Buy
1977 308 GTB FUEL FILTER
Discussion in 'Technical Q&A' started by Leweyb, Apr 24, 2004.
  1. Leweyb
    Leweyb Karting
    Apr 24, 2004
    166
    East Hampton
    MISPLACED MY SHOP MANUAL, IS THE FUEL FILTER, A BOSCH IF I'M NOT MISTAKEN LOCATED THROUGHT THE LEFT REAR WHEELWELL? ANY TRICKS FOR CHANGING OUT?
    MANY THIANKS IN ADVANCE
  3. ham308
    ham308 Formula Junior
    Nov 3, 2003
    358
    NE Switzerland
    Richard Ham
    from the manual
  4. Verell
    Verell F1 Veteran
    May 5, 2001
    7,009
    Groton, MA
    Verell Boaen
    Use a pair of vice-grips w/wooden blocks in the jaws to clamp off the fuel line running from the tank to the pump.
    Saves draining the tank.
    Then mostly the usual stuff like:
    -Use tubing wrenches on the fittings so you won't round off the fitting.
  5. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,366
    NY
    Simple just squeeze of tank line and unbolt bottom bolt and remove can. Make sure you have a small bucket under the fuel can. Then take out the gasket and put in the new filter and gasket . Tighten the bolt and your are done. Only need to make sure that the gasket is seated in the top of the filter housing when you put the can on.
  6. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,687
    North shore, MA
    THE Birdman
    Yes, left rear wheel well.
