1989 348 some pic of a car in need attention | FerrariChat
Discussion in '348/355' started by Scan348, Jun 18, 2018.
  1. Scan348
    Scan348 Rookie
    Jun 6, 2018
    5
    Vancouver B.C. Canada
    Stu Scan
    Hi
    The pic's below are from a 348, I looked at.
    Recent engine out cam belt work done on a tight budget. (work not done by owner)
    Not running very well. rough idle, from current owner.
    We did not start, flat battery & in basement of rented condo. car was pushed to current location.
    I threw a cash number at him. He was not impressed.
    Car looks great from 20 feet away. BUT!
    I will let the pic speak. :)
    This pic is from the coil pack L-H.
    This car can do with a re-pin job but is it worth it?
    As you can see the back end is very dirty due no wheel liners at all !!
    He recently bought used wheel liners are in trunk.
    This vin & date plate does not look original. I have the vin number front he steering column & does match the door jam decal. But the number on the R-H rear shock tower is filled over & painted. I did not take picture of it. The car does have plates & is currently a valid VIN & province plate Image Unavailable, Please Login
    The car has under 50K miles but sun damage, Engine cover is faded. car has been painted, you can see over spray on rads.
    Not he cleanest fuse box.
    I was looking for a project. The current owner does not wrench.
    First post on the this great site always liked the look of the 348.
    But how much work is in this project _________________ ?
    Stu
  2. steved033
    steved033 F1 Veteran
    Apr 12, 2017
    7,792
    Atlanta, GA
    Steve D.
    Do you want $$$$ (shop) or hours (self)?
    It's a big enough mess, that running rough, you'd want to check compression and a myriad of other things, possibly even dropping the engine out again and re-doing/rechecking work.
    It's definitely been repainted, as the lowers are no longer black.
    You say you were looking for a project...you found one. Personally, i like them like this. if you're getting it sub 30k, it might be a good buy, but you have to want THIS car.
    sjd
  3. A348W
    A348W Formula 3
    Jun 28, 2017
    1,749
    North Wiltshire, UK
    What is it worth, we would need lots more detail. Paint condition, interior condition, pervious service history, mileage, tire dates, condition of bushes, condition of rear subframe, brake pads, brake discs, brake hoses, etc etc. Your get the idea.
    Rough running might just be a $40 crank case sensor, might not be! You wont know until you start diagnosing it. (Re-pinning seems to be more a North American "thing"; but I might be wrong.)
    How much work? How long is a piece of string.
    What would need further investigation first is the numbers. Note that the pic you have above is NOT a VIN plate, its just a tyre pressure/size sticker. You buy these as repros, typically when doing a respray! You need to look at the shock tower, and if its been painted over it needs to be scrapped back, compare that to the steering wheel plaque, the plate that is riveted to the chassis member on the front pillar, visible when you open one of the doors and the registration documents. The original glass also has the last few digits of the number etched on them (at least mine does) Also look at previous service invoices, as some will record the car by the chassis number. All this will help pull the numbers together, but key is the shock tower, front door pillar and reg documents.
    You sure you want a project Ferrari?
  4. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Resale Red?
  5. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    I love seeing neglected significant cars fall into the hands of caring owners who will put in the effort required to bring them back to their former glory. So I'm almost always in favor of someone trying to save a car if they have the skills and kinda sorta know what they're getting themselves into. But....
    What really worries me about this car is the giant question mark looming over the VIN. People do not obscure the stamped VIN for no reason. That is a huge red flag to me. Personally, even if I were willing to take on a project such as this (I've seen worse 348s become beautiful again) I'd be worried that the car's past might eventually catch up with it and I'd be out my investment *and* my time.
    If you want to pursue this car I'd suggest searching the VIN that you do have to see what comes up. I believe there are even ways to run it through certain law enforcement databases. Unless you have some reason not to do so, I'd suggest posting it here as well to see if someone recognizes it. A few of us keep our own databases of known 348s. If you do post the VIN, also post the Assembly No (top of the left rear shock tower) because that can also be used to identify the car, as well as to confirm that the two numbers correlate in the build timeline. If the Assembly No. is missing, that would be yet another huge red flag for me.
