What to use to lubricate 308/328 seat rails? | FerrariChat
Discussion in 'Technical Q&A' started by Mike328, Aug 12, 2007.
  1. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    Hi folks,
    I've got my 328's seats out for their annual Leatherique treatment.
    This year I wanted to clean lubricate the seat rails so they slide forward and backward a little more smoothly. What should I use here as a lubricant? I think something more substantial (grease? what kind?) beyond WD-40 would be appropriate...
    Any help appreciated!
    --Mike
  2. Glassman
    Glassman F1 World Champ
    I used white lithium grease applied with a small paint brush.
  3. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    White Lithium Grease,
    It's plastics friendly, cleans up pretty easily, & lubricates adequately for this type of job.
  4. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    Thanks, guys! I have some "in stock" here in the garage and will use that. Very much appreciate the input.
    --Mike
  5. Stew
    Stew Formula Junior
    Apr 16, 2006
    547
    Los Angeles
    Mike,
    I,ve been down this road a couple of times. Make sure you take the time to completely clean out the old dirt and gunk in the rails before you lubricate and re-install. It's actually easier to take the time to remove the rails from the seats and then clean them. The results will amaze you !
    Regards,
    Stew
  6. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    Thanks for the encouragement. I WANT to take the rails completey off of the seats. However, each rail has 2 6mm allen (inverse hex-head) bolts that I absolutely, positively CANNOT crack, even after using various nut loosener sprays and light tapping on a hammer. I considered slotting them with a dremel tool, but have not done so....
    Has anyone else had any trouble here? I'd really like to do as Stew suggests and completely remove them and take the time to de-gunk them.
    --Mike
  7. robbie
    robbie F1 Rookie
    Aug 26, 2005
    3,015
    Los Gatos, CA
    Robert
    When playing with the rails be careful. there are two rollers with rubber o-rings on them and they can fall out. Also, there are some small ball bearings that have to be in specific locations or the seat will jam. The rails have little indentations that keep the balls in the right place but sometimes the balls can get past them. Patience is a virtue.
  8. mike
    mike Formula Junior
    Nov 2, 2003
    721
    Colorado
    I'd just like to know how to get the seats out. I have tried the allen screws in the front of the seat/floor area but get lost as I proceed anound to the tunnel side & aft portion. Anyone post a link?
  9. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    It's simple. Each seat has four 6mm allen bolts bolted into the floor. The allen bolts I'm talking about above are two separate ones that attach the rails to the actual seat, you can ignore those.
    You must move the seat ALL THE WAY FORWARD firmly and pull the reclining latch to lean the seat forward in order to reach the rear bolts. Same applies to the front bolts. A typical "90 degree elbow" allen key will give you enough clearance to get to the bolts.
    --Mike
  10. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    the reason the rear screws are so much trouble is they're exposed to the elements and rust up very easy. keep after them with penetrating oil. if you feel under the car you may be able to access the end of the screw. i use a 6mm allen head socket for removal. when reinstalling them i coat the screws with silicone sealer and lube the track with white lithium grease. perserevance furthers.
  11. wolftalk
    wolftalk Formula Junior
    Jan 27, 2004
    367
    san franciso area
    phil
    on the 328, if you take out the front bolts first, a stop bracket comes out with one of them and you can slide the seat further forward. Makes getting to the back ones with a hex socket and extension pretty easy.
    on the 308, the stop is welded to the seat rail, so no help there. However, it is usually easier to take out the fronts first so the back of the seat doesn't try and lift when you slide the seat forward.
    wrt getting the rails off the 328 seats, yeah, those allen bolts were on tight. Hex socket worked for me, though.
  12. mike
    mike Formula Junior
    Nov 2, 2003
    721
    Colorado
    Thanks everyone..I'll pursue this again on my 328..slowly following these directions..
