1987 328 gts resurrection | Page 10 | FerrariChat
Discussion in '308/328' started by 87we410877, Aug 21, 2022.
  1. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,339
    Dumpster Fire #31
    SMG
    Reading back a couple pages, you could very likely still be fighting an electrical issue. Anything from a glitchy ignition switch to relay kicking off the fuel pump or ignition circuit. We're you able to sort out the cut up harness etc?
  2. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,856
    Atlanta
    John!
    Yeah what’s the deal with compression and leakdown for this thing.
    also, where is the fuel pump grounding? Can’t stress having good grounds enough
  3. 87we410877
    87we410877 Karting
    Jan 23, 2022
    170
    Dallas Texas
    Tyler eucalyptus
    I have tried propping the flap open slightly same / worse result. Also tried with the plug off. Same result. The car has not run since 2006. I’ve gone through the whole engine, timing belts, valve adjustment etc etc. compression numbers are good. One cylinder was a bit low, so i sprayed some wd40 and tested it again and it came up from 90 to 130. Like you said, it’s cold and been sitting for a long time. I don’t think compression is the issue. Also, filled each cylinder with marvel mystery at bottom dead center and let each one sit for 24 hours.
  4. 87we410877
    87we410877 Karting
    Jan 23, 2022
    170
    Dallas Texas
    Tyler eucalyptus
    yes, the alarm and radio junk is all out of the car now. Everything is now back to original and checks out. It runs perfect for 2-3 seconds. Revs up and everything.
    I’ll get a CIS fuel pressure tester and see what’s happening while cranking and running for that short time. Seems like the fuel pressure is bleeding off.
    y
  5. 87we410877
    87we410877 Karting
    Jan 23, 2022
    170
    Dallas Texas
    Tyler eucalyptus
    compression is as follows. This is cold and after sitting and not running for 20 years. As you can see, #1 came way up with just some wd40 in the cylinder and rechecking.
    steved033 likes this.
  6. Freddie328
    Freddie328 Formula Junior
    Jul 29, 2013
    391
    Herts, UK
    Richard
    Did you have the throttle open?
  7. 87we410877
    87we410877 Karting
    Jan 23, 2022
    170
    Dallas Texas
    Tyler eucalyptus
    Sometimes. Itll rev up no problem to 6k rpms. Sounds great. Then shuts off. Same result if I let it idle or wack the throttle. I get 3 seconds out of it
  8. 87we410877
    87we410877 Karting
    Jan 23, 2022
    170
    Dallas Texas
    Tyler eucalyptus
    It’s going to be a few weeks before I can get back at it. Dropped the coils on the ground and broke one. Have to wait for the new one from superperformance. Also change the hoses at the radiator and get some coolant in it to eliminate that “possibility”
    mixedgas likes this.
  9. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,339
    Dumpster Fire #31
    SMG
    He's referring to when doing the comp test, throttle is held wide open. Fuel pump and ignition off/disabled.
    You've got enough compression for it run at least.
    The cutout could very likely be electrical. CIS is very basic, it'll run without any ECU to control it. The various sensors are to fine tune it and control the closed loop operation.
    So either you've got very weird control pressures in the lower chamber, fuel pump is cutting out or ignition is being cut. Two of those point to electrical.
    Or is flooding.
    Get a CIS test setup to check the control pressures and main pump pressure. Also run a 40sec or 1min pump flow rate as well.
    87we410877 likes this.
  10. 87we410877
    87we410877 Karting
    Jan 23, 2022
    170
    Dallas Texas
    Tyler eucalyptus
    thanks for the info. Fuel pressure test will be first on the list. As for the throttle open, I would say yes, considering there was no intake on the motor at all.
  11. 87we410877
    87we410877 Karting
    Jan 23, 2022
    170
    Dallas Texas
    Tyler eucalyptus
    Ok. Fuel pressure is 32 psi with the engine off, cold, key on, blue plug unplugged pump running. Steady. Plug it back in (pump off) goes up to 42 lbs. Start the engine, fuel pressure stays steady at 32 psi either at idle or revving it up. Once it dies after 3 seconds, back up to 42. Still won’t run for more than 3 seconds.
