1987 TR Spark Wire Replacement - OEM or ? | FerrariChat
Discussion in 'Boxers/TR/M' started by xplodee, Oct 5, 2018.
  1. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    Hey Guys,
    Looks like OEM spark wires are about $650 for both banks. GT Car Parts is quoting $550 for Italian made aftermarket wires.
    Any opinions on this topic? Stick with OEM for the extra money? How to make sure I'm not getting some wires that have been sitting around for 30yrs if I do go with OEM?
  2. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    rebuild with 7mm wire in your oem covers
    turbo-joe and xplodee like this.
  3. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,931
    romano schwabel
    when you make those wires by yourself then you still need the plugs and the red silicone hose around. you could use the old ones but it is a terrible job to do this
  4. ago car nut
    ago car nut F1 Veteran
    5,266
    Madison Ohio
    David A.
    Not so bad to do it that way!
  5. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,402
    Alabama (was Mich.)
    Jeff
    I've made up several sets of plug wires over the years and it does require a little patience, but you can do the whole job for between $100 and $200.
  6. Jeff Pintler
    Jeff Pintler Formula Junior
    Jul 20, 2005
    537
    Richland
    Jeff Pintler
    Make this stuff yourself. the red outer covers are removable and there is plain solid core spark plug wire inside. Be sure to measure
    the resistance of the spark plug extenders and replace ones that read open resistance. One last fun fact, carefully inspect
    the spring behind the carbon contact in the distributor cap and of course the length of the carbon contact.
    Jeff Pintler
    89 348tb, 86tr, 99 360 3-pedal, 05 Bobcat S-160
  7. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    Thank you, Jeff. While I acknowledge youre right. Given my level of frustration and wantinf to reduce any unnecessary variables, I purchased Italian wires from GT Carparts. Everything ohmed perfectly and the car is running beautifully now.
