1987 328 gts resurrection | Page 13 | FerrariChat
Discussion in '308/328' started by 87we410877, Aug 21, 2022.
  1. 87we410877
    87we410877 Karting
    Jan 23, 2022
    182
    Dallas Texas
    Tyler eucalyptus
    Thanks. I'm done. Done wasting time, money and throwing parts at this thing. I'll be contacting the experts. If they want to throw parts and money at it too, it'll be for sale that day. 3 years cant get this thing going. Im done. With two kids under 2, its impossible to have a minute to do anything. Let alone just keep wasting time (Years) on things that do not improve the condition. Again, it does run above 3,000 RPM's. Which makes 0 sense.
  2. 87we410877
    87we410877 Karting
    Jan 23, 2022
    182
    Dallas Texas
    Tyler eucalyptus
    Do you happen to have a part number or link? All the threads I found in here won’t pull up. There has to be one for a reasonable price other than the one for $1800 on eBay. Thinking about changing the switch.
    now, the fuel pump won’t come on even with the blue plug disconnected. Pump was tested direct and still good. Relay and fuse is good. Not sure if the circuit goes through the ignition switch? Worth a try. Not for $1800 though. Or even $500
  3. Steve Magnusson
    26,946
  4. mixedgas
    mixedgas Formula Junior
    Apr 23, 2019
    293
    Ramona, CA
    Is a BMW part, ill post a link tomorrow
    87we410877 likes this.
  5. mixedgas
    Apr 23, 2019
    293
    Ramona, CA
    Hi there, I noticed my engine was running strong at start and dying immediately after - seemed to happen to suddenly to be fuel related IMO (i.e. I assumed was an electrical issue). I noticed it died when I released the key from 'start' to 'run' position. It was on my list to troubleshoot further but then I also noticed my ignition was 'notchy' and the key would jam trying to turn to 'start' position - on a desperate whim I decided to replace the electrical portion of the ignition switch with the goal of addressing the notchy action of my key.
    I crawled under the dash and swapped out the electrical portion of the switch in-situ and was delighted that the car fired right up and continued to run. Unfortunately it did not fix the notchy feel of the key, but I'll deal with that later.
    Now I of course can't promise this will fix your run issue, nor if the 328 uses the same ignition switch electrical parts ( I think it does - maybe search this forum for the part number below), but I found a thread somewhere on here indicating that Ferrari and BMW (2002 maybe?) use the same ignition electrical switch. FCP Euro had one and the price was competitive.
    Apparently there are inexpensive generic versions, and better OEM versions available for BMW, I went with genuine.
    BMW Switch - Genuine BMW 61312682120
    Apparently this is Ferrari part number 70000707 and a quick search indicates AW Italian might be able to rebuild these? Nevertheless I would not throw out the old one.
    Hope this helps.
    -Mike
  6. 87we410877
    87we410877 Karting
    Jan 23, 2022
    182
    Dallas Texas
    Tyler eucalyptus
    you’re the man. Thank you. This is the next step.
    both relays and the connection at the passenger foot well are good.
  7. 87we410877
    87we410877 Karting
    Jan 23, 2022
    182
    Dallas Texas
    Tyler eucalyptus
    ZikZak, mixedgas and rwbolt1 like this.
  8. 87we410877
    87we410877 Karting
    Jan 23, 2022
    182
    Dallas Texas
    Tyler eucalyptus
    subnet67, Zenobie, rwbolt1 and 2 others like this.
  9. 87we410877
    87we410877 Karting
    Jan 23, 2022
    182
    Dallas Texas
    Tyler eucalyptus
    New ignition switch in. Still no pump, no start no run. Yayyyy
  10. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,757
    Argent/Brasil
    Guido
  11. 87we410877
    87we410877 Karting
    Jan 23, 2022
    182
    Dallas Texas
    Tyler eucalyptus
    they are correct. Used to at least have fuel pump. Just no continuous running. Now I have neither
  12. theunissenguido
    Jan 21, 2004
    2,757
    Argent/Brasil
    Guido
    Ground connection between engine and chassis ?Did you try a direct connection with a wire between engine and ground battery ?
  13. mixedgas
    Apr 23, 2019
    293
    Ramona, CA
    I'm of course disappointed to hear the ignition switch didn't solve your issue and I hope there are no hard feelings. On the brightside you now have a new ignition switch which should last another 40 years.
    Have you tried hot-wiring the fuel pump (putting 12V directly to the pump with a jumper wire)?
  14. versamil
    versamil Formula 3
    1,248
    Gaston, Oregon
    Brian Healy
    Hate to rain on your parade, I read your first post, and here we are 13 pages later. Burglar alarms that kids installed in the eighties. wired by someone who probably doesn't have a schematic, are a source of grief later in life. BUT if your fuel pump is dead, the electrical schematic is your best friend and this is basic electrical troubleshooting.