    I would not be surprised at all if the car was stolen at some point and the VIN plates were swapped from a wrecked car. Does the VIN sticker in the driver's door jamb match the build plate and the steering column plate? The sticker would be much more difficult to transplant than the build plate and it sounds like whoever messed around with this car's identity was not exactly a pro. If it and the Assembly No are both missing the conclusion is almost inevitable.
    HTH. I swore I wasn't going to bother to write detailed responses to first time posters after all of the recent hit & run questions, but this is an intriguing situation. I hope you'll post the VIN and Assembly No., or at least PM them to me.
  6. GTO Joe
    GTO Joe Formula Junior
    989
    Charlotte, NC
    Joseph Troutwine
    I don't know for sure about later '89 builds but I can say that the early cars did not have an assembly data plate on the left side shock tower. There is a build number stamped into the left tower though on the vertical area just behind the usual location of the assembly plate.
  7. allandwf
    allandwf Formula Junior
    Aug 27, 2011
    267
    Scotland UK
    Is the chassis number not etched onto every piece of glass? It is on mine.
  8. Scan348
    Scan348 Rookie
    Jun 6, 2018
    5
    Stu Scan
    I have done the search $$ of the VIN number.
    Mileage report qty: 3 from 2006 30K kilometers, 2007 49K Kilometers, 2010 58 K Kilometers from Quebec,
    2010 to 2018 Vancouver renewal no mileage reported.
    No info from 1989 to 2006. !!! I talked to our local license office about the reports lack of info in the report & response "some data has been purged" They no longer have access to vehicle history.
    Yes.
    The door jam sticker looks to new for a 30 year old car.
    The VIN number on the door jam a single decal inboard of the door jam sticker that I posted. I deliberately omitted the VIN. As the car is not in my possession.
    Pertaining to the the Glass; from what I looked at, the sides have Ferrari name but front glass does not. I did not look at the fine print on the glass. I have seen cars with VIN etched but as more of a deterrent.
    I wish I had the the vin number location pictograph with me. I now have a print out.
    Thank You, for the questions.
    The car deserves another look & pictures.
    Stu
  9. bjwhite
    bjwhite F1 Rookie
    Mar 17, 2006
    4,686
    Seattle, WA
    Brian White
    VINs are not private information. There would be no risk in posting it. But that's your call.
    I would love to see the rear shock tower area where you're saying the VIN is ground off.
  10. ghardt
    ghardt Formula 3
    Apr 18, 2004
    1,259
    Texas
    Jerry
    The silver sticker with tire pressure info looks original to me.
  11. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    I believe that may have been a requirement in some countries, and was a popular anti-theft "strategy" during the 80s and early 90s.
    The Saudi spec '88 Mondial Coupe I owned had the windows etched with the VIN.
    BTW, what country are you in?
  12. Scan348
    Scan348 Rookie
    Jun 6, 2018
    5
    Stu Scan
  13. RWP137
    RWP137 Formula 3
    Apr 29, 2013
    1,588
    AZ
    Rick
    He’s not will to take the risk and fix it to sell for more, so why would you take the risk of over paying? Stick to your low offer, leave your number and I bet your phone will ring. If not, you’re out nothing. Lots of good cars out there.
    The fact that it won’t start and runs rough compleatly negates the “recent belt service.” You need to pull the motor again imo...
    Wade likes this.
  14. GTO Joe
    989
    Charlotte, NC
    Joseph Troutwine
    Can anyone verify when the factory began using the stick on vin label that is shown above the tire sticker in the above picture. My car was built probably a couple of weeks before this car and I don't have that vin label and given the placement of the tire sticker on my car there would not have been room for it between the label and the black trim. Lots of little things unique especially to the early cars that is fun to know. It would be interesting to see the metal plate with the vin on the door post to see the build month on this car as well.
  15. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Joe, I do not believe that particular sticker to be original. The earliest car for which I have a pic of the rear of the driver's door jamb is 82618. It has the tire data sticker but nothing else. By 84547 the factory had begun adding the bar code style VIN stickers seen in later cars (I do not know the specific SN where the change was made; perhaps with the '90 model year?). As I'm sure you know, the factory bar code VIN stickers were placed lower, between the air intake and the door seam and were quite a bit larger than the one pictured here.
