1983 gtsi 12k | FerrariChat
1983 gtsi 12k
Discussion in '308/328' started by cantweight, Mar 21, 2006.
  1. cantweight
    cantweight Rookie
    Mar 21, 2006
    2
    I am thinking of purchasing a 1983 gtsi with 12k all original. What should I look for? The smog eqipment has been removed? Is that bad. The car looks brand new.
  2. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,176
    E ' ' '/ F
    Snike Fingersmith
    Where are you? Some places require all original smog equipment and check for it, others check tailpipe emissions only, others have no checks. The missing equipment could be expensive to replace if needed in your area.
    Check service records. Check to see when the timing belts and tensioners were replaced, whether the water pump was rebuilt, what other work has been done. An 83 GTSi may be a quattrovalve car, verify precisely what you're looking at because there's a price differential between the 80-82 GTSi and the 83-85 GTS QV. The 83 has some unique parts, there's a recent thread in this section about that.
    Check the condition of the seat bolsters and the pedals. The odometer is easy to disconnect on the car, so make sure the condition matches the mileage.
    If there's a local Fcar mechanic, have the car inspected
  3. cantweight
    cantweight Rookie
    Mar 21, 2006
    2
  4. BigAl
    BigAl F1 Veteran
    Mar 17, 2002
    6,146
    TX
    GSgt Hartman
    like Tillman said, it all depends on where you live or are going to live and whether or not they have emissions testing.