    Made myself this adapter with a schrader valve brazed onto the banjo fitting so I have a place to take fuel pressure any time. Cleaned up the coil bracket and reinstalled all that. I’m stuck. Don’t know where to go from here.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  12. mixedgas
    mixedgas Formula Junior
    275
    Ramona, CA
    Could that fuel sock in post 61 be restricting flow? Just a WAG. I'm no expert in k jet.
  13. 87we410877
    87we410877 Karting
    Jan 23, 2022
    170
    Dallas Texas
    Tyler eucalyptus
    I doubt it. That's what its made for. Good suggestion though.
  14. 87we410877
    87we410877 Karting
    Jan 23, 2022
    170
    Dallas Texas
    Tyler eucalyptus
    On second thought, I cant think of anything else starving this thing. I'll start there, try running it without the sock, then move on down the line. Runs like something that needs a good carb cleaning. Soon as you take it off choke it dies no matter how much fuel you give it. Seems once the accumulator gets exhausted, its starving. If that's how that even works. I don't know.
  15. 87we410877
    87we410877 Karting
    Jan 23, 2022
    170
    Dallas Texas
    Tyler eucalyptus
    Drained the fuel, removed the sock, reinstalled the pickup tube with nothing on it, filled with gas; same result. Still won’t stay running. That’s one more thing eliminated.
  16. 87we410877
    87we410877 Karting
    Jan 23, 2022
    170
    Dallas Texas
    Tyler eucalyptus
    Moved on to other things since I cannot figure out why it won’t run.
    Connected all the cut wires at the two plugs under the dash by the drivers left knee. (Red and white plugs) there were several cut wires. Now, with the key off and out of the ignition, I have the oil pressure light on, the door buzzer going (door open or closed) and the tach pegged at 10k rpm and fluctuates with the scratchy sound of the door buzzer. Put the key in and turn to on position, tach goes to 0, door buzzer goes off. Car still doesn’t run more than 2-3 seconds.
  17. 87we410877
    87we410877 Karting
    Jan 23, 2022
    170
    Dallas Texas
    Tyler eucalyptus
  18. 87we410877
    87we410877 Karting
    Jan 23, 2022
    170
    Dallas Texas
    Tyler eucalyptus
    Still cannot get the car to run so i have been working on rebuilding the broken switches and missing items in the center consol. I wanted to put this here for anyone doing a google search. The 328 GTS hazard switch nut and washer was impossible to locate so i went to ebay and bought one that looked exact. Usually thats a fail, but this time it worked out well!!! Below is what i bought. I guess the BMW E10 2002 shares a similar switch. Here are some before and after pics.
    rwbolt1 likes this.
  19. 87we410877
    87we410877 Karting
    Jan 23, 2022
    170
    Dallas Texas
    Tyler eucalyptus
    Before. After to come later tonight. Still need to cut the ac switch post down so the knob will fit on. If anyone is looking for any small plastic parts like knobs and such, check out the Unobtanium. They’re awesome.
  20. 87we410877
    87we410877 Karting
    Jan 23, 2022
    170
    Dallas Texas
    Tyler eucalyptus
    Zenobie likes this.
  21. 87we410877
    87we410877 Karting
    Jan 23, 2022
    170
    Dallas Texas
    Tyler eucalyptus
    Before I go gluing and screwing this thing back together, has there been any updates on these heater valves? Everything I search is from years ago. Hoping this $12 part has finally been reproduced and I don’t have to pay $400. I don’t want one I have to modify, and I don’t want a used one. Let me know! Part number 126324
  22. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,674
    Argent/Brasil
    Guido
    Impossible to find a new one. And used almost all the time are full of crab and leaking.
    Here you find how to repair those = see #10
    https://www.ferrarichat.com/forum/threads/heater-valve.601331/#post-148778025
  23. 87we410877
    87we410877 Karting
    Jan 23, 2022
    170
    Dallas Texas
    Tyler eucalyptus
    Thank you. Im going to try the screw solution before i cut it in half. We'll see how that works. But, 2 part high temp JB weld epoxy was the way i was leaning. Thanks again! Yours still not leaking?
  24. theunissenguido
    Jan 21, 2004
    2,674
    Argent/Brasil
    Guido
    Until now not leaking....but for security put a cup under that valve ! :p
  25. 87we410877
    87we410877 Karting
    Jan 23, 2022
    170
    Dallas Texas
    Tyler eucalyptus
    HAHA got it. Cup under the valve, rags under the cam seals. Gotta love it! Thanks again.
