1978 308 GTS EV Conversion | Page 5 | FerrariChat
Discussion in '308/328' started by 308Hutch, Sep 27, 2014.
  1. 308Hutch
    308Hutch Formula Junior
    Sep 24, 2014
    369
    San Diego
    Hutch
    Mark-
    There are a couple great options for VW EV conversions:
    (1) Zelectricmotors: Here is a link to a guy that EV West supports for full restomods and sales of VW's. ZELECTRIC MOTORS
    David just went live recently with sales and his 1st 2 available cars vaporized. I think they were about $45k - Restored, converted and ready to roll out in totally new fashion.... minus a lot of future VW maintenance... Check out some of David's videos on the site or via youtube:
    https://www.youtube.com/watch?v=jlqNwpMWiIA&spfreload=10
    (2) EVWest.com has kits that are supposed to be fairly easy for a basic gear head to install. Many classic VW Models area already designed and ready to ship in various packages -power/range.... The kits here:
    EV West - High Performance Electric Vehicle Parts ... see the Kits tab on top bar.
    Makes for a classic, reliable and quick day driver. Apparently I will be put to the test and tasked with making a full Beetle conversion with a kit. I have never done it but will be doing it to test (and hopefully prove) that and average guy can perform the conversion. We have it on the schedule and plan to air it on The EV Show in a couple of months.
    Feel free to reach out to me and I can put you in touch with Mike if interested... feel free to visit the shop.
    Have a great weekend.
    Eric
  2. Thomas Magnum
    Thomas Magnum F1 Veteran
    Feb 24, 2013
    8,081
    Mark
  3. 308Hutch
    Sep 24, 2014
    369
    San Diego
    Hutch
    #103 308Hutch, Dec 22, 2014
    This video recap of the EV West M36 race win at Laguna Seca is solid. The 308 is going to come out with hugh torque numbers slightly below the M36. It would be appropriate to take the 308 to LS for inaugural track time seeing as the first race ever run at Laguna was won by a Ferrari!
    https://m.youtube.com/watch?v=hWZH7RT_0TU
  4. 308Hutch
    Sep 24, 2014
    369
    San Diego
    Hutch
    #104 308Hutch, Dec 24, 2014
    After extensive wire brushing the frame we I painted all interior metal/frame flat red to ID the "already covered" areas. Final black is coming soon, after primary fab work. The front end had a little prior crunch damage and subsequent bad repair. We cut out (with saw-all's and flip flops) the crunch area and SRD has re-fabricated the front frame to accommodate the battery box and restore the frame strength. We cut the side frame steel with a plasma cutter/ SolidWorks to create a light weight and exceptionally strong structure. The holes were cut on the plasma cutter and then punched with dimples to make a thin piece of steel function with the specs of 1/3"+ of steel. It is paper thin and very low weight. Racing tech.
    Having thoughts of turning a roller into a full out EV race car...... :)
  5. 308Hutch
    Sep 24, 2014
    369
    San Diego
    Hutch
    We just posted updates covering the past 120 days on the EV 308 Conversion project on the EVShow.com in our January 2015 Episode. 2 video segments are included. Will be updating progress on the project every month there as well as here.
    https://www.youtube.com/watch?v=uUfKGqTxiMQ&spfreload=10
    Happy New Year and all the best to everyone in 2015.
  6. shmark
    shmark F1 Rookie
    Oct 31, 2003
    2,968
    Atlanta
    Mark
    Eric I love it, what a fantastic way to get life into an old bug. Gonna see what my wife thinks about it now. :D
  7. Thomas Magnum
    Feb 24, 2013
    8,081
    Mark
    Well done. You guys are having too much fun. See you tomorrow. Lots to talk about.
  8. 308Hutch
    Sep 24, 2014
    369
    San Diego
    Hutch
    #108 308Hutch, Jan 6, 2015
    The G50 is upside down and backwards mounted on the trial end...... note the Patrick Motorsport Cable bracket fitted. Had to extend the nose bolts, shave down a small nose section to accommodate the shifter cable bracket crossover bar. I see the new mounts on the inside for the Euro bumper fitting... more photos soon as I get to SRD today.
    The battery boxes are all fitted as well.... Should be about ready to bring back to EV West for the next round of projects.... Fitting 3 AC-51's, electrical system overhaul, chassis painting...... and the list is long!
  9. 308Hutch
    Sep 24, 2014
    369
    San Diego
    Hutch
    #109 308Hutch, Jan 6, 2015
    (1) PSM shifter cable bracket on but still to be modified (extended for our "custom" short-nose).
