1988 Mondial 3.2 Odometer adding miles | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by dmcleod, Nov 8, 2021.
  1. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    afterburner likes this.
  2. Qavion
    Qavion F1 World Champ
    14,605
    Ian Riddell
    Datasheet for Electrolube SPG35SL
    It's sounds very sticky, but the datasheet says:
  3. afterburner
    afterburner F1 Rookie
    3,513
    Switzerland
    Urs STEMMLER
    Qavion likes this.
  4. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,765
    Argent/Brasil
    Guido
    It has an expiration date ? So we have to open that meter every year ? :p
  5. raemin
    raemin Formula 3
    Jan 16, 2007
    2,399
    Lyon (FR)
    R. Emin
    I do have a tube of Tamiya Grease (ref 87022), it's a clean (read milky translucent grease) can be ordered online, and cheap. They also sell a switch lubricant grease that does wonder in the toggle and mirror switches. These hobby grade products are perfect if you need a small quantity.
    afterburner and Qavion like this.
  6. dmcleod
    dmcleod Karting
    May 2, 2021
    59
    Toronto, Ontario
    Derek McLeod
    Got the instruments off without too much trouble. Everything appears to be in order with nothing obviously wrong or out of place.
    The odometer motor is getting power through the small red and blue wires. With the connector removed, no more counting up.
    Not sure what to check next or how to diagnose further…
  7. dmcleod
    dmcleod Karting
    May 2, 2021
    59
    Toronto, Ontario
    Derek McLeod
    I tried to take a reading on the back of the red and blue connector and got something like 3.8V on it with the key on.
  8. Qavion
    14,605
    Ian Riddell
    What does the back of the circuit board look like? Any signs of cracked tracks, dry joints, etc? Can you see the first component that the red/black wire goes to (pin 5 on the main plug). That's the speed sensor signal coming in.
    I didn't think there would be so many wires on the odometer itself (unless some are internal lighting). Can you take the white plastic cover off and see where the wires go?
  9. dmcleod
    dmcleod Karting
    May 2, 2021
    59
    Toronto, Ontario
    Derek McLeod
    I’ll have to pull it out again to have a look - the back of the board seemed fine.
    In the meantime, I now have to figure out why I’m not getting heat in the car. Thinking the thermostat could be at fault. Ferrari ownership is quite hands on!
    Qavion likes this.
  10. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Why the thermostat? You mean your heater isn't working?
  11. dmcleod
    dmcleod Karting
    May 2, 2021
    59
    Toronto, Ontario
    Derek McLeod
    When I start the car up, it will provide some heat initially but then fades to cool air. It’s also operating quite below temperature with the water temperature showing maybe a 150-180F range, but mostly on the lower end and especially if travelling at any speed.
  12. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Same on my car, generally around 180. But the heater works perfectly with 180deg water... I think your heater valve may not be operating properly.
    Disconnect it and see if you get 12V or 0V at the plug dependent on your heater knob position.
  13. dmcleod
    dmcleod Karting
    May 2, 2021
    59
    Toronto, Ontario
    Derek McLeod
    It’s much lower in my case, which has me concerned about the engine temp.
    Where is the heater valve?
  14. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  15. dmcleod
    dmcleod Karting
    May 2, 2021
    59
    Toronto, Ontario
    Derek McLeod
    Thanks! That’s very helpful. Guessing that I’ll need to somehow catch the coolant in the hose to get the valve off.
  16. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Just unplug it and test the signal first to rule out any issues in the HVAC system. It's an ON/OFF signal from the ecu, so you either have 0V (heater ON) or 12V (heater OFF). Only if that's ok I'd remove the valve and yes in that case you need to catch a bit of water (between the exit of the core and the valve).
