1992 348 TS Alternator Light Function | Page 2 | FerrariChat
Discussion in '348/355' started by POLO35, Apr 14, 2018.
  1. m.stojanovic
    m.stojanovic F1 Rookie
    3,309
    Serbia - Niš
    Miroljub Stojanovic
    It is possible that the three wires, including the S (volt sensing) wire, were actually cut-off in the factory. Some alternators have internal volt sensing so they do not have any "S" pin but if they have it, then it is usually connected to the big alternator output terminal (stud). The picture below shows wiring of the CS130 and this is also how the original connections are on my 348 with a Denso alternator (the "S" wire is also red).
  2. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    794
    Treasure Coast Florida
    MATT
    Very interesting. I certainly don't want to burn anything out but do you think it would be safe to try a jumper wire from positive batt output to the sensor wire like your diagram? However, check this out I found on eBay. A self exciting one wire regulator I've also found on some cs130 chats that one wire is very often used on vehicles. item2cab19686a:g:i7YAAOxy79VRcjo1
  3. POLO35
    Feb 21, 2005
    794
    MATT
    Sorry link won't post but its CS 130 self exciting regulator.
  4. POLO35
    Feb 21, 2005
    794
    MATT
    Firat let me say again thank you for all the help. I think what I'm going to do is rig up a jumper wire from the S terminal to the large + output terminal on the alternator with an inline fuse of say 1/2 amp so as not to burn anything out and try that.
  5. FloridaIsland348
    Aug 5, 2022
    118
    Pensacola Beach
    Scott Wheatley
    Do you have a fresh link for this diagram? Thanks
  6. Qavion
    Qavion F1 World Champ
    14,601
    Ian Riddell
    If you can wait until tomorrow, your time, yes. I’m currently away from home.
    FloridaIsland348 likes this.
  7. FloridaIsland348
    Aug 5, 2022
    118
    Pensacola Beach
    Scott Wheatley
    Very helpful. I was looking for the Alternator "IGN" path, and now I see it shares pin 5 in the old style 115 port. Then goes on to fuse 6 in the foot well. This explains why that fuse blew when I fried my Alt. "Red bullet connectors" tricked me into a very very very dumb move when installing a new battery. Paying dearly for that one.
    My instruments are working again with a new fuse, so the fuse for the alternator IGN wire should also be working fine. A test light at the Alternator socket terminal worked. And the meter reads 12v. I can eliminate that as my alternator issue then....I hope.
    Thank you once again. My "hobby" car has had me bent over for a couple weeks. I think I have made every mistake imaginable with my Alternator 155785 at this point.
    Qavion likes this.
