1964 Maserati Mistral Restoration | FerrariChat
Discussion in 'Maserati' started by Dosombres, Apr 16, 2011.
  1. Dosombres
    Dosombres Rookie
    Apr 16, 2011
    48
    Mannheim
    #1 Dosombres, Apr 16, 2011
    Hello,
    i am new in this Forum and new in Maserati Cars....
    Just bought a 1964 Mistral which i will bring back to Life.
    I do Restorations for about 25 Years now... starting with Motorcycles and go over to Cars
    about a few Years ago.
    Last Project was a 1966 Jaguar E-Type which was sunk in Hurrikan Katrina.
    I sold this Car to full fill my Dream of an old Maserati.
    Can someone help me with the Colors which where used original on the Mistrals?
    Thank you for helping
    Roger
  2. italiancars
    italiancars F1 Rookie
    Apr 18, 2004
    3,339
    Hershey, PA
  3. Dosombres
    Dosombres Rookie
    Apr 16, 2011
    48
    Mannheim
    Thank you Joe,
    i have print it out....
    did you know if the two ear Locknut of the Borranis are only used on very early Cars or are they used on a Mistral too ?
    Roger
  4. italiancars
    Apr 18, 2004
    3,339
    Hershey, PA
    #4 italiancars, Apr 17, 2011
    The car I used to own, Mistral #1216 a '67 had 3 ear.
  5. 1Hurthutoy15
    1Hurthutoy15 Karting
    Sep 16, 2009
    108
    I have never seen two ear knockoffs on the Mistral but you never know!maybe it was a costumer special order:)
    Jacques
  6. Dosombres
    Dosombres Rookie
    Apr 16, 2011
    48
    Mannheim
    #6 Dosombres, Apr 17, 2011
  7. Portenos
    Portenos Formula 3
    Aug 20, 2004
    1,851
    Seattle
    Carguytour
    Welcome to the "madness" and pleasures of restoring an old Maserati and welcome to Mchat.
    My 3rd Maserati was a early Mistral Spyder #057 with covered headlights.
    I bought it for $6,250.00 standing on a corner in downtown Seattle. That was in 1977/8.
    It had 3 ear K/O's.
    Ciao,
    FGM
  8. 1Hurthutoy15
    Sep 16, 2009
    108
    #8 1Hurthutoy15, Apr 17, 2011
    most likely not original to that car.
    Jacques
  9. Dosombres
    Dosombres Rookie
    Apr 16, 2011
    48
    Mannheim
    Hello,
    does anybody knows how the Doors came off?
    How i came to the Doorbolt, or does they came off unscrewing the bolts inside the Doors?
    Does the Engine came out as unit with the Gearbox, or does the Gearbox get off first?
    Thankx
    Roger
  10. jonack
    jonack Formula Junior
    Jul 3, 2007
    290
    Berkeley, California
    J. Clark
    All of my door hinges were welded on, I just popped out the pins. Mind you that was no easy feat. Those pins were stuck.. The engine can be pulled and returned with the trans on. It’s a bit long though, and heavy! You’ll need to be careful when you put it back in….. The transmission in these cars comes out through the cockpit, it is not possible to install from underneath. Mistrals are fairly small cars, it’s a pretty tight fit all around. I hate to say this, but some of your body panels should be made out of aluminum. This is great for weight savings! But hard on restorers, as the aluminum panels react poorly with the steel sub frame. With a proper resto you might need to pull some of those panels off, repair them and tend to the supporting metal frame. Have fun!!!!
  11. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Subscribed.
    Pete
  12. Dosombres
    Dosombres Rookie
    Apr 16, 2011
    48
    Mannheim
    #12 Dosombres, Apr 21, 2011
    Hey Jon,
    yes, i know... it is the same Story as on the old Astons.
    There is a lot of Work to do, but this drives me... :)
    have add you a Picture.... everywhere the Water can flow away there is rust but only on a few places.
    Did you know if there are aftermarket Steelsheets as for the Front ?
    Roger
  13. Dosombres
    Dosombres Rookie
    Apr 16, 2011
    48
    Mannheim
    Does someone can post me a Photo of the Front part shown that i could make a reconstruction of the part?
    Thanks for helping
    Roger
  14. italiancars
    Apr 18, 2004
    3,339
    Hershey, PA
    #14 italiancars, Apr 25, 2011
  15. Dosombres
    Dosombres Rookie
    Apr 16, 2011
    48
    Mannheim
    Thank you very much.
    Did you can give me a closeup where the posts for the Hood are?
    Is the Fold in the rear open to build a Chanel...... do you have a Closeup of this?
    Thanks for Helping
    Roger
  16. carnutz
    carnutz Karting
    Aug 11, 2008
    111
    #16 carnutz, Apr 25, 2011
    Roger, attached are some photos from my Mistral. The hood pins are threaded shafts that go through the trough in front of the radiator. They are secured by a nut on top and a nut underneath. Besides the holes for the hood pins are three drainage holes. Possibly these were blocked on your Mistral which led to the heavy rust condition.
    Someone with a Mistral with the hood removed could take much more descriptive photos.
    Good luck,
    Larry
  17. Dosombres
    Dosombres Rookie
    Apr 16, 2011
    48
    Mannheim
    Hello FGM,
    i would be lucky if i could bought it back in 1977..... i just dream of them back then :)
    Thank you for your welcome greetings...
    Roger
  18. Dosombres
    Dosombres Rookie
    Apr 16, 2011
    48
    Mannheim
    Hello Jon...?
    I have taken all surround Parts from the Engine Bay.... have found out it is easier to disconnect the Gearbox from the Engine and take out the Engine first.... so you can take it out straight and you have much more place....
    Thank you
  19. Dosombres
    Dosombres Rookie
    Apr 16, 2011
    48
    Mannheim
    #19 Dosombres, May 5, 2011
  20. Mexico074
    Mexico074 Formula 3
    Aug 14, 2008
    1,227
    Harriman, TN USA
    Michael Demyanovich
    hello Roger(Dosombres)...
    Keep up the good work and please continue to keep us posted...
    In your most recent picture, I can only see one coil... Is that correct,
    or are there two?? My 64 Mistral (109.102) has two... Mine is a project
    that I will get to when I have some of the others done.. But if you
    need pictures or information, I might be able to help...
  21. emsiegel13
    emsiegel13 Formula Junior
    503
    Grayslake, Illinis
    Elliot M. Siegel
    Your view of the engine is interesting as it appears that your engine pulley is one used with the air conditioning setup. Did your Mistral come with air conditioning?
    Elliot Siegel
  22. Dosombres
    Dosombres Rookie
    Apr 16, 2011
    48
    Mannheim
    Hello Mike,
    if you look closer you see the second one behind....
    Thank you for your Post.
    Roger
  23. Dosombres
    Dosombres Rookie
    Apr 16, 2011
    48
    Mannheim
    Hello Elliot,
    yes it has an Air Condition, but i don't reinstall them.
    If somebody is interested i will sell it with all the Parts and Brackets.
    Roger
  24. Dosombres
    Dosombres Rookie
    Apr 16, 2011
    48
    Mannheim
    #24 Dosombres, May 6, 2011
  25. Dosombres
    Dosombres Rookie
    Apr 16, 2011
    48
    Mannheim
    #25 Dosombres, May 14, 2011
