1983 Mondial Cab conv top leak | FerrariChat
Discussion in 'Mondial' started by FF8929, Feb 27, 2009.
  1. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    #1 FF8929, Feb 27, 2009
    I have a serious water leak at the windshield header seal. Has anyone else had this problem? Will replacing the foam seal, attached to the windshield header, solve the problem, or does it also involve the mating part that is part of the top itself?
    Thanks in advance for your input.
  2. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,379
    Northern VA
    Dave W
    Do you adjust the thumb screws on the latches every time you put the top up? What I do is run the latch paddles all the way forward and latch the top. Then I release one latch, and back the adjuster to the stop and re-latch. Now do the other side. This is the only way I know to have a tight seal and still be able to latch the top.
    Dave
  3. FF8929
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    Thanks for the tip.
  4. FamilyCar
    FamilyCar Formula Junior
    655
    Seattle, Wa
    Peter Goodall
    I spoke to an upholsterer / top guy a while ago about a similar issue: my top doesn't appear to come seat as far forwards as I think it should. He told me that they can often re-stitch the leading edge of the roof to give it a bit more length.
    I haven't done anything about it, since it doesn't actually seem to leak there--as opposed to all the water that dumps in when I open the door. Just a thought if you want to try that route. I also walk the top forward tightening the screws from side to side, and have replaced the toggles with the unbreakable ones available on eBay from another Fchatter.
  5. ronfrohock
    ronfrohock F1 Rookie
    3,919
    MA
    Ron Frohock
    Thanks for the mention......
    I havent posted them on EBay for a while now as the demand had dropped off. I cant say they will help with the leak, but they will not break.
    Please let me know if anyone wants a pair.
    - Ron Frohock
  6. FF8929
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    Upon closer inspection, I see that my 83 Mondial does not have the adjustable fasteners. It looks to me like the only fix is to replace the rubber seal at the top of the windshield header. $$$$$
  7. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,379
    Northern VA
    Dave W
    #7 davebdave, Mar 14, 2009
    I didn't realise there was a difference. To confirm, here is a picture of the latch and thumb screw on our '92.
    P.S. You can also see Ron's must have toggle (arm) installed on the latch.
    dave
  8. FF8929
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    #8 FF8929, Mar 14, 2009
    Nope, no adj. bolt. But, thanks anyway.
  9. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,379
    Northern VA
    Dave W
    I don't know early Mondials but those look like Alfa Romeo latches to me. I have heard that some people have used them instead of the $600 ferrari latch. Perhaps someone with an '83 or earlier can confirm.
    Dave
  10. FF8929
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    Your right!!! Good eye. I just took the latch off my 78 Alfa Spider, put the two side by side, and but for color and the leather strap, they're exactly the same. From the parts illustration, I believe that what I have is original for 1983. Doesn't help my leak, but the interchangability could sure save a lot of money!
  11. sonfield
    sonfield Karting
    Jul 17, 2008
    100
    Florence, SC
    my entire latch needs replacing..does anyone know of any better deal than $500-700 through parts dealers?
  12. Max4HD
    Max4HD Formula 3
    Jun 20, 2006
    1,042
    Florida
    Post #5 above.
    Buy them, even if yours have not broken yet - they eventually will.
    Cheers
  13. dakharris
    dakharris Two Time F1 World Champ
    Jun 7, 2001
    29,441
    Sleepy Hollow
    Cavaliere Senzatesta
    Don't drive your car in the rain and the problem will be solved.
  14. CFCARRIAGE
    CFCARRIAGE Formula Junior
    Jun 9, 2006
    598
    Missouri
    Dave
    I have the same issue with my 89. Like DAK said don't drive in the rain. I got caught by a sudden out of no where deluge this summer and was drivin with a sham wow cloth soakin it all up. Keep a good absorbant cloth under the seat. I have considered the top replacement, as over 20 years the top had shrunk slightly but just enough to create small irritations. +1 on Ron's toggles.
    Dave
  15. FF8929
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    Well, I guess I've just got to roll the dice and order the seal. For the cost of this thing, it better work and it should install itself!
  16. FamilyCar
    655
    Seattle, Wa
    Peter Goodall
    Well, as I noted earlier, have you checked with a shop to see if the front edge of the roof can be re-stitched. That might make up for shrinkage and give it the add length to move forward all the way against the seal. It sounds as if that seal is an expensive one, and it's condition doesn't matter if the top doesn't meet it properly. I didn't get the impression that re-stitching the front bow was too complicated, perhaps a few hours work. Just another avenue. Good luck.
  17. FF8929
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    The seal ($400.) is original and quite compressed and the top is newer, so I don't think that's the problem. But I do appreciate the suggestion.
