1989 328 GTS oil change | FerrariChat
Discussion in 'Technical Q&A' started by rezone, Feb 2, 2006.
  1. rezone
    rezone Rookie
    Dec 25, 2005
    24
    Just got my first ferrari last month and wanted to know if a lift is absolutely needed to do an oil change? Going to use castrol 10w-40 and a fram oil filter by the way. Thanks
  2. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,802
    LA
    Frank
    No you don't need a lift and don't use the fram use the Baldwin 253 or the correct UFI filter. I don't believe the fram has the standpipe in it
  3. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,285
    Colorado
    Dave
    You just need to get it raised maybe 4-6 inches to slide a big enough pan underneath. Mobile 1 0-40 is a better choice. It flows better when cold and has at least as much high temp protection as any 40 weight. Agree with above about filters. When refilling, put in 7 quarts and then start and run. Check the oil then and fill until you are at the add mark. Wait an hour and then bring it up to the full mark if need be. Ususally takes 8-8.5 quarts per change.
    Dave
  4. hardtop
    Jan 31, 2002
    11,285
    Colorado
    Dave
    I forgotten to mention, I usually put rags around the bottom of the oil filter before removing. Usually very little comes out, but sometimes quite a bit. The rags save a mess.
    Dave
  5. Mule
    Mule F1 Rookie
    3,752
    Alaska
    Mule
    Dave,
    Mine is getting due, will you come over and give me a hand? Only negative 12 out last week.
  6. Glassman
    Glassman F1 World Champ
    If you do just jack up the rear end to get underneath it, be sure to lower the car back to level before you re-fill it, or you won't get all of the old oil out.
  7. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,845
    Southern Md
    Robbie
  8. Dr Tommy Cosgrove
    35,338
    Birmingham, AL
    Tommy
    When you reach under there to drain the oil - make damn sure your not draining the transmission fluid instead (don't laugh like it can't happen)
  9. rezone
    rezone Rookie
    Dec 25, 2005
    24
    thanks for the replies, but after seeing many pics of 328 engines on the net with the fram filter I bought 3 of them. is there a big problem in using them? can I use low height ramps at the rear tires or will the car need to be raised up with a floor jack?
  10. Rifledriver
    33,950
    Austin TX
    Fram 2804-1 does have a stand pipe and for many years was the OE filter.
    Frams have in recent years been known to have a complete collapse of the filter material. I have seen several of the filters do it at the cost of two motors I have seen and quite a few I have heard of.
    Just say no to Fram.
    Ufi or Baldwin.
  11. hardtop
    Jan 31, 2002
    11,285
    Colorado
    Dave
    Ramps work fine. One last tip: do NOT overtighten the drain plug. Doing so can crack the pan (a friend of mine did this recently) or pull out the threads.
    Really, it is all just a snap!
    Dave
  12. hardtop
    Jan 31, 2002
    11,285
    Colorado
    Dave
    For a free ticket, a warm bed and a six pack of Alaskan amber, I'll help.
    Yer buddy,
    Dave
  13. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    Agreed.
  14. Mule
    Mule F1 Rookie
    3,752
    Alaska
    Mule
    Bring the 328 oil change directions and you may have a deal (in the Spring).
  15. carlrose
    carlrose Formula Junior
    Nov 25, 2003
    321
    Rezone, shoot me an email at [email protected] & I'll forward you the entire article with pictures. The NAPA part #s for the copper crush washers are incorrect (but were what was on the box I purchased in) but all else should be applicable. Ensure you use a torque wrench.
    Best,
    :) Carl
  16. Dr.T348
    Dr.T348 Formula 3
    Jan 8, 2004
    1,599
    Chicago NW Burbs
    Richard T.
    Make sure you use a new copper crush washer for the drain plug.
  17. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    if you use the FRAM make sure it has the -1 part number, that -1 is the anti-flowback valve or whatever it is called.
  18. Dr Tommy Cosgrove
    35,338
    Birmingham, AL
    Tommy
    Just buy Baldwin filters and you don't need to worry about the Fram
  19. f355spider
    f355spider F1 World Champ
    17,934
    It doesn't matter, because the anti-drainback valver rarely works on the Fram, which is why you shouldn't use them.
  20. Dr Tommy Cosgrove
    35,338
    Birmingham, AL
    Tommy
  21. Mike328
    Mike328 F1 Rookie
    2,655
    Boulder, CO
    Carl Rose's excellent write up, Ferrari 328 Oil Change, is attached to this post. Example car in the procedure was a a late 88 model.
    EDIT: I see Carl already responded. In case he didn't want his article posted, I've removed the attachment. Let me know if I can attach it back for everyone's benefit.
    --Mike
  22. hardtop
    Jan 31, 2002
    11,285
    Colorado
    Dave
    I'll even bring a Baldwin filter with me. Probably hard to find up there in snowmobile stores.
    Dave
  23. carlrose
    Nov 25, 2003
    321
    #23 carlrose, Feb 3, 2006
    Of course you can attach it Mike, this is what makes FC great (smile)! Can't remember, think I may have updated it to effect of NAPA crush washer part #s weren't correct. There was also a debate regarding copper washers a while back - I have no proverbial horse in that race, just taking pictures...didn't realize I could post entire article?
    :) Carl
  24. rezone
    rezone Rookie
    Dec 25, 2005
    24
    can I use the my brand new fram oil filter or not??? what risk would it be? They are not old stock or anything like that. Do you need a new copper drain plug washer everytime you do an oil change? thanks
  25. jw6513
    jw6513 Karting
    Nov 24, 2003
    50
    Arizona
    Jim Whitney
    There is nothing wrong with the Fram filter....as long as it is the right number...use it....Bob Wallace recommends it....and I've never had a problem.
