16" Dino Wheels Cromodora Design from Superformance | Page 4 | FerrariChat
Discussion in '206/246' started by Dino Club Germany, May 16, 2011.
  1. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,882
    Southern California
    UroTrash likes this.
  2. Edward 96GTS
    Edward 96GTS F1 World Champ
    11,162
    better angle. looks good. (laguna hills?)
  3. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,882
    Southern California
    You can see my front camber is positive. My rear camber is negative. It drives well as-is but I’d like to explore a bit of negative camber on the front. Anyone have any experience with that?
  4. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,882
    Southern California
    UroTrash, Nuvolari and 375+ like this.
  5. Longstone Tyres
    Longstone Tyres Formula 3
    Sponsor
    Feb 2, 2006
    2,067
    Dougal
    thoswe tyres should have more adverse camber than a XWX
  6. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,882
    Southern California
    Thank you Dougal. What’s the max negative camber do you think?
  7. Longstone Tyres
    Sponsor
    Feb 2, 2006
    2,067
    Dougal
    Hmm.I wouldn't have a clue. I'm not that clever, but more than the XWX
  8. swift53
    swift53 F1 Veteran
    8,619
    E.S.
    Alberto
    Neg. Camber up front is always great...
    Also, just add 1 mm of toe-out up front :)
    Really, the best is go to a professional.
    Regards, Alberto
  9. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,882
    Southern California
    I always use pros when it comes to alignment etc. I have one of the best that will do it. I’ve been researching 308 numbers with the same size P7’s. 308’s got the same size P7’s with 16” wheels as an option in ‘77 and 308’s are similar in wheelbase and basic suspension. Anyone who knows different, please chime in! Factory 308 specs showed negative camber after the 14” XWX’s due to a stiffer sidewall.
    I’m really excited with this!
    Nuvolari, Michael Call and swift53 like this.
  10. Longstone Tyres
    Sponsor
    Feb 2, 2006
    2,067
    Dougal
    Correct me if im wrong, but after the XWX they added more negative camber because the foot print was wider and the carcass had sharper shoulders to it. look at this picture demonstrating the massive difference in shape of the tyre. So even though the 205/55R16 is in theory the same width as the 205/70VR14 XWX, the XWX will have a thinner amount of rubber in contact with the road, However as the car leans ion the corners and rolls round the the rounded shoulder of the carcass it will keep more rubber in contact with the road than a wider squarer shoulder tyre, because it suddenly lifts a large portion of its tyre off the road.
    Unless, like you say, you add adverse camber to keep that footprint on the road as the car leans under cornering forces. (Also stiffen the springs.)
    It isn't just this width of tyre that creats this Phenomena
    the difference with modern cars and their clever geometry and suspension etc is they cleverly keep all of the footprint on the road like this.
    You can add adverse camber, but do beware you don't find yourself in that position we often come accross with modern cars where they have no idea they have shredded the inside edge of the tyre because 3/4 of the tyre is fine, it is just the inboard shoulder of the tyre that wears.
    Jack-the-lad and Ribolla_67 like this.
  11. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,882
    Southern California
    Dougal, first off, I love your sketch diagrams!! Second, thank you for your wisdom!!
  12. swift53
    swift53 F1 Veteran
    8,619
    E.S.
    Alberto
    375+ and Longstone Tyres like this.
  13. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,882
    Southern California
    All great info! Thanks!
    swift53 likes this.
  14. Longstone Tyres
    Sponsor
    Feb 2, 2006
    2,067
    Dougal
    Oo! i like those Alfas.
    swift53 likes this.
  15. HMB-Dino
    HMB-Dino Formula 3
    2,353
    Pebble Beach, CA
    RonG
    You mean those technical drawings aren't from Michelin?
  16. swift53
    swift53 F1 Veteran
    8,619
    E.S.
    Alberto
    Please note the Marlboro sponsorship :)
  17. tx246
    tx246 F1 Veteran
    6,705
    Texas
    Shawn
    How much interest is there in another run of 16” wheels for a Dino?
  18. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,882
    Southern California
    I think having the option of a correct looking 16” wheel allows you to use it for driving and tours and reserve your 14” wheels for concours. Lots of 16” tire choices. I wish there was also a 16” Campy option!
    View attachment 3768678 View attachment 3768679
    375+ and swift53 like this.
  19. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,882
    Southern California
  20. racerboy9
    racerboy9 F1 Rookie
    2,689
    I wish they made them in 15" with a suitable low-profile tire. The Stratos road car used the same size tire and rim as the Dino but when I put on the "15 Speedlines with Michelin TB5's it was much more sure footed and the speedo read about the same. The 16 inch wheels look a little out of scale on the Dino to me.
  21. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,882
    Southern California
    I like the idea of a 15” wheel. There are a number of 205/65-15 tires out there that are similar in height to a 205/70-14 https://tiresize.com/tiresizes/205-65R15.htm. There is also an XWX in 185/70-15 that is the same diameter.
    swift53 likes this.
  22. Longstone Tyres
    Sponsor
    Feb 2, 2006
    2,067
    Dougal
    Why do you want to do that?
  23. swift53
    swift53 F1 Veteran
    8,619
    E.S.
    Alberto
    Because this is Dinoland.....
  24. swift53
    swift53 F1 Veteran
    8,619
    E.S.
    Alberto
  25. Edward 96GTS
    11,162
