Some more pictures of the strip down stage. W Image Unavailable, Please Login Image Unavailable, Please Login
Hi. Motor and Gearbox out. Need to send off the ZF and Mark wants to rebuild the motor at the shop. Fairly big number attached to this exercise........ Image Unavailable, Please Login Image Unavailable, Please Login
Just posted the motor on the 81 which is out while the car gets painted. The 86 is still a labour. New suspension all in but for some reason the MIE front shock and spring set seems to sit very high? I have asked if this is an issue or if there is a fix for this. Seems strange though. Various missing bits being sorted out. I will admit being a bit discouraged at the cost so far. Wish I could do more of the fiddling myself. Ciao for now Image Unavailable, Please Login Image Unavailable, Please Login
Yes, I replaced them with a modified poly bushing from a 4wd supplier. I eliminated one of the reducer sleeves as the top and bottom have different diameter bolts... pretty simple really. Mine were collapsed and oblong reducing effective shock length by around 1.5 inches!
Would be interesting to see the photo of the rear of the engine noting the difference to the Automatic Trans Engine block. This engine block is supposed to be very different. Interesting cut outs on the trans bellhousing....
Hi I will arrange for some photos of the other side. I was unaware until recently that the motors are so different but only a manual motor will work on a manual car.
William, this is normal. The stock springs/shocks are underrated and the car sags under the weight of the engine. The set from MIE is uprated and designed to avoid the problem, but at the price of making the car look a bit funny from the side. Mine does the same, and has the same set of springs and shocks. Image Unavailable, Please Login
Hi William, I plan on changing my rear wheel bearings, mine are a bit on the loose side so I figured an ounce of prevention... Do you know the part number or where to source these bearings? Are they f.x. identical to XJ6 cars, since they share (apparently) the same suspension? Cheers, Thor
Had I known they were different I would have taken a few pictures while we had the transmission out. I do have a few, but they're not really ideal to show the rear of the engine as a whole to compare. Maybe the parts manual would have a diagram showing the difference? I'm quite surprised that they bothered to make two different blocks for such a low production volume. I do know that they modified the bell housing pattern to fit with the Torqueflite. Cheers, Thor
I had described this in a technical post to ZF and their reply was: "Dear Sir, I think the gear shift rail or the gear shift fork is broken. For maintenance und repairing please contact our sercvice station in GB" However, contacting ZF got a negative response for assistance as "they don't service them any more". Well the ZF is pictured out of the car but is off for repair. Wayne Lee has agreed to do this. He is from MST (Motorsport Transmissions) http://www.motorsporttransmissions.com/home He specialises in the ZF S5 18/3 but has the manuals etc and has rebuilt the ZF S5 24/3. He seems a reasonable chap on the phone and is doing some interesting work so we shall see. The other option was to ship it back to ZF but they were very uncommunicative. http://www.schiemenz.com/ Auto Schiemenz could work on the ZF but their email does not work, no one answers the phone that speaks English and I don't%2 Image Unavailable, Please Login
Google is your friend: http://translate.google.com/translate?sl=de&tl=en&js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fwww.schiemenz.com%2F&act=url (translate.google.com) Cheers, Thor
For some reason I lost some text so here is the end of my post. "Dear Sir, I think the gear shift rail or the gear shift fork is broken. For maintenance und repairing please contact our sercvice station in GB" However, contacting ZF got a negative response for assistance as "they don't service them any more". Well the ZF is pictured out of the car but is off for repair. Wayne Lee has agreed to do this. He is from MST (Motorsport Transmissions) http://www.motorsporttransmissions.com/home He specialises in the ZF S5 18/3 but has the manuals etc and has rebuilt the ZF S5 24/3. He seems a reasonable chap on the phone and is doing some interesting work so we shall see. The other option was to ship it back to ZF but they were very uncommunicative. http://www.schiemenz.com/ Auto Schiemenz could work on the ZF but their email does not work, no one answers the phone that speaks English and I don't want to risk shipping the ZF to Bonn and having any issues with communication. Another option was P&W Engineering Paley Workshop Arden Press Way Letchworth GC Herts SG6 1FR UK They could work on it and are Aston specialists. It seemed like money no object Aston restoration but they were uber professional and would be a perfect place to go. I liked the sound of Wayne on the phone and his estimate is reasonable and the process painless so lets see how it works out. He also agreed to do a photo disassembly etc so I can post it which I liked. Ciao for now
Well the long awaited day has arrived. The amazing piece of ZF kit is at MST without a hitch and they have immediately begun to strip it down. Here are some pics to start. No analysis yet. Ciao Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
if possible an engine side pic. of bell hsg. would be nice. The shift rail design is the same as a modern seven speed American truck transmission used in most medium size trucks.
What is the cure to the raised front end with the MIE kit? If you install the MIE rears will that level the car?
We are going to set up the suspension and run it a bit and see if it settles. The back looks perfect though. I did ask MIE but no response on a fix yet.
Mine has the MIE kit all around - front and rear. You can draw your own conclusions from the picture, but to my eyes it's about 1" too high in the front. It handles well, though. Thor
Hi I am putting this here also given the discussion. Front end weakness seems to be an issue. William, I think you might be best off with the MIE shocks. While the front suspension technically came from a QP III, it's true source appears to be the Pantera, a rear-mid-engine car with considerably less weight at the front. That suspension with it's coil-over shocks (dampers) was never meant to hold up half the weight of a QP III, with the engine sitting over the front axle center-line, all sitting on a couple of little rubber shock bushings. We have a set of US-made coil-overs by Vari-Shock on this car. They are machined from billet aluminum, are re-buildable and are externally adjustable for damping and ride height. They also come with a choice of urethane bushings or spherical bearings at the load bearing points. I'm not sure they would be suitable for the QP III. You would have to check with the manufacturer. On my roadster the bare chassis only weighs about 200 pounds and the engine sits very far back from the front axle center-line. The weight on the front shock bushings is considerably less than on a QP III. Thank you for your encouragement even though I'm not being very encouraging here.
Well it is fully stripped down and the good news is that all of the gears are solid. As Wayne predicted they are so well made that they show no wear at all. Lots of junk and very dirty. A real testament to the quality of engineering. He also can see why the issues were arising in the ZF which he also says is really good news as what you see you can fix. He has some of the parts required but it will need some bearings from ZF. The parts are all stamped with an S which he advises means they were only ZF made and special. More pictures shortly.
The difference in handling over stock cannot certainly be worth the slumped rear look....? So are the real shocks available from Masi still or am I stuck sorting out the MIE kit when my suspension needs fixing? I am certainly not buying an MIE kit until I know that the car will have proper ride height.... Dave Helms was even befuddled when I mentioned this to him this morning.
