Pic of my 308 motor with the latest goodies! | FerrariChat
Discussion in '308/328' started by luckydynes, Jun 1, 2007.
  1. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    #1 luckydynes, Jun 1, 2007
  2. James in Denver
    James in Denver Formula 3
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
    Holy crap thats cool! Thats a great looking engine.
    James in Denver
  3. TGF
    TGF Formula Junior
    May 1, 2007
    319
    North Central, MA
    Tom
    I agree, it's neat. It looks nothing like my relatively stock set-up.
  4. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Thanks . . . it's been an itterative process over the past year.
    Sean
  5. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    That's one simplified engine bay -- NICE!
    How about a pic or two from further back so we can see more?
  6. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    #6 luckydynes, Jun 1, 2007
    How's this?
  7. Mr. Nice Guy
    Mr. Nice Guy Formula Junior
    Apr 11, 2007
    301
    Southern NH
    Eric
    WOW! Very nice!
  8. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,851
    Atlanta
    John!
    Ok how did you get that to work. What brain module did you use to fire the coils, and where are you getting power for wach one of those coils? I am very curious cause I thought about doing the same thing. To me, it looks much cleaner than the electromotive set-up and will operate jsut as well.
  9. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Thank you, thank you.
    Fchat has been a great resource and motivator for me . . . gearheads are a dieing breed.
    Sean
  10. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,140
    E ' ' '/ F
    Snike Fingersmith
    Ok, I gotta ask -- what's the function of the hose to the oil filler opening?
  11. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    I'm using a Haltech E6x ECU for the brain. It controls the fuel injection also. When I first installed the ECU I still had the stock fuel injection on it. I copied the timing curve from the manual for the euro car and mistakingly ended up with 42 deg full advance (stock compression, etc.). It really livened up the stock motor though since it had such low compression. That was with the stock dizzy's and stock Ferrari triggers also. When I started using the Haltech triggers with the dizzy's it smoothed up the idle . . . I don't think the signal from the stock triggers was "clean" but there are some filters I could of played with if I wanted. Keep this in mind though . . . can't use the stock triggers with direct fire ignition. I made an adapter that fit in the harmonic balancer that holds the magnets the Haltech reccomends for triggers . . .. you can also do the E-motive set up with the missing tooth, etc. The stock triggers will only work if you continue to use dizzy's because of the number of pulses generated per rev is only enough for dizzy's - not direct fire.
    This motor is higher compression and for some reason the COP's and MSD ignition unit reduced pinging and allowed me to advance the timing back to 36-38 degrees like the factory euro cars had . . . was only able to run 28 degress full advance with dizzy's and high comp motor before doing the direct fire but this could of been bad plug wire creating electronic noise or? One of the plug extenders had a burn in the side so it could of been creating noise also.
    Sean
  12. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    I was just trying to get more crankcase ventilation . . . there's a little K&N filter on the end of it. The rear main leaked when I first built this motor which made me think the crankcase was not venting enough at high rpm. I added a PCV system also but eventually the rear main stopped leaking I think once the rings seated. Not sure if it's doing any good any more. Doing a little research it seemed a good thing to be pulling blow by gas out of the block . . . pulling a vacum with a dry sump system is the ultimate which is why I also started working on that.
    Sean
  13. GrigioGuy
    Nov 26, 2001
    33,140
    E ' ' '/ F
    Snike Fingersmith
    Thanks. I kinda figured it was something like that, but didn't want to assume on a heavily modified engine.
    Clean install, looks great!
  14. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    #14 luckydynes, Jun 1, 2007
    Thanks . . . here's a pic of my nitrous injection plate that's going on next.
    Sean
  15. Corsa308
    Corsa308 Formula Junior
    Apr 22, 2007
    290
    Sydney, Australia
    Steve D
    Have you done anything to the water pump and piping etc? or does it look different because there is no air feed going over the top of it and now we are just seeing what is usually hidden?
  16. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Nope, that's what lies beneath.
  17. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Check-frickin-plus.
    That is one outstandingly well done engine bay.
    Very well done and you are an inspiration yourself!
    Any dyno numbers on that work of art?
    Great job!
  18. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Why thank you.
    I have g-force acceleration numbers from my data acquisition system. I backed out some hp numbers based on weight, etc. Someone else run the numbers (stock weight roughly) . . . wasn't what I was hoping for but that's why I'm playing with nitrous . . . never enough until you get the two black lines from one corner to the other. Flat line pull is around .62 g's which I don't think is that impressive hp wise. If I'm malicous with the clutch or lurch it from decel to full throttle I'll get .7 g's but she's running so good right now that I'm trying to be a little gentle.
    You want some screen shots from my data acq system? Shows air/fuel ratio, etc. and you guys might have some tuning advice, etc.
    Sean
    edit: I weight "roughly" 200 lbs and give me the benefit of the doubt and a full tank of gas if you're running hp numbers . . . hot day also
  19. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    It sounds pretty darn good to me and would not neccesarily take those g-numbers to the bank on hp - a $100 dyno run with A/F and rwhp would tell a much more accurate tale.
    I would love to see the A/F vs rpm plots and ignition advance if you have them.
    Many thanks
    rt
  20. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    I'll pull that data acq stuff off my other lap top. I posted my ignition advance curves a long time ago in an excel spread sheet. I had the vacum reversed at that time . . . that'll make sense if you look at it. I'll do a screen shot of the actual 3d map I'm running also. I don't think there's an official file ouput . . . ther laptop also.
    Happy to return some inspiration!
    Sean
  21. 350HPMondial
    350HPMondial F1 Veteran
    5,325
    Edwardo
    Sean,
    Wow, best ever NA engine!
    I used to run a Haltec E6 (old).. I would be interested in obtaining a copy of your map.
    I will eventually add port injection to my 1981 Euro Mondial 8.
    Edwardo
  22. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Thanks. Different cams in my engine also . . . not sure how useful the map would be unless you built your engine similar to mine. I want to try and simplify/automate the mapping process using my wideband O2 and data logging in closed loop operation. It's way off in some places but it's pretty good at WOT which is where it matters most.
    FYI I made extras of all the fuel injector adapters/holders which do not require any permanents mod's to the intake.
    I data logged a pretty good launch this morning and will post a screen shot later.
    Thanks again,
    Sean
  23. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    #23 luckydynes, Jun 2, 2007
  24. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    #24 luckydynes, Jun 2, 2007
  25. kris308
    kris308 Rookie
    May 31, 2007
    49
    wow!! that is beautiful. I am presently all stock, but you're making me jealous!!!!
