3.2 liter high compression pistons | FerrariChat
Discussion in '308/328' started by snj5, Aug 11, 2007.
  1. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #1 snj5, Aug 11, 2007
    while somewhat of a cross-post, here are what the JE 10.5:1 and stock US 9.2:1 static compression ratio pistons look like. There were off an existing Norwood pattern and designed after the combustion chamber was cc'd. This car has a requirement to run on street premium, so it was felt about 10.5:1 was about as high to go with some safety margin with the ported heads. I've never done this before, but I understand that raising the compression ratio really makes a noticible difference in seat of the pants driving. We'll also probably start tuning at a reduced advance of 30 degrees btdc and slowly advance for safety regarding detonation.
  2. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
  3. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Russ,
    Superchargers, Modified Heads, High Compression Pistons ?? When will it end!!;)
    You guys are killing me! LOL!
  4. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Chris
    supercharge? not me - it's like dynanite fishing.
  5. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Russ,
    With all these different mods out there for our Fcars, i'm going to be in the poor house soon. LOL
    I have to start limiting myself to this site soon.:)
  6. rtking
    rtking Formula Junior
    Mar 5, 2006
    703
    Huntington Beach, CA
    Bob King
    Gotta love those forged pistons! I'm excited to see the horsepower and throttle response changes. Going from 9.2:1 to 10.5:1 pistons is really going to sharpen your throttle response. I'm going to guess that your 1 point increase in compression 9actually 1.3 points) is going to net about 10% increase in power, all other things being equal.
    Keep us posted!
    Bob
  7. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    Yes, when will it end????
    Hopefully never :)
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,807
    The twilight zone
    They're pretty, but you're going the wrong way with the compression man....tha't will really limit the amount of boost you can run. I think I'm going to drop to 8:1 and try to get the boost north of 20 :)
  9. james patterson
    james patterson Formula Junior
    Dec 8, 2003
    417
    Dallas Texas
    James Patterson
    Mark- You have Motec and 4 valve heads, don't drop the compression. With the right maps and good air temps you should be able to run 9.0-9.5 at 18psi on good 93 with the right parts in the motor. If you go to a 93/106 mix or a straight 106+ go to 27 and make some big numbers. Even with your blower set up the drop in compression will lose area under the curve till she is flowing some air.
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,807
    The twilight zone
    James,
    With the stock pistons (factory claims 8.6) and 93 octane pump gas I was running 18 psi at 7000rpm that climbed to about 22 psi and it did seem fine. I think with the heads flowing better now the peak hp will be at about 7700-8000 so I shouldn't have to deal with the boost rising at the end so I could turn up the blower and get 22 across the board....at least in theory....
    Anyway, I had it in my head that if 8.6 worked at 22 psi, then dropping down to about 8:1 would let me push the boost to 24-28 psi on 93 and make about 750 hp. The second part of the thought was to open up the LSA to 112-114 and possibly take a little duration or the cams (the heads flow so well now, particularly at low lift that thing the stock duration may make peak hp around 8200 on my little 3.0 liter....and I'm not sure I want to run that high) and I should be able to maintain low rpm cylinder pressure at the expense of a bit of peak hp, which could be made up with boost...again at least in theory.
    I'd sure like more compression if I can get away with it....I'm just starting to get a bit scared. I'm not ready to order the pistons just yet.....still working on the patio from h*ll that is eating more than all my money, but I will most likely call you when I am ready.....I would like more compression.....
  11. GTHill
    GTHill F1 World Champ
    Jul 1, 2006
    14,054
    Double Wide
    GT Hill
    It is hard for me to deny the power from forced induction, but I still prefer going natural...
    So, how much is a guy looking at spending to get this done? I'm about 6 months from engine out so that would be the time.
    Gene
  12. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Everything is a bit variable with regard to how much I did and labor costs, so it is difficult to nail down exact labor price. Partswise, the pistons I believe were $1349.81 and wrist pins $112.38. I think one of the best bets would be to get the heads done, which is about $2 - 4K depending plus assembly.
