1981 308 GTSi rich condition | Page 2 | FerrariChat
Discussion in '308/328' started by Sickly308GTSi, Oct 13, 2018.
  1. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,139
    Mansfield, TX
    Ron
    FWIW. There is a way to check to see if the cam has jumped timing without removing the valve covers. Looks for the TDC mark on the flywheel for the 1-4 bank under the inspection cover. Bring the engine to TDC and see if the #1 cylinder will hold air pressure. You can do the same with the #5 cylinder as well. Remember to rotate the engine one turn as needed to make sure you are at TDC and not on exhaust stroke. This should give you some idea if the cam timing has jumped compare results from 1 to 5.
  2. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,169
    CT
    John Kreskovsky
    #27 johnk..., Oct 17, 2018
    At TDC on the compression stroke both intake and exhaust valves are closed and have been or will remain closed for a while. The exhaust won't open until about 130 after TDC and the intake will have been closed since about 130 degrees before TDC. Jumping a few teeth won't matter. So unless the belts have jumped a lot of teeth, the valves will still be close at TDC on compression. If a belt has jumped enough to have a valve open at TDC on compression, you probably have bigger problems, like bent valves.
    I'll revise that a little. If it were the exhaust cam that jumped, then then it would close late and you would probably have a bent exhaust valve. So then you might see the inability to hold pressure. But, obviously, much bigger problems,.
  3. ferrariowner
    Feb 21, 2014
    1,139
    Mansfield, TX
    Ron
    John, I agree with your analysis. What I may not have said clearly is compare cylinder 1 to 5. Check the range in degrees the crank can be rotated before and after TDC and hold pressure. If it is different in crank degrees you could have a tooth or more.
  4. johnk...
    Jun 11, 2004
    11,169
    CT
    John Kreskovsky
    That's reasonable. A bit of a pain in the butt, but it should work. I'd suggest using the cam timing to check the angles. As I posted, exhaust opens about 130 after TDC and intake closes about 130 before TDC. But check actually cam timing specs for exact numbers. They are different on Euro and US cars and probably different on carb cars, 2V injected and QVs.
  5. Sickly308GTSi
    Sickly308GTSi Rookie
    Oct 10, 2018
    16
    Mark Collins
    OK guys I must apologize for the extremely late reply. Life has been extremely chaotic lately. I am extremely happy to report that the car can now be reported as diagnosed and fixed! As it turns out, we had a bad catalytic converter that was prohibiting exhaust flow. My father-in-law dropped the exhaust, fired it up and it screamed to the redline as it should! I thoroughly appreciate all of you who stuck with us and helped with suggestions. We learned a lot from you!
  6. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Thanks for the update. Hope it all works out for you.
  7. Albert-LP
    Albert-LP F1 Veteran
    8,046
    around Modena, Italy
    Alberto Mantovani
    May I ask which hole is it? here every day you learn something…
    Thank you very much!
    ciao
  8. ferrariowner
    Feb 21, 2014
    1,139
    Mansfield, TX
    Ron
    The hole is on the fuel distributor. From memory it is located next to the air cleaner on top of the fuel distributor. You remove the plug (screw) to adjust the idle mixture and then reseal it to check air-fuel mixture.
  9. fletch62
    fletch62 Formula Junior
    Mar 8, 2004
    333
    Fairhope, AL
    Larry Fletcher
    That is not the fuel distributor, it is the air flow meter, the part the fuel distributor is bolted to.
    You need to contact me and I can go over the injection with you I have a pretty good idea the seals in the fuel distributor are going bad.
    Larry Fletcher
    CIS Flow Tech
    Gordo308, waymar and 308 milano like this.
