1985 308 GTSi QV questions. | FerrariChat
Discussion in '308/328' started by Tifosi2011, Apr 12, 2011.
  1. Tifosi2011
    Tifosi2011 Formula Junior
    Apr 3, 2011
    307
    Burnaby, BC Canada
    Can anyone recommend what brand and type of oil I should be using on my 1985 308GTSi QV? I've heard that synthetic oils could damage critical seals and such. And also, what brand/type of gear oil is prefered? I live in Vancouver Canada if that helps in your recommendations. Thanks to everyone who will reply. It is much appreciated. Go Canucks!
  2. irondogmike
    irondogmike F1 Rookie
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    I had a 85 qv,I used nothing but redline,I've never had leaks but then it you do its time for new gaskets,simple as that,If you drive the car often enough and mantain it ,it should never have leaks
  3. Dr Tommy Cosgrove
    35,338
    Birmingham, AL
    Tommy
    Synthetic oil doesn't damage seals.
  4. Crallscars
    Crallscars F1 Rookie
    Jun 7, 2006
    2,512
    Bainbridge, GA
    Douglas Crall
    Hay Tommy, not oil or seal related, I sent you an request on Linked In
  5. 4re308
    4re308 F1 Rookie
    Jun 13, 2001
    4,813
    Woodstock, GA
    Mitch D
    I use Valvoline Racing 20w/50 in the car. I too have heard not to use synthetics in that engine. Nothing wrong with good ole Dino oil.
  6. ckracing
    ckracing Formula Junior
    May 20, 2006
    728
    Jacksonville,Florida
    Charles
    I use Shell Rotella 15-40. I have a 84 308 GTS with 80,000 miles.
    Previous owners used Castrol and Mobil 1
  7. Tifosi2011
    Apr 3, 2011
    307
    Burnaby, BC Canada
    Thanks for the input everyone. I'm still trying to figure out where I can purchase these oil brands locally that everyone so far has mentioned.
  8. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,172
    NYC, USA
    Phil
    You'll probably find in your owner's manual that the recommended oil is AGIP Sint 2000, which is a synthetic oil.
  9. Tifosi2011
    Apr 3, 2011
    307
    Burnaby, BC Canada
    Good point.
  10. 4re308
    4re308 F1 Rookie
    Jun 13, 2001
    4,813
    Woodstock, GA
    Mitch D
    X2!
  11. thecarreaper
    thecarreaper F1 World Champ
    17,583
    Savannah
    Redline 10-40 and Redline 75-90NS gear oil. Buy it on Amazon.
  12. Jeff Kennedy
    Jeff Kennedy F1 Veteran
    Oct 16, 2007
    6,577
    Edwardsville, IL
    Jeff Kennedy
    That is what is in Prugna. After ready some long threads here on F-Chat that is what I with went originally and have stayed with. Also use Water Wetter.
    Last time I bought I used a supplier that advertised in the FCA newsletter.
    Jeff
  13. sindo308qv
    sindo308qv F1 Rookie
    Nov 1, 2003
    3,575
    miami.fl.
    sindo
    Valvoline racing oil is what was used on my 308.
  14. Peter
    Peter F1 Veteran
    6,430
    B.C., Canada
    I've been running Mobil 1 20W50 V-Twin which is a high zinc/phosphorous motorcycle oil. This is a hot topic, because many new oils have less and less of those additives, which could cause valvetrain damage. I'm sure this is most critical with a brand new engine where the parts need to wear together, but on a well-used motor?... I suppose it can't hurt.
    Although I've found that the 20 weight makes for a sluggish cold starting idle. Never had issues like that when I ran Castrol Syntec 5W50. But since the Syntec is now an "SM" rated oil (may even be "SN" now), I wouldn't use it because of the lower ZDDP levels.
    I'll be running Motul 5100 10W50 semi-synthetic motorcycle oil for this upcoming oil change. This is as close to the original Agip SINT 10W50 spec as I can determine. I really would have liked to use Silkolene Pro 4 Plus full-synthetic 10W50, but unfortunately, it isn't available in Canada (unless I bring it across from Washington state, or have it shipped by mail...).
  15. captglen
    captglen Formula 3
    1,790
    West Palm Beach, Fl
    Glenn L.
    When I had my 85 308QV, I used Royal Purple and Redline Gear Oil. My mechanic who happened to be the NA rep for Ferrari uses this stuff. He is on here under FerrariDR. He would be a good one to answer this. Good Luck
  16. thecarreaper
    17,583
    Savannah
    I add a can of BG MOA for the zinc and i swear a thinner oil makes a difference I can feel.
  17. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,689
    Mike 996
    Use the oil that is recommended in the owners manual. Agonizing over "the best oil" is a total waste of time.
  18. Tifosi2011
    Apr 3, 2011
    307
    Burnaby, BC Canada
    Sounds good to me. I'll certainly do just that.
  19. magnum
    magnum Formula Junior
    Feb 21, 2008
    877
    Barcelona, Spain
    Antonio
    I'm using Esso Ultra 10w40 for road use and everything is fine. I prefer to have a "fast" oil in warm up -10 instead of 20-, and a 40 grade at high temp. I don't need the 50 grade -I'm using the car gently, not on track-.
