PPI Cost? | FerrariChat
PPI Cost?
Discussion in 'Vintage (thru 365 GTC4)' started by gsjohnson, May 3, 2008.
  1. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    I have been browsing 365 GTC/4s for a possible purchase and since this will be my first Ferrari purchase, I don't want to blunder. What do complete PPIs typically cost with a leak down test?
  2. Shumdit
    Shumdit Formula Junior
    May 9, 2006
    335
    Greenville, SC
    Matthew B.
    $700-900 at an auth. dealer is the range I have seen, $200-300 less at a non Ferrari authorized dealer. Could be more or less for an older Ferrari though since I am referring to late model cars.
  3. Vintage V12
    Vintage V12 Formula 3
    Aug 11, 2004
    1,451
    For a Vintage Ferrari forget about an authorized dealer. In your area I would call Norbert Hofer. The cost for a mechanical inspection may cost 800 to 1000 dollars. You may also want to have the body looked at. Trust me, it is worth it. Do not take a chance on getting a poorly maintained car. You may also want to find out who worked on it and who owned it in the past. Reciepts from a prior engine rebuild mean nothing if it was not done properly by an experienced shop. Keep in mind it cost the same to fix that car as a 15 million dollar 250gto. Take your time and don't let a pretty paint job full you. These cars are expensive to fix.
  4. Mrpbody44
    Mrpbody44 F1 Veteran
    Jul 5, 2007
    7,899
    St Augustine Florida
    Steve Metz
    About $1000 to $1200 for a car of this vintage. Older cars run about $2,000 like 212's . The car must be inspected on a lift. Do not just have some guy look at the car in the driveway.
  5. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I would agree 100%.
    The C4 is a complicated car and to do a thorough inspection is a pretty big job.
  6. jsa330
    jsa330 F1 World Champ
    10,043
    75225
    Scott
    In October '02, I paid about $200 for the PPI on my '64 330 2+2. It was good in the sense that it covered all the vital points. However, it didn't alert me to lots of $mall things...and if it had I may not have bought the car, and may not have bought a Ferrari at all. No regrets.
    Last year, I paid $500 each for two PPI's, first on a '65 330 2+2, then on my current '83 308.
    These were thorough, top to bottom, with compression/leakdown tests, full photos, etc., etc.
    Agree, high-reputation independents are the best for classic and vintage cars.
    Do your homework, then as extensive a checkover as you are personally capable of, make sure you want the car, and then don't hold back for the PPI.
  7. UroTrash
    Jan 20, 2004
    40,455
    Purgatory
    Clifford Gunboat
    I paid $400 three times on 3 different 330GTCs.
  8. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    A 330 or a 308 is a far simpler car than a 365 GTC4. A better comparison would be a Daytona but the downdraft carbs and lack of power steering make that car easier to inspect as well.
  9. Bertocchi
    Bertocchi Formula 3
    Jan 28, 2004
    2,322
    Austin, Texas
    David Castelhano
    I perform them fairly inexpensive in hopes that I land the new owner as a potential client. If I have to travel to do a PPI it is much more expensive of course. It can easily run $1000.
  10. tritone
    tritone F1 Veteran
    7,196
    On the Rock
    James
    Me too; and then I did 3 separate PPI's on the car I finally bought!
  11. Motob
    Motob Formula 3
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
    What? that is crazy! We typically spend 3 hours doing a pre-purchase inspection ($300), which includes a test drive, compression test and inspection of the car on a lift.
    Brian Brown
    Patrick Ottis Co.
  12. shaughnessy
    shaughnessy Formula 3
    1,869
    Wolfeboro NH
    Thomas E Shaughnessy
    I could not agree more, Brian. Guess we aren't charging enough huh.
    Leakdown what do you think another hour?
    make it $400 then
  13. dm_n_stuff
    Dec 10, 2003
    43,707
    26.806311,-81.755805
    Dave M.
    There you have it!
    From two of the best.
    To quote from Trading Places (loosely) "Mr. Shaughnessy has set the price. Tell our clients to buy PPIs at $400."
    DM
  14. Vintage V12
    Aug 11, 2004
    1,451
    OK I over estimated the cost of an inspection. I figured a days labor.The fact is I did not have an inspection on the car I bought 5 years ago. I first saw the "show winning" car in person as it rolled off the truck after traveling 2000 miles. It was beautiful. The yellow paint shining in the sunlight. I started it up and oil and water were not dripping out, but spraying out of the engine bay. The car ran great but just had too leaks. To make a long story short I ended up doing a restoration on the car (see 275gtb returning to life thread). I got lucky because the market has gone up so I could justify the money I had to put into the car to make it right. If this had been a 365gtc/4 I would have been in trouble. In the end I basicly had a post purchase inspection that cost me about 150K.
  15. shaughnessy
    1,869
    Wolfeboro NH
    Need to add travel and possible flat bedding costs to the facility
    Those are estimated hard core costs landed on our doorstep.
  16. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Aren't you "retired"?
    Website still says "Closed Indefinitely"
  17. shaughnessy
    1,869
    Wolfeboro NH
    To certain and most individuals
  18. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    So does anyone know of any privately owned 365 GTC/4s reasonably priced for sale? I do not want a project. Looking for a cosmetically restored driver.
  19. Fontana
    Fontana Karting
    Dec 30, 2006
    177
    Vermont
    Peter Markowski
    I am finishing a restoration on a car that will be for sale when finished
  20. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    LOL, I understand ;)
  21. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    Sent you PM Steve
