1987 328 gts resurrection | Page 6 | FerrariChat
Discussion in '308/328' started by 87we410877, Aug 21, 2022.
  1. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    196
    Boerne, TX
    Rodney Bolt
    Looking fantastic! What are you using to clean your parts? A lot of elbow grease and what else?
  2. 87we410877
    87we410877 Karting
    Jan 23, 2022
    155
    Dallas Texas
    Tyler eucalyptus
    Usually brake cleaner and a brush, then either aluminum brightener and a brush and hose off or a very light (fine) glass bead. Rinse off and then I coat them with a trim detainer and a clean paint brush (trim cleaner listed above) . Thanks!!
    rwbolt1 likes this.
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,435
    San Carlos, CA
    Mitchell Le
    Who is selling those coolant tank stickers now?
  4. yelcab
    Nov 29, 2001
    13,435
    San Carlos, CA
    Mitchell Le
    While we are at it, you gonna sand off the red wrinkle paint on the letters on top of the plenum?
  5. 87we410877
    87we410877 Karting
    Jan 23, 2022
    155
    Dallas Texas
    Tyler eucalyptus
  6. 87we410877
    87we410877 Karting
    Jan 23, 2022
    155
    Dallas Texas
    Tyler eucalyptus
    I didn't plan on it. Its not wrinkle paint. I believe the 308 had wrinkle paint. Not the 328. Damn. I just looked at my pics and noticed they aren't painted originally. Hmmmmm. This is how it was so, someone must have re-painted this at some point. Yea. I'll probably sand them down.
  7. LostAussie
    LostAussie Formula Junior
    Jun 13, 2013
    713
    Piemonte
    Stuart
    Where did you get the elbow hoses? the last time I checked they were NLA and I'd love to pick a couple of them up.
  8. yelcab
    Nov 29, 2001
    13,435
    San Carlos, CA
    Mitchell Le
    Got news for you, the original 328 plenum has red and silver wrinkle paint ..
  9. 87we410877
    87we410877 Karting
    Jan 23, 2022
    155
    Dallas Texas
    Tyler eucalyptus
    Silver I can see. I've looked at 100's of pics I could find online, the red does not look like wrinkle paint. Nice and glossy in every pic. Mine will be staying as is regardless. Its far from a concourse car.
  10. 87we410877
    87we410877 Karting
    Jan 23, 2022
    155
    Dallas Texas
    Tyler eucalyptus
    I just go to the auto store and match them up to something they have, and cut the 90 out of it.
  11. yelcab
    Nov 29, 2001
    13,435
    San Carlos, CA
    Mitchell Le
  12. Rifledriver
    36,842
    The factory painted every single one wrinkle red and wrinkle silver.
  13. 87we410877
    87we410877 Karting
    Jan 23, 2022
    155
    Dallas Texas
    Tyler eucalyptus
    #139 87we410877, May 3, 2024
  14. 87we410877
    87we410877 Karting
    Jan 23, 2022
    155
    Dallas Texas
    Tyler eucalyptus
    Sooooo. Went out to the garage today and there was a bunch of oil on the ground under the ac compressor. It’s coming from the compressor by the lower of the two mounting bolts from the bottom bracket. One bolt is longer than the other. I’m guessing I put the wrong one it and compromised the compressor casing. I’m assuming it’s F’d and I need a new one? Any links to one that is a 100% direct replacement?
  15. Dockboy
    Dockboy Formula Junior
    561
    Maryland
    R12 or R134a?
    Here is what I used for R134a
    https://www.amazon.com/gp/product/B00SLKC2MU/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1
    87we410877 likes this.
  16. 87we410877
    87we410877 Karting
    Jan 23, 2022
    155
    Dallas Texas
    Tyler eucalyptus
    Need some vacuum help. The solenoid on the drivers side in the air injection only has two ports. Mine has three. This is how they are run currently. There is a line that goes into the wheel well and disappears into the trunk. Where does this third port on the solenoid hook up, and where does this disappearing line go (lines up perfect with the upper intake through the oil cooler grommet) and what does it do? Thanks!
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  17. 87we410877
    87we410877 Karting
    Jan 23, 2022
    155
    Dallas Texas
    Tyler eucalyptus
  18. 87we410877
    87we410877 Karting
    Jan 23, 2022
    155
    Dallas Texas
    Tyler eucalyptus
    Got the answer on Facebook. Front facing port with the ? Next to it is open, vacuum line in the fender well goes to the intake, and is for the ignition control module. Digiplex box.
    got the plugs and wires in. So close.
  19. 87we410877
    87we410877 Karting
    Jan 23, 2022
    155
    Dallas Texas
    Tyler eucalyptus
  20. Dockboy
    561
    Maryland
    #146 Dockboy, May 13, 2024
    Yes. It is on my car and operational as we speak.
    It bolts right up to the existing mounting.
    You will have to move the clutch and all the studs over to the new compressor.
    Here is a thread that explains how to remove the clutch. You will need a 5/8-11 bolt.
    https://www.ferrarichat.com/forum/threads/ac-clutch-pully-removal.425221/
  21. 87we410877
    87we410877 Karting
    Jan 23, 2022
    155
    Dallas Texas
    Tyler eucalyptus
    Thanks Again! Do you happen to have a R12 to 134 conversion write up / link with parts handy?
  22. Dockboy
    561
    Maryland
    Sorry, I do not but using the "Search" function will bring up tons of threads!
    It is a highly volatile subject! There are those that say you must replace every system component, and others that say not. It is your car, so it's your choice!
    I replaced the compressor, the high and low side ports, the drier, and the expansion valve. The system works just fine. Because I didn't change the lines, I have to recharge it about every 2 years but that is no big deal to me!
    Good luck!
  23. 87we410877
    87we410877 Karting
    Jan 23, 2022
    155
    Dallas Texas
    Tyler eucalyptus
    Well this was like a damn puzzle going back together. Finally finished. However, the belt was extremely tight on the compressor without the tensioner pulley even helping.
    Is there supposed to be spacers or washers between the compressor and the top bracket on the 3 studs? I’m thinking I need to add some
  24. mixedgas
    mixedgas Formula Junior
    253
    Ramona, CA
    I suspect you'll get a more comprehensive response, but my recollection from the AC on my 328 (like 5 years ago) was that there was a single washer (aka spacer) on each of the 3 studs. I think these are item 6 in the parts book. My car just had washers, but looks like an actual spacer might be available (the C-shaped item 6)
    bitsobrits and 87we410877 like this.
