166MM / 250mm gearbox Ebay | FerrariChat
Discussion in 'Vintage Ferrari Market' started by tomgt, Nov 26, 2008.
  1. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
    #2 Marcel Massini, Nov 26, 2008
    Guys:
    Before ANYBODY starts bidding on this item I HIGHLY recommend to check the description VERY CAREFULLY and especially the origins where this item comes from. Then start your research. You can also contact me by PM.
    Another key word is the STOLEN 166 MM/53 Spider Vignale #0314 M (28 May 2000 stolen in Brescia, just after the Mille Miglia) that was found in an Italian warehouse in December 2007, in bits and pieces and totally dismantled with 70 percent of the items still missing today.
    DO YOUR HOMEWORK!!!
    Marcel Massini
  2. tomgt
    tomgt F1 Veteran
    7,167
    Netherlands
    Tom Wiggers
    IF stolen than one can check the numbers on the gearbox and compare with 0314m.......
  3. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
    #4 Marcel Massini, Nov 26, 2008
    What do you think I am doing?????
    Since 8 years I am personally involved in this particular case and work with and for the insurance company.
    This is a BIG thing.
    Marcel Massini
  4. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    It is somewhat strange that a seller of an item as unique as this would not list the serial number in the item description.
    I also note the colour on the inside of the bellhousing. I may be way off the mark here, but didn't they paint the insides of the castings green? (not that the colour is terribly important)
  5. ivo73
    ivo73 F1 Rookie
    Mar 3, 2005
    3,476
    Switzerland
    Ivo Pucci
    Does you already try to contact the seller and ask for the internal number ??
    on a picture its only visible the casting number..right ?
    Ivo
  6. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    That is a sealant used to keep the oil in the gearbox.
  7. Randy Forbes
    Randy Forbes Formula Junior
    Jul 14, 2006
    741
    Sarasota, FL
    Sports Cars Plus,LLC
    Which, the green, or the red (Glyptal?)?
    Just curious, thanks.
  8. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
    Ivo
    Several people have contacted the seller and asked for the internal number and photos showing the internal number.
    No replies so far.
    Marcel Massini
  9. tomgt
    tomgt F1 Veteran
    7,167
    Netherlands
    Tom Wiggers
    Hi Ivo,
    No I just found it on Ebay and I did not know this was the gearbox of the stolen car.
    and to Marcel: don't shoot the messenger!
  10. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
    Tom
    I am not shooting you, not at all.
    And I am NOT saying that this is the gearbox from 0314 M.
    However, the chance is VERY BIG that there is the connection to 0314 M.
    That's why we all want to see a photo showing the internal number on the gearbox.
    I know what the numbers should be and have the factory documentation to prove. Besides that I have photos of these numbers before the car was stolen and therefore am in the position to compare and verify. And yes, the insurance company is also interested in this case.
    Marcel Massini
  11. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    We've used sealant that is green but there may be red sealant as well. It works very well and also prevents corrosion.
    Best
  12. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Jack Verschuur
    Jim,
    In engines and I suppose gearboxes a paint is used to promote the flow of oil back to the sump: In a bell-housing, which is the only visible internal part, there is no oil.
    Ferrari used the paint on the inside to make sure that no casting sand that might have remained behind on the surfaces of a casting could end up in the oil and do harm.
    But who am I telling....
  13. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    In a 166 Box there is oil in the Bell housing as the seals are a bit primitive. The stuff we use isn't original but it protects the castings and seems to work well. As you know I'm not a purist. I also use modern bearings/seals/gears/ and even Porsche syncro's in mine.
  14. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
    Has ANYBODY been able to obtain a reply from the seller of this gearbox and get information about the internal number stamped on this gearbox??? Best would be a clear photo showing the number stamped. Thanks for all help.
    Marcel Massini
  15. drakefan
    drakefan Rookie
    26
    Hi Marcel,
    I know this guy and where he is located ...I can ask to his friend about the serial number of the gearbox. I'll do my best for a clear photo with the number stamped on...
    Ciao, Mari
  16. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
    Well, auction has ended without any bidding.
    And the gearbox appears to be from a 212, not from a 166 MM.............misrepresented.
    Plus, the seller never provided a photo of the numbers stamped, despite 8 inquiries.
    Marcel Massini
  17. Motob
    Motob Formula 3
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
    Typical Italian eBay auction. Pretty much every item that I have bought from someone in Italy on eBay has been misrepresented.
    Would you buy a high dollar item from someone named "Black Toxin"?
  18. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
    "Black Toxin" claims to be an employee of Fulvio Visioli, Visauto, Cremona, Italy.
    N O further comment!!!
    Marcel Massini
  19. John Vardanian
    John Vardanian F1 Rookie
    Jul 1, 2004
    3,080
    San Francisco Area
    John Vardanian
    I got a set of wood handled screwdrivers from "ebay.it" represented as replica Ferrari items. They arrived. They looked identical to the real item... except 2/3 the size. I had to shake my head and laugh.
    john
  20. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
    I stopped buying thru ebay simply because 99 percent of the sellers are just plain crooks and always mis-representing the item.
    And only a fool would buy a genuine gearbox that may originate from a stolen car.
    Marcel Massini
  21. teak360
    teak360 F1 World Champ
    Nov 3, 2003
    10,065
    Boulder, CO
    Scott
    #22 teak360, Dec 3, 2008
    At least you didn't pay $500K for the replica GTO at only 1/18 the size!
  22. etceterini.com
    etceterini.com Karting
    May 26, 2008
    200
    St. Louis MO
    Cliff Reuter
    #23 etceterini.com, Dec 4, 2008
    I've bought (and sold) hundreds of things on Ebay and never had a problem. So are you saying
    that Ebay.it is the problem?
    Here is my latest purchase which you can see all of on my scca history page: http://www.ferrariexperts.com/SCCA%20results%20test%20page.htm
  23. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,446
    Will Tomkins
    Shhhhhhhh! Keep it to yourself. It's much better for us if others looking for Ferrari & other bits aren't bidding too....
  24. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,446
    Will Tomkins
    Were any 250MMs fitted with 5 speed boxes? All my literature says they're 4 speed.
