1987 328 gts resurrection | Page 9 | FerrariChat
Discussion in '308/328' started by 87we410877, Aug 21, 2022.
  1. bertrand328
    bertrand328 Formula 3
    Jun 1, 2015
    1,640
    France
    Bertrand
    Can you post any video ?
  2. 87we410877
    87we410877 Karting
    Jan 23, 2022
    184
    Dallas Texas
    Tyler eucalyptus
    https://photos.app.goo.gl/8rDovHULVk6uFnZN9
    I edited the video to make it shorter, but right after that, tried to start and nothing. Just a sputter or two. Wait a minute, and it does like in the video again.
  3. mixedgas
    mixedgas Formula Junior
    Apr 23, 2019
    293
    Ramona, CA
    are you loosing power at fuel pump?
  4. Freddie328
    Freddie328 Formula Junior
    Jul 29, 2013
    393
    Herts, UK
    Richard
    There's an electrical safety switch in the fuel distributor that switches off the fuel pump when ignition is on but engine isn't. I would check that your getting fuel when ignition is in on position, not cranking position but engine is running. The switch is connected by a small blue plastic clip on type terminal. Disconnecting it allows the fuel pump to run when ignition switch is turned on.
  5. 87we410877
    87we410877 Karting
    Jan 23, 2022
    184
    Dallas Texas
    Tyler eucalyptus
    I’ve done that, same result, everything fuel pump and ignition seems to be operating correctly. It does run. But for only a few seconds.
  6. 87we410877
    87we410877 Karting
    Jan 23, 2022
    184
    Dallas Texas
    Tyler eucalyptus
    pump is still running when it dies, with the blue plug unplugged.
  7. 87we410877
    87we410877 Karting
    Jan 23, 2022
    184
    Dallas Texas
    Tyler eucalyptus
    There’s also no coolant or gear oil in it yet. Would that cause it to shut down?
  8. mixedgas
    Apr 23, 2019
    293
    Ramona, CA
    did you clean out the fuel system - no blockage in the filter/lines? In-tank filter? It seems the car is burning through available fuel then starving.
    I dont think coolant/gear oil level would make a difference but I admit I dont have a lot of experience with these cars running (mine is in pieces).
    There was another recent post about the fuel pump relays but if your pump is running then the relays aren't likely the issue.
  9. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,486
    Dumpster Fire #31
    SMG
    No coolant? Like zero water? Dry cooling system?
  10. Freddie328
    Jul 29, 2013
    393
    Herts, UK
    Richard
    Long shot, but you aren't pulling a vacuum in the tanks? The accumulator you referred is just a spring loaded diaphragm inside a canister. If the diaphragm is leaking fuel will leak out of the breather,which is at the top of the canister. You can often hear them slightly creaking (need a silent space) as the diaphragm moves when the engine is first turned off and the fuel pressure gradually reduces.
    If you've got a CIS test kit, I would put this on the system to see what happens to fuel pressure when problem arises.
    No after market weird immobilizer fitted?
    87we410877 likes this.
  11. 87we410877
    87we410877 Karting
    Jan 23, 2022
    184
    Dallas Texas
    Tyler eucalyptus
    #211 87we410877, Sep 12, 2024
    No aftermarket anything. Everything is brand new, hoses, lines cleaned and blown out, new pump, accumulator, vapor canister, tanks cleaned and flushed, all new filters, rebuilt fuel distributor and WUR, both flow tested and calibrated perfectly (WUR slightly out of specs, distributor perfect).
    I’ve tried with the fuel cap off as well to make sure it wasn’t pulling vacuum. Same result.
  12. 87we410877
    87we410877 Karting
    Jan 23, 2022
    184
    Dallas Texas
    Tyler eucalyptus
    just haven’t gotten to it yet. Still need to change the hoses at the radiator.
  13. 87we410877
    87we410877 Karting
    Jan 23, 2022
    184
    Dallas Texas
    Tyler eucalyptus
    Go back a few pages you’ll see everything is new and cleaned etc etc. thanks
    mixedgas likes this.
  14. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,949
    Atlanta
    John!
    I saw you used a flushing system. It is difficult to know the amount of old fuel varnish in these tabjs when they’ve been sitting this long. Might be worth pulling your new fuel filter to check if it’s gummed up again and you’ll have your answer.
  15. 87we410877
    87we410877 Karting
    Jan 23, 2022
    184
    Dallas Texas
    Tyler eucalyptus
    I cleaned the tanks very very thoroughly. I doubt that is the issue but you never know. If anything is clogged it would be the filter on the outlet fitting on the tank itself. I'll check the fuel pressure as mentioned again during the conditions I'm having and go from there.
  16. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,486
    Dumpster Fire #31
    SMG
    Doesn't answer the question, I'm still not sure if you're saying the system is dry or filled with old water.
  17. 87we410877
    87we410877 Karting
    Jan 23, 2022
    184
    Dallas Texas
    Tyler eucalyptus
    Oh sorry. Completely empty. Dry. In any case, I have since confirmed the car will run, with the coolant system completely empty / dry.
  18. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    794
    Omaha, NE area, US
    Steve
    Running an engine with a dry cooling system is not good at all for the water pump seals. Hopefully you had the water pump belt removed.
    Ferraripilot likes this.
  19. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,761
    Argent/Brasil
    Guido
    Plunjer in the fuel distributor stuck in closed position. ?!
  20. Freddie328
    Jul 29, 2013
    393
    Herts, UK
    Richard
    What was wrong?
  21. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,486
    Dumpster Fire #31
    SMG
    Floating liners without any coolant to mitigate heat. Yeah it'll run for a short bit, wouldn't want to do that for more then 20-30 secs tops. Aside from the water pump seals going, the heat of combustion is going to cause expansion that will seize the rings, guides etc..
    Priority at this point would be to sort the cooling system.
    I don't understand why you'd want to run the engine without coolant. There's a reason the coolant system is very large on these engines.
    The CIS also utilizes coolant sensors for optimal running.
    87we410877 and Steve Magnusson like this.
  22. AUDIO RESEARCH
    AUDIO RESEARCH Formula Junior
    Feb 11, 2009
    399
    PHILIPPINES
    LUIGI RAYMUND LIRA
    this happened to me recently a stuck plunger causing fuel distributor to dump a lot of fuel flooding the cylinders thereby soaking the spark plugs ,w/c results that when the engine is started it starts momentarily then it shut downs .
  23. 87we410877
    87we410877 Karting
    Jan 23, 2022
    184
    Dallas Texas
    Tyler eucalyptus
    well, it doesnt run, so theres that.
  24. 87we410877
    87we410877 Karting
    Jan 23, 2022
    184
    Dallas Texas
    Tyler eucalyptus
    plugger is free. Distributor is rebuilt and calibrated perfectly.
    AUDIO RESEARCH likes this.
  25. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,486
    Dumpster Fire #31
    SMG
    You could try disconnecting the cold start injector from the circuit. Rules out of it's trying to run solely on that or if it's flooding the engine.
    The other issue could be the location of the flapper door, if it's too high it'll restrict air. Usually getting another helper can help with this but having someone else crank to start while using a thumb or finger to slightly depress the air door down to see if it'll run and not using the throttle.
    Are the plugs dry or wet after trying to get it start and run? What's your compression numbers? Leak down? It's not ideal as the engine is cold.
    It was running prior for longer but then stopped doing so?