    Here is an interesting reponse from the other board from Chris Fricke on increasing compression:
    I am hoping for Chris' "much more lively" feeling engine with most of the improvement below 7K in throttle response and torque rather than chasing an ultimate peak number (although I plan to whoop up on Mark's NA number handily :) )
  13. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,459
    Dumpster Fire #31
    SMG
    Looking good Russ! I'll be starting soon on another run of adjustable pullies, keep you posted.
    although I have a 2V I have 9.5:1 forged pistons and 20psi of boost. timing is peaked at about 40*. at the end of the yr I'm gonna switch over to full EFI for more fun. the one thing with the forged pistons is the rattle when cold.
  14. atlantaman
    atlantaman Formula 3
    Mar 31, 2002
    1,726
    Roswell, Georgia
    Charles
    Russ, I have been planning on going to 10.5 on my 328 but was not "warm n fuzzy" on my conversations with Wiseco. Can you send me infor on your pistons, part# and a contact name.... I am assuming that other than the porting , all else is stock on the 328 motor....
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,807
    The twilight zone
    Russ, when you say silly things like that, all your credibility goes right out the window....whoop on my NA number....man I need some of what you've been smokin ;)
    (Now I'm almost forced to listen to James and get the 9.5 pistons....and a 360 crank....and I don't know what all else but I just can't have you whoopin on me :) )
  16. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,807
    The twilight zone
    Isn't that blasphemy???? Welcome to the dark side :)
  17. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    I am running borgo ho comp pistons in my 308 euro carby - great overall torque....
  18. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    James Patterson (see his response below) at Norwood's (FChat sponsor) has an existing design at JE and I got them through him. The engine bottom end is stock. I'd give him a call if interested.
    What did Wiesco say that was not warm and fuzzy? That is interesting: JE and Wiesco are owned by the same folks I am told.
  19. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Very cool (although my teenage daughter has informed me people do not say that things are 'cool' anymore). Do you recall the compression ratioo? Any other comments with regard to power curve and/or pinging/detonation? Everyone that I have spoken to says they make a very noticible difference.
    Many thanks
  20. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    You are soooooo very predictable.... :)
    Russ 'if someone has a button, I'm gonna press it' Turner
  21. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,807
    The twilight zone
    Vic (the guy doing Russ's and my heads) tells me he never uses Wisco if he has a choice. It's not that there is anything wrong with the pistons, it's that they screw-up the dome cc every time. It looks like they calculate the correct dome, but then cut .060 or something like that off the OD of the dome...so they end up about .5 point lower than you asked for....unless you re-work the head to make up for it or know to order .5 point more than you really want knowing they will be wrong when you get them. Strange.
    The JE pistons on the other hand will be exactly what you asked for....which is why they are so popular with the top shops I guess. The JE pistons are also always about as light as they can be, there really is no extra metal if you change you mind on compression or valve pocket depth…they are as light as they can be. Other brands I've used have come with domes well over 1/2" thick because they only have 1 or 2 forgings, so flat top or 1/2 dome is the same part, it's just how much they cut off the top when they finish it (I don’t know if wisco falls into this group, the couple sets I’ve seem looked pretty good).
  22. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,807
    The twilight zone
    Oh I'm just funnin you.....I'm building a blower motor, so your flow restrictors....I mean webers are my only hope of beat you in the NA number :)
  23. atlantaman
    Mar 31, 2002
    1,726
    Roswell, Georgia
    Charles
    A) they could not look up pistons from an engine type---all custom pistons are simply given a code. Even with a name of someone that had purchased 10.3 328 pistons from them, no joy...
    2) their piston is simply a flat top from what i saw from others, It would appear that you rJE was atleast given a little effort on the design.
  24. 350HPMondial
    350HPMondial F1 Veteran
    5,336
    Edwardo
    WISECO 308 pistons... $1,080.oo USA
    JE 308 Pistons... $ 1,392.oo USA
    I believe that warm and fuzzy feeling is to be had from Wiseco, , , for $ 300.00 bones
  25. atlantaman
    Mar 31, 2002
    1,726
    Roswell, Georgia
    Charles
    interesting---a side note though---Wiseco also seemed to be very familiar with the 308 but could not find anything on the 328----
    I would be happy to go with Wiseco IF they can get me what I need.. Hey and I also need 12 new 10.0 pistons for my 330 motor too...........
    all help is appreciated