    Steve's link is right on the money. Make a jumper and plug it into the fuel pump relay and your fuel pump should be on- period. Terminals 30 and 87. Flip the relay upside down to figure out which terminals to jumper from. If the pump doesn't come on, ASSUME you have the terrific wiring diagram book, look at it and analyze where the fuel pump gets its voltage to run from. Almost DIRECT from the battery going through the fuse and to the relay. The ignition switch turns on Relay ":U" directly above the fuel pump relay, which powers the primary side of other relays. Terminal 30 on the fuel pump relay, comes from fuse 20 and should be HOT at all times. Check that it is with a voltmeter. Terminal 87 goes to the fuel pump, but goes through two terminals- if the fuel pump is not running and you have POWER to terminal 87, one of these connectors is probably bad. Not rocket science.
    Throwing parts at problems is NOT the smart way to solve problems. Sometimes this is why it's better to just take your car to an experienced mechanic. Experienced mechanics, don't change parts, they troubleshoot and solve the problem. When I ran my shop, I LOVED electrical problems.
    Not reading all of your posts, I don't know what the burglar alarm installation controlled. Did it disable the car and have an alarm? If it was able to disable the car, HOW did they accomplish that? Lots of ways to do this, but you can't willy- nilly just unhook wires and figure all is well. You seem to be chasing your tail.
    I have FOUR 328's so I have samples to look at if necessary. One which I purchased recently has a Clifford alarm that I am going to remove. LOTS of extra JUNK under the dash.
    JL350 likes this.
  15. 87we410877
    87we410877 Karting
    Jan 23, 2022
    182
    Dallas Texas
    Tyler eucalyptus
    yes. Pump comes on. Pump also comes on when jumping out the fuel pump relay, but the blue plug disconnected, still does not .
  16. 87we410877
    87we410877 Karting
    Jan 23, 2022
    182
    Dallas Texas
    Tyler eucalyptus
    I’ll check this out. Thank you. I did jump the fuel pump relay and the pump ran so there’s that. I don’t know what the alarm controlled since nothing worked. I took it all out and repaired anything that was tied into the factory plugs / harness. Fuel pump worked the last time I went out, now it doesn’t. Do the alarm is not the issue it’s been out for two years almost now. I hate electrical with a passion. I’ll be contacting a professional as soon as the seats are back in. I’m done chasing this problem and like you said, throwing parts at it.
  17. Steve Magnusson
    26,946
    Try a different ...101 relay in the "Fuel Injection Delivery Pump Starting-Relay" (Relay S) position, plug the fuel pump relay back in, and retest with the blue plug (safety switch) disconnected.
  18. versamil
    versamil Formula 3
    1,248
    Gaston, Oregon
    Brian Healy
    Don't be disheartened. If jumpering the fuel pump relay makes the fuel pump come on, you've eliminated HALF of your circuit, It means from terminal 87 to the fuel pump- you're good. Does everything else in the car function electrically- any other dead components? Jumpering the fuel pump, does the car start and run- it should? Using a voltmeter check for voltage from terminal 30 to terminal 86. This is checking that the pump relay has a good ground on the draw in coil circuit. Your voltmeter should read battery voltage, even with ignition off. Just for grins, put a jumper in relay U terminal 30 and 87. relay U is directly above the fuel pump relay. Try starting the car.
    Check with a voltmeter that you have battery voltage at terminal 30 and terminal 86 on relay "U". 86 is the ground for the draw in coil- same ground that's used for the fuel pump relay terminal 86. A few voltage checks take seconds to do, and it eliminates a lot of head scratching and guessing.
    Your fuel pump relay gets it's ON voltage from Relay S from terminal 30. If you remove relay "S" and just apply voltage to terminal 30 on the board- your fuel pump relay should turn on and the fuel pump should run. Doing this gets one more part checked out and eliminated. I guess if you did this FIRST, and the fuel pump turns on, that means the GROUND for relays U and R is good. We're just logically blasting through the circuit at this point. While you have relay S out, check voltages at terminals 86 and 87A, they should BOTH have battery voltage. Terminal 87 is hot with the ignition on. This relay operates by the switch in the air flow meter providing the ground to the draw in coil via terminal 85.
    Do these checks and you're running out of possibilities and you have a GOOD chance of finding out what's wrong. This is electricity 101 compared to so many newer cars with computers. If I was installing a burglar alarm on one of these cars- I would be using a relay or switch right in this circuit to disable the car. You won't see it at the relays, but with work at terminal block "W" I AM NOT looking at my cars for this information, this is just analyzing the schematic. I regularly trouble shoot machine tools that have electrical cabinets with 100's of motor starters ( relays), timers, transformers. Electrical cabinets that are huge weighing over a thousand pounds. So these cars, are kind of simple at this point.
