1981 308 GTSi mirrors | FerrariChat
Discussion in '308/328' started by F308fan, Nov 21, 2021.
  1. F308fan
    F308fan Karting
    May 7, 2017
    138
    Peoria, AZ
    Tony Pacini
    I just acquired a US-spec 1981 308 GTSi and have questions about the side mirrors.
    There are painted mirrors on each door and I don’t believe they’re OEM. Can anyone determine with any level of certainty what type they are?
    Both mirror assemblies ‘sag’ and won’t stay up. Is there a fix for this?
    I can’t imagine why there’s black sealer added around where the mirror bases attach to the door, especially in this fashion. Any ideas?
    Lastly, the driver’s power mirror works but the passenger side doesn’t. The switch appears to be the selectable type for use with 2 mirrors. The wiring diagram I have only shows a driver’s power mirror, but I’ve read about adding a different switch and a passenger side power mirror. It would appear that this is what was done, but the passenger side mirror doesn’t work. Has anyone else done or seen this, and does it look like that’s how my car’s equipped?
    I’m hoping to get an idea of what’s going on before going into 40-year-old doors on a fishing expedition. Getting that sealer off the doors probably won’t be a lot of fun, either.
    Thanks in advance for any guidance provided.
  2. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,614
    Pittsburgh, PA
    Matt F
    I believe that nothing came from the factory.
    Those are very un-original looking. The switch is wrong too.
    I’d say replace them with whatever you find attractive.
    Matt
  3. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,534
    Cerritos, CA.
  4. RodC328gts
    RodC328gts Formula Junior
    Aug 17, 2021
    454
    Mexico
    Rod C
  5. rjlloyd
    rjlloyd Formula Junior
    438
    Brisbane, Australia
    Richard Lloyd
    They look very similar to what are fitted to my '81, though I've always been of the belief that mine were retrofitted from a later model (QV?) some time prior to me buying the car and have the small Ferrari badges on the back. As for them drooping if you pull the concertina boots back, mine have a bolt in there that can be tightened
  6. F308fan
    F308fan Karting
    May 7, 2017
    138
    Peoria, AZ
    Tony Pacini
    Ah! That’s part of what I’m looking for; I’ll pull those boots back and look for a fastener to tighten. Thanks!
  7. Dr Tommy Cosgrove
    35,338
    Birmingham, AL
    Tommy
    If you want to put it back the was it was originally, the most likely way an 81 US car left the dealer was with a single black flag mirror. Nothing on the passenger side.
    waymar and Jbrauer like this.
  8. F308fan
    F308fan Karting
    May 7, 2017
    138
    Peoria, AZ
    Tony Pacini
    All,
    Thanks for your replies and photos. 3 of my 4 questions have been answered.
    Pulling the boot back revealed a bolt to be tightened, just as shown in the photos.
    As for the black goop? It’s covering a hole in the door at the leading edge of the mirror :mad:. Such hackery. If I can find mirrors with a longer mounting base (to cover that hole) that’d probably be the way to go.
    As for the right power mirror not working, that’s not as much of a concern. If I end up swapping the mirrors then I’ll investigate that at the time. I can’t say it’s worth pulling the door apart just for that.
    Thanks for all of your help.
  9. RodC328gts
    Aug 17, 2021
    454
    Mexico
    Rod C
    Maybe just the left mirror is electrical?
  10. Dr Tommy Cosgrove
    35,338
    Birmingham, AL
    Tommy
    The hole isn't a surprise. The US flag mirrors have a longer base than the "euro" or whatever you want to call them, have.
    You can see a hole peeking out from under the edge of mine from where I swapped mine but my car is black so you just dont see it unless you know its there.
  11. F308fan
    F308fan Karting
    May 7, 2017
    138
    Peoria, AZ
    Tony Pacini
    Dr. Tommy,
    Yes, I’d have to agree. I took the mirror off and cleaned off the goop, and the holes appear to be from the factory mirror. The aftermarket mirror doesn’t completely cover the holes. The other side was an add-on, so there were no holes to cover.
    And yes, RodC, I’d surmise that the other side may be a matching electrical mirror that they just never bothered to wire. I probably won’t, either.
    Dr Tommy Cosgrove likes this.
  12. Dr Tommy Cosgrove
    35,338
    Birmingham, AL
    Tommy
    Here is mine with the genuine factory mirrors after removing the flag mirrors.
  13. Dr Tommy Cosgrove
    35,338
    Birmingham, AL
    Tommy
    Kent Dellenbusch, Albert-LP and thorn like this.
  14. RodC328gts
    Aug 17, 2021
    454
    Mexico
    Rod C
    this one goes in the exhaust section.
    BTW your cats look brand new
    308 milano likes this.
  15. Dr Tommy Cosgrove
    35,338
    Birmingham, AL
    Tommy
    lol,
    That actually took me about 5 seconds. I need another cup of coffee
  16. surfdwn
    surfdwn Karting
    Sep 28, 2005
    128
    Freeport, Fl
    I have those Euro Vitaloni Turbo powered side mirrors on my 328. Can anyone tell me where I can get new electrical ones like these?
  17. miketuason
    Feb 24, 2006
    15,534
    Cerritos, CA.
    Almost impossible to find one let alone new ones as I tried searching for one years ago because I had two brand new for the right side and after years of searching for the left side I finally found a used one and traded my new right side for it, so now I have a pair, one new right side and one used left side.
  18. RodC328gts
    Aug 17, 2021
    454
    Mexico
    Rod C
  19. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    Kent Dellenbusch likes this.
  20. surfdwn
    surfdwn Karting
    Sep 28, 2005
    128
    Freeport, Fl
    Thanks. My car currently has a pair of the manual Vitaloni Turbo mirrors that the PO had on it. I would like to get the motorized ones to replace them.
  21. Dr Tommy Cosgrove
    35,338
    Birmingham, AL
    Tommy
    Are the extras for sale?
  22. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    The mirror brackets are £60ea plus post. A few pairs left. If anyone wants flag mirrors I switched to the prettier California mirrors
  23. Dr Tommy Cosgrove
    35,338
    Birmingham, AL
    Tommy
    I'm out of town. When I get back home I may get two.