    I agree that it would be great to have pics of the build plate, the area usually occupied by the chassis VIN, and the engine (to at least know if it's a 2.5 car as this SN would indicate, or if we could use it as evidence that this VIN doesn't belong to this car). But that's the OP's business and he doesn't seem too concerned. According to the Ferrari VIN decoder the check digit is incorrect in this VIN, so it would seem there are plenty of things to wonder about on this car.
    BTW, if you're willing to share you car's info for my SN database please PM the interior color, mileage, VIN, motor number (don't guess there's an Assembly No visible, although it might be next to the Motor No in the warranty book), build date, and any other pertinent data. I'm trying to document as many of these cars as possible, including pics.
  16. GTO Joe
    989
    Charlotte, NC
    Joseph Troutwine
    Mike, thanks for the quick reply. I was just looking at the '89 348 that sold this evening on BAT which is later than mine and it doesn't have that vin sticker either. I think there are a number of unusual items about the car in question so "buyer beware" applies. I will pull my books and get the info to you about my in the next few days. Take care. Joe
  17. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Thanks, Joe! I had today's BAT car in my database from a previous listing but I need to update with the new data & pics. It is the earliest chassis I have documented, so your car will take its place once it's entered. The earliest SN I have recorded is 79908, which was presumably a pre-production car or *very* early series production since there are 328s with higher VINs.
    I love learning this kind of stuff about these cars since they're not very well documented at all. In fact, your earlier post was I knew of the build number being stamped near the rear VIN. Always learning...
  18. tr0768
    tr0768 Formula Junior
    Oct 28, 2008
    730
    maltby wa
    Howard Musolf
    When my wife and I visited the factory a few years back, we were taken through the archives warehouse. This building houses build files on every production and race car ever produced. You can try and apply through their clasique department for copies. Typically the Italian way it may take months for a response.
    I was able to get actual copies of photos of my 400i, and my 308gtsi. These documents are in file boxes in numerical order, shelves and shelves row upon row. It was like the holy grail of Ferrari history. In the file for my 400i, there was a hand written card with notes of some history that had been reported to the factory over the years.
    just sayin'
    tr0768
  19. allandwf
    Aug 27, 2011
    267
    Scotland UK
    UK. mine is a 91 UK 348.
  20. ghardt
    ghardt Formula 3
    Apr 18, 2004
    1,259
    Texas
    Jerry
    My 1993 348TB has the same tire pressure info sticker. However, it does not have the narrow vin # sticker. Dealers will reprint vin stickers for customers. Ferrari of Houston reprinted a vin sticker for my 612 because it was bubbling off. Maybe a dealer reprinted a modern sticker for the car in question.
  21. Jasonberkeley
    Jasonberkeley Formula 3
    Apr 23, 2017
    1,321
    NW Corner, CT
    Jason Berkeley
    That is very cool. Is there any kind of service available to pay to get copies of those files for your car?
  22. Scan348
    Scan348 Rookie
    Jun 6, 2018
    5
    Stu Scan
    The car has sold.;)
    He asked if I would beat $36k CDN :eek: & my best offer was not enough:confused:.
    Thank You FerrariChat members:).
    Stu:D
  23. bjwhite
    bjwhite F1 Rookie
    Mar 17, 2006
    4,686
    Seattle, WA
    Brian White
    Wow that’s $27k US. Seems like a decent car for that.
    steved033 likes this.
  24. Scan348
    Scan348 Rookie
    Jun 6, 2018
    5
    Stu Scan
    I was close in the price but he quoted Hagerty level 4 as a reference. This car is not a level 4. More pics to ponder.
    Their is corrosion on the blades in front fuse box.
    above rear wheels
    The front hood lever escutcheon is corroded through on bottom
    Drivers door
    Drivers door opening pull is incomplete as in chunk missing finger pull area.
    Rubber sill not attached. ..... ETC .....
    With no history from 1989 to 2006. I have saved my self some grief.
    Would be interesting if the new owner popped up here.:oops:
  25. A348W
    A348W Formula 3
    Jun 28, 2017
    1,749
    North Wiltshire, UK
    Looks like you dodged a bullet there, despite the low price. Both buttresses need doing, some dodgy wiring going on around that door, and the carpet on the door car has gone a funny colour.
    All things that can be sorted, but with the question marks over the VIN...best left to somebody else I would say.