    (2) Better resolution pictures of the G50 mounting bracket.
    (3) Front Battery Box fitted nicely.
    (4) Rear Euro Bumper Bracket just welded up... not painted but a clean fit into the US bumper shock mount. Easy in and out using existing frame bolts from inside trunk.
    (4.5) Front bracket done later today... stay tuned.
    (5) Rear Crossmember re-built to accommodate motor and transaxle alignment.
  10. Thomas Magnum
    Feb 24, 2013
    8,081
    Mark
    Nice progress. Thanks for the update and pictures.
  11. 308Hutch
    Sep 24, 2014
    369
    San Diego
    Hutch
    #111 308Hutch, Jan 15, 2015
    The custom made short nose required that we re-fabricate the PMS cable bracket. Note the extension ad on. Extended from original picture to the second photo. Perfect alignment now so we can measure and order the cables. Also ordered the custom hydraulic clutch and brake pedals, masters and reservoirs (similar construction to photo attached from a Baja truck.... but obviously will be top mounted w remote reservoirs). Clutch will be operating the Tilton clutch push release clutch bearing since we have the G50 in backwards and upside-down. Brakes will be manual with 8:1 ratio. Brakes will be adjustable front to rear. Pedals should be mounted and we should have this back next week to start building forward through the transaxle into the motors.
  12. matumorales
    matumorales Formula Junior
    Jun 8, 2011
    470
    Asunción, Paraguay
    Daniel Morales
    Eric;
    I noticed you're making many custom brackets and mounts, and that they look AWESOME! Very professional work, congrats, BTW!
    Do you have a CNC cutting table at the shop? Or are you using an outside provider for these? I'm involved in a project that'll require some CNC cut parts (http://www.ferrarichat.com/forum/308-328/359739-chassis-37313-resurrection-308-gtbi.html), and I still don't have a source for these...
    Keep up the good work! It's turning out amazing! Love this thread!!
  13. 308Hutch
    Sep 24, 2014
    369
    San Diego
    Hutch
    Full CNC shop and Solid-works connected plasma cutting table at SRD who partners with us at EV West. Will PM you.
  14. palmer_md
    palmer_md Karting
    Feb 26, 2014
    65
    Hermosa Beach, CA
    Michael
    Are you working on this project on weekends? I'm going to be in the area on Saturday the 31st. If love get a look at your project.
    Michael
  15. 308Hutch
    Sep 24, 2014
    369
    San Diego
    Hutch
    Michael- Sent you a PM.
    Will have more updates next week. Picking up the car today and brining it back to EV West from SRD, ready for the next phase of to project. Making good tracks. Stay tuned for updated next week. Have a great weekend.
  16. 308Hutch
    Sep 24, 2014
    369
    San Diego
    Hutch
    #116 308Hutch, Jan 30, 2015
    Moving along at a steady clip now:
    1. Euro bumpers mounted with new custom brackets (available if anyone needs - PM me)
    2. 3 Battery Boxed designed, fab'd and installed
    3. CNC off road aluminum racing pedals, master cylinders, and hydraulic clutch installed. 3 remote reservoirs tucked above via a custom fab bracket fitting the OEM mounting holes...master cylinders. Really consise install. Space saver. Eliminates transfers OEM brake pedal box, brake booster, and need for electric vacuum pump in conversion. Really frees p substantial space and reduced total weight as well.
    4. "Smart Car" electronic Accelerator pedal mounted, installed.
    5. G50 Hanger fabricated and installed.
    6. PMS cable shifter bracket installed (after modification)
    7. Grill modified to fit Euro front Bumper . DRLs fitted int metal extensions.
    Photos:
  17. palmer_md
    palmer_md Karting
    Feb 26, 2014
    65
    Hermosa Beach, CA
    Michael
    I saw this project in person last week, and all I can say is WOW! This project is going to be awesome. The attention to detail is unreal. Fabrication work on the brackets and other details is phenomenal. The torque that is going to come from three electric motors will absolutely blow the doors off of any other 3x8 out there. I'm looking forward to future updates on this. Great work Eric.
    Aus_yz likes this.