    Unlike high quality electrical cabinets in machine tools that use SCREW in terminals and terminal blocks, car manufacturers unfortunately use lots of plug in connectors. Terminals that rely on spring tension don't work very well after thirty years of relatively high amperage, heating them up and the metal fatiguing. So we're trying to FIND that possibly weak connector, that you're fortunate enough to have NOT working while your car is conveniently in your shop. There's an UPSIDE to everything.
  19. 87we410877
    87we410877 Karting
    Jan 23, 2022
    182
    Dallas Texas
    Tyler eucalyptus
    I’ve done this. No change.
  20. 87we410877
    87we410877 Karting
    Jan 23, 2022
    182
    Dallas Texas
    Tyler eucalyptus
    I’ll have to print this all out and make notes as I go. Thank you!!! I did jump the relay above the fuel pump already and that did nothing. With the fuel pump running while relay jumped out, the car does what it’s been doing for the last year. Starts, runs for 3 seconds, shuts off.
    I’ll check all this out and report back. Thanks again sir!!
  21. Steve Magnusson
    26,946
    Try this same test with a different ...113 relay in the "key controlled services relay" (relay U) position. Do your electric windows work (before trying a different relay U)?
  22. 87we410877
    87we410877 Karting
    Jan 23, 2022
    182
    Dallas Texas
    Tyler eucalyptus
    yes windows, lights, horn everything works. Oil pressure buzzer buzzes with the battery hooked up regardless of key position, and the tack goes to 8-9k and bounces around. Turn the key one position, and buzzer stops as does the tach. That’s the only other odd electrical thing happening.
  23. versamil
    versamil Formula 3
    1,248
    Gaston, Oregon
    Brian Healy
    Interesting that your car runs for three seconds and shuts off, WITH the fuel pump relay bypassed. You STILL need to make the checks outlined above, to try and determine WHY your fuel pump is not turning on without the jumper. Steve's suggestion on the "U" relay is good but if jumping it doesn't change anything, you still have to check out the voltages and grounds.
    While you MAY think you've removed the burglar alarm wiring- who KNOWS where and what they did to immobilize the car. The car HAS to run if it has spark and fuel, and if one of those disappears, it's going to die. You have to ascertain which one of the two is getting turned off. Applying a HOT wire to terminal 30 of the relay "S" with the relay removed, is a very revealing test- do it. The other two relays need to be plugged in.
  24. 87we410877
    87we410877 Karting
    Jan 23, 2022
    182
    Dallas Texas
    Tyler eucalyptus
    if you read back a bit, when the pump was coming on just fine, fuel pressure and spark remain while cranking, running, and when it shuts off. Plugs are soaked with fuel. It seems like it’s gettin too much fuel. Not the other way around. But I’m two steps back now just trying to get the GD pump to work again. I’ll get out there when I can and troubleshoot everything mentioned above. Thanks again.
  25. 87we410877
    87we410877 Karting
    Jan 23, 2022
    182
    Dallas Texas
    Tyler eucalyptus
    Ok here we go.
    Let me preface this by saying i took the plug out of the left side of the fuse / relay box and saw the one brown wire kind of burnt, and the plastic missing around the pin, I adjusted it and moved on. I think that was my problem, and ide like to fix it (See end of post)
    ALL TESTING WAS DONE WITH THE KEY IN THE ON POSITION ,ONE AWAY FROM CRANKING.
    Ok here we go.
    Yes, jumping 30 to 87 on Relay "R" Relay for Fuel Pump, the pump runs.
    No, Car still runs for 3 seconds and then shuts off.
    0 Volts
    Yes, Car starts. Shuts right off as it has been doing. But runs.
    Check with a voltmeter that you have battery voltage at terminal 30 (YES) and terminal 86 (NO) on relay "U". 86 is the ground for the draw in coil- same ground that's used for the fuel pump relay terminal 86. A few voltage checks take seconds to do, and it eliminates a lot of head scratching and guessing.
    When i did this, the car cranked over all by itself.
    Yes. Battery voltage at both 86 and 87A on relay "S"
    Also, when i take the blue plug off at the CIS, the fuel pump runs as it should. I do think that brown wire / plug was my issue. Where if at all, can i find this plug and pins to re-pin the entire plug? The only terminal that looks bad is the brown wire one. There is grease or dielectric all over it that someone put there which makes the plug look worse than it really is. Still looking at turning this over to someone else at this point however.
