News
1982 308 GTSi battery discharging
Discussion in 'Technical Q&A' started by seschroeder, Jul 9, 2004.
  1. seschroeder
    seschroeder Formula Junior
    Apr 25, 2002
    251
    Alexandria, VA
    Steve Schroeder
    Gentlemen:
    The battery on my 308 discharges after 10 days to 14 days of idleness. Had the battery checked and it was found to be good. I rather suspect that the diodes in the alternator are bad. Any secrets to having the bloody thing rebuild or taking it off the vehicle?? Owners manual say it is a Bosch 0.120.489 - 641 (55 Amp).
    As always, thanks in advance.
    Steve Schroeder
  3. milstanselnino
    milstanselnino Formula Junior
    Jan 8, 2004
    573
    MN
    Jon P.
    Are yiou sure the alternator is at fault? That's easy to test. My bet is on some other current drain: my Mondial would do that. Whan I checked, I found that the problem was not uncommon. Look for a light somewhere, or if you don't want to go through all that, a battery cut-off switch.