  18. Casino Square
    Casino Square Formula 3
    1,728
    Hong Kong / USA
    Andrew
    This is AWESOME. I love carbs and petrol engines, but you have to admire someone who can put this level of creativity to work. What an amazing project. Respect with a capital "R". :)
  19. badkarma308
    badkarma308 Karting
    Aug 5, 2010
    88
    Fairfax, VA
    Seth
    #119 badkarma308, Feb 8, 2015
    I had the pleasure of visiting Eric at the EV West shop this afternoon; I have to say the pictures do not do it justice. Engineering is first rate on all their builds and the 308 is going to be a sweet ride when it's done. I highly recommend checking out their videos if you haven't already; impressive and entertaining. Here is my crappy camera phone picture to add to the mix, I'll have to remember the DSLR next time. My Euro QV is out front and you can just see Eric's 308 EV peeking out from behind the bus.
  20. 308Hutch
    Sep 24, 2014
    369
    San Diego
    Hutch
    #120 308Hutch, Feb 10, 2015
    Looks like this is going to go. Faro arm to design new aluminum cluster and I am looking at a few options for a set of gauges to fill the 7 spots for the EV project. Too many items that need upgrading so figured best to pull the entire cluster, redesign, and set new gauges in cluster a(including 2 side gauges).
    Will aim to make something special here. Into the wiring... more to post shortly.
  21. 308Hutch
    Sep 24, 2014
    369
    San Diego
    Hutch
    #121 308Hutch, Feb 10, 2015
    Look closely at this for a while and settled into liking the Truck-Lite LED 2727OC headlights to replace the Halogens. Great optics and considering our mods they will be a nice compliment. They are not as light weight as replaced lights but they feel great, solid, and bullet proof. Drop in required a little extra movement of headlight cover assemble to fit over the additional 1/2" or on the lens protrusion but no problem. 3 prong was a direct connect. 5 minutes to install. About $340 for pair.
    Their points:
    **Military grade, die-cast aluminum housing and non-yellowing, polycarbonate lens offer optimum protection against damage from impact, roadside debris and other hazards
    ***Electronics are sealed in epoxy to resist from damage caused by corrosion or moisture
    ****Advanced circuitry protects against voltage spikes up to 600v
    *****Drop-in replacement for #6014, 6015, 6016, H6024 and Par 56 headlamp designs
    Uses standard, H4, 3-blade wiring connector
  22. 308Hutch
    Sep 24, 2014
    369
    San Diego
    Hutch
    #122 308Hutch, Feb 10, 2015
    Since we have a 3'x5' wiring diagram on the wall and the 308 is back from SRD, it is time to moving. James is in from Australia helping out for 2 months and man what a great guy! He has a Nissan Skyline under conversion with 2 WARP 11's..... basic translation: stupid horsepower! seriously.
    Tracing every wire down in the 308 to remove every and any last unnecessary wire, relay, contact etc. New fuse and contact blocks are in order.. have yet to look them up here but feel free to toss an idea or two out..... Wires are in good shape under the old sheaths. Some classic 80's additions hiding in the wires... fuel pump secret kill switch, auto-paging theft device, a few questionable wire jumps...:). What a story inside.
    The bottom photo is above the driver knee area under dash... That a down light??? Have yet to check wires but thats my guess... bet someone knows that right off the bat??
    Now we have the 308 back there will be more posts w progress. Busy week kept me from getting a few of these up.. There are a couple new ones posted not he bottom of page 6 too if you have any interest.
    More tomorrow on the complete exterior LED bulbs for all the lights (other than the Truck-Lite's. Found some solid bulbs, low prices, and they fit well.
  23. 308Hutch
    Sep 24, 2014
    369
    San Diego
    Hutch
    Here is the latest video (link to the commencment point of Ferrari 308 EV Conversion coverage inside of the EV Show) update contained quickly within about 4 min covering past 30 days of work. Love any feedback on the show too.
    https://www.youtube.com/watch?v=8KJr66bDxH8&feature=youtu.be&t=1h10m55s
    We are trying.... learning, having fun with projects, building content.... and yeah, and having more fun every time... We did miss the super bowl but made for open roads!
    And Great to meet you Seth.. Thanks for stopping but with you 85 QV Euro... Thomas Magnum thinks thats #4 on his registry for US Euro's..... Fun putting it up on the scales. That will be a nice point of comparison.....
    (note there are about 5 new posts I finally got up tonight before this one tonight).
    Cheers,
    Hutch
  24. 308Hutch
    Sep 24, 2014
    369
    San Diego
    Hutch
    #124 308Hutch, Feb 10, 2015
    Seth - Here are a few photos.... Thanks for stopping by to share over the weekend. Made James' day.. Aussie loved his first ride in a Ferrari!
  25. LostAussie
    LostAussie Formula Junior
    Jun 13, 2013
    714
    Piemonte
    Stuart
    It's the socket for the portable trouble light that came with the car from new.
