1990 348 | FerrariChat
1990 348
Discussion in 'Technical Q&A' started by OiTBill, May 15, 2006.
  1. OiTBill
    OiTBill Rookie
    May 15, 2006
    5
    How come my speedometer works sometimes and some times it just drops to zero and doesn't work?
  2. plugzit
    plugzit F1 Veteran
    7,775
    Redondo Beach, CA
    Bruce Bogart
    Probably your speed sensor. The wire tends to break on the sensor and only sometimes make contact.
  3. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    OiTBill; Welcome to Ferrari Chat!
    Just in case you are not familiar with the system in your 348, here's how it works. There is no drive cable involved with the speedometer in your car, it's totally electronically operated. There is a sensor mounted on the transmission case at the back of the car, next to the inner end of the left axle. This sensor is reading the rotating speed of one of the inner gears, and translating it into an electronic signal. The signal is sent through two wires to the speedometer, where a circuit board reads the signal and drives the needle. The usual problem is that the sensor breaks down and sends an erratic signal (or no signal) to the speedo. There is at least a possibility that you have a bad connection at the pigtail plug next to the sensor, or at the twist connector near the top of the LR shock tower, or at the printed circuit board on the back of the instrument cluster. And you may have a problem with the speedo itself. Is the odometer working normally, or does it also stop working when the speedo stops?
    There are a few basic checks you can make to be sure that the connections are clean and tight, but you probably have a bad sensor. My opinion.
  4. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,804
    Cerritos, CA.
    Hi Jeff, do you know what year they start using the elctronically operated speed sesor? I wan't to know if my 84 308 QV is electronic or mechanical thank you.
  5. Llenroc
    Llenroc F1 Veteran
    5,481
    Colorado
    Vern
    They have been around a long time my '75 308 GT4 had a electronic speedo and your 308 does also. Regards,Vern
  6. Ricambi America
    Sponsor Owner
    #6 Ricambi America, May 15, 2006
  7. PassionIsFerrari
    PassionIsFerrari Formula 3
    Aug 15, 2004
    2,454
  8. Ricambi America
    Sponsor Owner
    click da' link, mate!
  9. miketuason
    Feb 24, 2006
    15,804
    Cerritos, CA.
    Thanks for the info sir.
  10. Llenroc
    Llenroc F1 Veteran
    5,481
    Colorado
    Vern
    Crap... Sir.. am I that old. LOL Regards, Vern
  11. T-A Tech
    T-A Tech Rookie
    Sep 16, 2005
    49
    Western Massachusett
    Jim Burke
    I remember reading somewhere here that the speedo sensor produces a square wave?? Anyone know if it is a basic Hall Effect-type sensor?
  12. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
  13. OiTBill
    OiTBill Rookie
    May 15, 2006
    5
    Thanks for the reply's.
