotsmmx 225f -255r which is OE for TR, lot of grip,perfect fit.
  15. thecarreaper
    18,071
    Savannah
    cool ! :)
  16. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Thanks Glen.:)
    Those 360 wheels look great on your 328.
  17. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    #17 Pizzaman Chris, Apr 13, 2007
  18. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Man, look at those girlie brakes! ;) Imagine what is next..... :D
  19. chrismorse
    Feb 16, 2004
    2,150
    chris morse
    #19 chrismorse, Apr 14, 2007
    Here is one option, (It is not on the ground yet ~85% complete).
    Those 355 wheels look good. Keep posting pics of the project.
    best,
    chris
  20. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Hey buddy,
    Welcome back.:)
    Are you back??
  21. Matt308
    Feb 16, 2004
    487
    CO
    Matt
    #21 Matt308, Apr 14, 2007
    Hey Chris, about what we talked about before...
    Bolts are 70mm with 45mm thread, so may be too short for what you need. Spacers are 20mm, but have a 76mm wide by 10mm tall lip that fits into the wheel - again, may not work for what you need. I suppose you could cut off the lip, but would probably not be worth the effort. Let me know. -matt
  22. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Hi Matt,
    Thanks for the pictures.:)
    Yeah, i wont be able to use them.:(
    Thanks again,
    Chris
  23. Matt308
    Feb 16, 2004
    487
    CO
    Matt
    OK, back to the shed they go...
    Take it easy, m
  24. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Oh sooo sweet!!
    Chris, i...........hold on a second while i wipe the drool off.......... i can't wait to read about your "Big Brake Project":)
  25. chrismorse
    Feb 16, 2004
    2,150
    chris morse
    #25 chrismorse, Apr 14, 2007
    I was writing it up when i took a brake to check, "what's up".
    Just sent the e brake brackets and front wheel adaptors to girodisc for anodizing, yesterday.
    To emulate one of my heros, birdman, here is a "teaser" of a new product: 360 to 308 parking brake adaptor- Material 6061 T-6. This was done on a cnc machine, so if your specs differ a little bit, changes are easy.
    "Help is on the way" :)
    sorry, couldn't resist a small beer induced moment of joy.
    hth,
    chris
