1977 308 GTB New Ownership | Page 3 | FerrariChat
Discussion in '308/328' started by jspencer1532, Oct 8, 2015.
  1. david
    david Formula Junior
    Feb 21, 2001
    810
    Northwest
    david
    Good luck with the smog test. Too bad the laws are so ridiculous.
  2. david
    Feb 21, 2001
    810
    Northwest
    david
    Hah!
  3. david
    Feb 21, 2001
    810
    Northwest
    david
    How the heck did you get the air injection assembly into the front bank? I thought you would have to pull the engine. Is there actually room to work in there?
  4. jspencer1532
    jspencer1532 Rookie
    Sep 11, 2015
    26
    Irvine CA
    Jeff Spencer
    To be honest I'm having it all done by a restoration specialist. But I know he did not have to pull the engine. I'll be sure to ask him tomorrow.
  5. jessup
    jessup Formula Junior
    Apr 26, 2014
    403
    Santa Clara CA USA
    Jessup
    It's not to bad if you have it on a lift and go from the bottom.
  6. jjeffries
    jjeffries Formula Junior
    Sep 4, 2012
    254
    Connecticut
    John Jeffries
    Stupid question: when you bring a non-California emission spec (30+ year old) car into CA you have to convert it to CA spec? The answer is obviously yes because that's what you're doing. But...wow. In Connecticut we are lucky that 25+ year old cars are exempt. But we do have harsh winters...no one gets it all! John in CT.
  7. BigTex
    79,408
    Houston, Texas
    Bubba
    Impressive, good luck!!
  8. BigTex
    79,408
    Houston, Texas
    Bubba
    It goes into the head, above the rear header.
    Lots of access, if you remove the RH fuel tank, roll the header out of the way, in that direction, unbolt the engine mounts and by jacking the motor slightly.......
    Easy!!!
    :D :D :D
  9. BigTex
    79,408
    Houston, Texas
    Bubba
    They want "the stuff that came on the car, and working" is the best way to summarize it, to my understanding....
  10. jspencer1532
    jspencer1532 Rookie
    Sep 11, 2015
    26
    Irvine CA
    Jeff Spencer
    Yes. I wish there was an exemption because it isn't an easy undertaking. There is talk of making older cars exempt if they fail the test but the smog equipment must still be on the car.
  11. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    I took all this stuff off my 77 years ago. As I recall, the air injection pump was used on a Buick so should be findable. Trying to recall if one pump or two. Anyone?
    Philip
  12. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    Yes, there's definitely a GM equivalent for the air pump - it's in the 308 Parts Cross Reference thread, IIRC.
  13. jspencer1532
    jspencer1532 Rookie
    Sep 11, 2015
    26
    Irvine CA
    Jeff Spencer
    We seem to have hit a snag. The diverter valves don't work and passing smog has been a bit of a trial. Any suggestions on where to get new diverter valves for the emissions system are appreciated.
  14. jessup
    Apr 26, 2014
    403
    Santa Clara CA USA
    Jessup
    #64 jessup, Dec 5, 2015
  15. jspencer1532
    jspencer1532 Rookie
    Sep 11, 2015
    26
    Irvine CA
    Jeff Spencer
    Thanks everyone for the tips and advice. We passed the California smog test and are officially street legal. Now I have to brave the line at the DMV...
  16. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,614
    Gates Mills, Ohio
    Jon
    1975 and later cars need to be smog compliant. Vintage stuff... they don't care. As of now it's not a rolling date, so any 308 GTB/GTS needs to be correct and US spec.
    Congrats on getting the car back to spec. I haven't had to face that challenge, but finding the original equipment and setting it up can't be easy.
  17. Casino Square
    Casino Square Formula 3
    Apr 21, 2004
    1,728
    Hong Kong / USA
    Andrew
    Why not register your car in AZ. No smog check needed as it's classed as 'historic', therefore no need to take it back to AZ each year..... Just asking ;-)
