1980 308 GTSi sn 32819 | FerrariChat
Discussion in '308/328' started by SAFE4NOW, Jul 14, 2021.
  1. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,404
    Dallas Texas
    If you know you know
    I know this is an old ad, car has been sold, but I wanted to draw upon the FerrariChat brain trust and get their feedback on this car:
    https://www.worldwidevintageautos.com/vehicles/5313/1980-ferrari-308gtsi
    I don't think I have ever seen those wheels on a 308 before, but I could be wrong.
    Wrong shifter " ball "
    the seats look to be vinyl vs leather
    What do you see?
  2. Grim Reaper tr
    Grim Reaper tr Karting
    Oct 6, 2014
    115
    Very early 2vi car.....unpainted Plenum in engine bay and vertical clock and oil temp guage. Still wearing 80MPH restricted speedo!
    Be interesting to see build date?
    These were pre-Michelin TRX and Metric tyres.
    Wheels pictured are off a Mondial, TRX (wrong obviously) and spare is "14 inch rim with Michelin XWX.
    Seats and carepet are re-trims and wrong. External mirrors are aftermarket and has been repainted...should be black sealent line at rear of side window louvres on rear wings.
    Grim
    mwr4440 and SAFE4NOW like this.
  3. waymar
    waymar Formula 3
    Sep 2, 2008
    1,324
    Northeast, PA - USA
    Wayne Martin
    Marked as SOLD
    SAFE4NOW likes this.
  4. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,404
    Dallas Texas
    Thank you, this is what I am looking for, I appreciate your feeeback!
    Correct, I happen to know where the car is now, and am looking for feed back as Grim offered above, on what things visually need addressing.
    or other known historical information that may be of interest to others.
    Steve
    RodC328gts likes this.
  5. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,404
    Dallas Texas
  6. ProvaMo
    ProvaMo Formula Junior
    Jun 29, 2004
    308
    Mid West
    Paul John
    Incorrect horn button, painted A-pillars in semi-gloss, but not behind targa top areas by quarter windows, also quarter window louvers are painted all back (I think this year should have the silver highlights). Lots of after market speakers, like a subwoofer in passenger footwell and speakers at quarter glass. Some aftermarket switch (battery disconnect?) under front bonnet in front right corner area. Also looks like a repaired right front bumper, and the parking brake lever is bent.
    Agree with all of Grim's comments, good call on the wheels including the likely original 14" spare. I'll reserve judgment of the aftermarket mirrors...
  7. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,404
    Dallas Texas
    Car has arrived and project(s) started:
    1. Timing belt service completed w. new rollers, and aux belt
    2. All Fluids and filters replaced ( Oil, Coolant, brake, gearbox ) & replace spark plugs
    3. Brake calipers rebuild all the way around
    4. Replaced window switches to confirm windows work, but slow ( no surprise )
    5. New Battery
    6. Drained fuel tank
    7. Replaced Motronic ECU's ( internal short )
    8. Replaced shift ball
    9. Replaced horn button back to stock
    Projects to go:
    1. Suspension: 4 Shocks, front and rear bushing kit ( need lower front control arms )
    2. Engine: air intake boot, valve cover gaskets , oil pan reseal, and engine dist gaskets
    3. Gearbox: linkage O-rings/seals and sump reseal
    4. Engine cover struts
    5. Replace steering wheel due to leather splitting due to age ( saving original steering wheel )
    6. Front and rear bumper replacement
    7. Radiator surround insulation
    8. Repair center console and recover
    9. Exterior mirror replacement
    10. Replace wheels with either OEM spec or Reproduction 328 wheels
    11. Replace muffler box, current one is rusted out and exhaust tips are falling loose.
    Under consideration:
    1. Complete repaint of car. ( It appears to have already been done before and small areas of corrosion can be addressed at the same time )
    It was a relief that the car runs and stops strong as-is , but I would feel more comfortable with all the above being done before taking an overnight FCA drive!
    Buckling down and getting started...
    Steve
  8. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,257
    Montana
    Kim
    Congratulations! Now let’s see some pictures of this baby’s transformation!
  9. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,404
    Dallas Texas
    Parts sourced and ordered except for:
    1. Wheels.. I would like the OEM 14” or metric equivalent. Mostly for the ride quality having the larger sidewalls ( Please correct me if I’m wrong )
    Tire price doesn't bother me so much.
    2. Muffler... still reading all the treads back past 2010.
    Steve
  10. jimpo1
    jimpo1 Two Time F1 World Champ
    Jul 30, 2001
    24,530
    Dallas, TX
    Jim E
    I was going to suggest the 328 wheels for improved handling until I read BigTex's response. He likely knows, given all the 308's he's owned. :)
    Do you have a source for the engine cover struts? ;)
  11. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,404
    Dallas Texas
    This is where I purchased them from: https://www.superformance.co.uk/308/fittings.html
    Steve
  12. BigTex
    79,218
    Houston, Texas
    Bubba
    328 wheels are totally different in appearance to the earlier wheels.
    Compare a 16" 328 to a 16" 308 casting.
    Here's something to ponder:
    How many suspension parts are shared across the 308/308QV/328 series.
    I suspect (although have not spent the time) not many..
    I'm just saying having driven both TIRE sizes a long time, the 16"s lower the car and ride harsher, at railroad tracks and such.
    16" more likely to damage in pot holes, too...
  13. BigTex
    79,218
    Houston, Texas
    Bubba
    That Emissions Sticker in the jamb is easily damaged, if removed.......mine has migrated around of the years.
    They are readily available and of course YEAR specific, should match the Production Plate and the Engine Tech plate in the back.
  14. BigTex
    79,218
    Houston, Texas
    Bubba
    KONI will rebuild the shocks as new.
    There's a shop in the Dallas area that does excellent work on leather steering wheels the did my TransAm. Garland maybe??
    I would add cleaning the radiator, "rodding" as you can put the seals around it in place, but I always wondered how much "sludge" is in there after 40 years...
    PM sent on wheels I was in San Antonio....Sam's Burgers
  15. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,404
    Dallas Texas
    ....ended up finding a local FCA member with a set of 14 inch wheels he’s had in storage.
    I’ve already sent them off to begin refinishing, tires are on order... !
    Steve
    miketuason and jimpo1 like this.
  16. jimpo1
    Jul 30, 2001
    24,530
    Dallas, TX
    Jim E
    Watching this with interest! Can't wait to see if you look good in it. ;)
    I assume that you changed the fuel lines when you drained the tank?
  17. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,404
    Dallas Texas
    Fuel Lines
    Vac lines
    plastic junctions and connectors
    You know we will be driving this one as much as the Cali T, I'm not one that likes to break down much... LOL
    S
  18. jimpo1
    Jul 30, 2001
    24,530
    Dallas, TX
    Jim E
    Do you FIT? You're a tall guy! My son can hardly drive my car with the top on.
    If you don't like breakdowns, you should've bought another car! :D
  19. AClark
    AClark Formula Junior
    315
    #19 AClark, Sep 18, 2021
    Note
  20. AClark
    315
    #20 AClark, Sep 18, 2021
    Note
  21. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,404
    Dallas Texas
    That’s why we got a GTS and not a GTB
    lol
    Steve
  22. jimpo1
    Jul 30, 2001
    24,530
    Dallas, TX
    Jim E
    So my son can drive it? :D
  23. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,404
    Dallas Texas
  24. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,404
    Dallas Texas
