1977 308 GT4 aka DaddyO Dino | Page 6 | FerrariChat
Discussion in '308/328' started by Vonbarron, Mar 3, 2021.
  1. Vonbarron
    Vonbarron Formula 3
    2,289
    Westside Mofo
    S B
    absostone and NoGoSlow like this.
  2. NoGoSlow
    NoGoSlow Formula Junior
    643
    Republic of Texas
    Mark Jacks
    Good call. Too many old cars get torched due to gas leaks, especially with ethanol-based fuels on old rubber.
    absostone likes this.
  3. Jdubbya
    Jdubbya The $10 Trillion Man
    43,928
    Hell's waiting room
    The fun one is the filler neck. Don't forget that one. :)
    Mike Florio and absostone like this.
  4. Vonbarron
    Vonbarron Formula 3
    2,289
    Westside Mofo
    S B
    Jdubbya and 308 milano like this.
  5. 308 milano
    308 milano F1 Veteran
    5,351
    Montana
    Kim
    Yeah, looks like the same fuel hose that was on it when it rolled out of the factory! :)
    Jdubbya likes this.
  6. Jdubbya
    43,928
    Hell's waiting room
    308 milano likes this.
  7. steven_ew
    steven_ew Karting
    Apr 3, 2009
    107
    I’m changing all the hoses in both of mine before they go back on the road. I’ve survived a fuel leak in the GTS already (no fire at any stage just a smell of fuel and I discovered after some time that one of the hoses coming out of the top of the tank had shrunk and come off) and found evidence of a small self contained fire on top of the GT4 (completely rebuilt engine and this was down to a carburettor leak).
    I consider myself lucky and also thinking about installing fire extinguishers
    steved033 and absostone like this.
  8. Vonbarron
    Vonbarron Formula 3
    2,289
    Westside Mofo
    S B
  9. rob
    rob F1 Rookie
    May 22, 2002
    4,310
    Vt
    Did you get an egg cream or go to the Ba Da Bing or do any Jersey stuff ?
  10. Vonbarron
    Vonbarron Formula 3
    2,289
    Westside Mofo
    S B
    I toured the devastation, except I didn’t see any
  11. Jdubbya
    43,928
    Hell's waiting room
    It's looking better bit by bit!!
  12. Vonbarron
    Vonbarron Formula 3
    2,289
    Westside Mofo
    S B
    Had a couple hours today, change out a motor stabilizer, I don’t have a press so that was a suka, heated it a bit and bashed out the old one with a socket then beat in a new one. Also made some fill in panels for the old bumper areas, it’s all a moot point since the entire trunk needs to be cut off and all the structure replaced. The old engine mount looks like something at the adult bookstore
  13. john earhart
    john earhart Rookie
    Nov 15, 2020
    15
    New hampshire
    john earhart
    Looks great so far!!! Fantastic work; this thing is awesome!
  14. Vonbarron
    Vonbarron Formula 3
    2,289
    Westside Mofo
    S B
    Now that the outlaw is gone for a week at the car show, I can mess with the mess, welded the corners on, the amount of lead and bondo is fun, I’m sure I’m poisoned. Stand by for lockjaw and crazy talk, I also for fun decided to slow down the cancer creep by spraying rust converter in all the voids, oh and I ran out of welding gas of course on the first corner welded
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  15. Vonbarron
    Vonbarron Formula 3
    2,289
    Westside Mofo
    S B
    I’m trying to get water temperature gauge working and discovered there’s no wire going to the sensor, anywhere, no loose wire hanging down, zippo. I looked everywhere, consulted the manual for wire run map , still no idea where it should be in the loom in engine bay if anyone can enlighten me
  16. absostone
    absostone F1 World Champ
    10,237
    That stuff is gonna fall out of the other holes. LOL
  17. absostone
    10,237
    By putting that nozzle in the hole behind the drivers side front wheel you will coat the Brake vac line and coolant hose FYI
  18. Vonbarron
    Vonbarron Formula 3
    2,289
    Westside Mofo
    S B
    Yeah I’m aware, once all that rotten steel is cut out, hoses will get updated, they work for now
  19. Vonbarron
    Vonbarron Formula 3
    2,289
    Westside Mofo
    S B
    I have the DaddyO up on the parking lift currently, every time I walk by I notice that the sway bar is showing small signs of wear. Off to the basement to seen what’s what for supplies. Turns out I have enough pretty good/new stuff to fix it up. I can see the sway bar link and brackets were crushed, drivers link was broken and rewelded at some point
  20. Vonbarron
    Vonbarron Formula 3
    2,289
    Westside Mofo
    S B
    Went ahead and bombcan restored the nuts and bit of the frame. Not going crazy here, I’m eventually cutting out all the sheet metal, cleaned up the links, pressed new bushings in, already had a gold plated weak sauce sway bar so that’s going in. Obvious race car now, surprised I’m not in handcuffs. Time to reassemble and brag about all the fine work I’m doing. I finally used my Ferrari service tools also
  21. absostone
    10,237
    Not a sway bar. Torsional resistance spaghetti is what the SPC calls it. (al Dente)
    steved033 likes this.
  22. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,539
    Tulsa, OK
    John McDermott
    Love those long t-handle swivel sockets.
  23. Jdubbya
    43,928
    Hell's waiting room
    Slick tool cabinet.
  24. Vonbarron
    Vonbarron Formula 3
    2,289
    Westside Mofo
    S B
    Since it’s raining and horrible outside I decided to make some patterns for the roll pan. Also was able to license it after running around illegal for a couple years, pulled the plate off and some message behind the plate, some girl named Niki apparently is pretty great or so someone named Laro Larrini says
