News
1985 Testarossa throttle sticking
Discussion in 'Boxers/TR/M' started by Flyyellow, Mar 27, 2005.
  1. Flyyellow
    Flyyellow Rookie
    Mar 12, 2005
    3
    Oregon
    glenn e wickstrom
    I have had the throttle cable replaced by my Ferrari mech. twice. It seems to stick at low speeds and at idle. 1,500/2000 RPM. Upon feathering the gas pedal, it returns to normal. I notice that when the gas pedal is first depressed, it seems to hang up a bit but never at high speeds. Help! Any advise anyone? thanks Glenn
  3. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,242
    Could be a problem with the cable or the pedal linkage - some of the F-cars have quite intricate linkages behind the gas pedal I believe. Has any major work been done that necessitated the removal of the cable in any way? If so was it routed correctly when re-installed?
    Could also be some kind of idle valve issue with the injection system. Suggest you seek out a man who really knows about the thing!
    I.
  4. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    TRossas have a fiddly little bracket to pass the cable through, that's buried down in between the metering units and water pipes.
    It's an absolute 8itch to pull the cable through... so much so I have made a special tool for exactly that purpose.
    Triple check your cable passes through the hole correctly.
    Then also, re-check all around the floor section near the pedal and behind the centre console part.
    Also check that you are actually getting full throttle... and just as importantly, that you are not stretching the cable by going beyond full throttle due to poor adjustment... as this is why cables break in the first place.
  5. slm
    slm F1 Rookie
    Rossa Subscribed Owner
    Dec 5, 2004
    2,931
    Ozark Americana
    Steve M
    Something very simple to consider. Those of us with floor mats that go over the original mats tend to creep forward push on the lower part of the throttle platen and cause it to stay open slightly, especialy as you describe. Try pulling the mats back or taking them out. I believe this is the most common problem for what you are describing.
  6. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,336
    Alabama (was Mich.)
    Jeff
    I would also verify that the throttle plates have the proper clearance. I had an occassional "sticking" situation when I let off the gas...the throttle wouldn't return to rest....the car would idle a few hundred rpm high. But if I let the throttle snap back....all would be fine. It was only after an easy let off that it would stick. I had to regap the right side throttle plate. Oh yeah....and the floor mat issue...yep...happened to me too !
  8. stevetr
    stevetr Formula Junior
    Sep 29, 2003
    379
    Surrey, UK
    Stephen
    This has caught me out too. As has been said, it's normally just the floor mat sliding forward! Really, it may be that simple!
  9. slm
    slm F1 Rookie
    Dec 5, 2004
    2,931
    Ozark Americana
    Steve M
    This problem has been posted a number of times on the FCA technical section and every time Bill B has recommended checking the floor mats and I believe they have always been the culprit. I know I have to intentionally pull my mats back a few times during a long drive. Certainly not the only potential problem, but by for the most common. Also happens a lot with the 328.
  10. PerryJ
    PerryJ Formula 3
    Jun 5, 2003
    1,909
    N. Alabama
    John Perry
    I just had this problem on my 308, mine was the valve just inside where the hose connects to the manifold.
    i little carb cleaner fixed mine.
