News
Sold 1992 348 TS Rossa/Tan Fresh Major Service ($36K)
Discussion in 'Ferraris' started by jferrante, Aug 10, 2018.
  1. jferrante
    jferrante Karting
    101
    Due to an unplanned move I am listing my 348 TS for sale. This car is fresh off extensive service and is a perfect driver quality example.
    1992 348TS Rossa/Tan
    80,852 Miles
    2018 Service:
    New high flow injectors
    New exhaust system and performance cats
    All new coolant hoses and lines
    New Clutch with Hill Engineering throw out bearing
    All new upper end gaskets, valve cover, intake, etc.
    Valve covers were stripped and repainted
    Intake was separated and repainted
    Flushed brake fluid
    Recharged AC system
    adjusted valves
    new oil and filter
    K&N Air Filter
    Timing belt and roller kit
    Waterpump and housing
    Alternator Replaced
    This service was done at 80,018 miles and completed in June/July 2018.
    The only thing I could notice was moisture on the oil pan after a drive, no drips and may have been water from a puddle but I cant confirm.
    Interior, carpets are original but in good condition, and has 348 floor mats. The car has a carbon fiber "kit" installed in the interior, see photos, looks great. It has a 355 six speed shift knob for some reason so R and 1 are not labeled correctly but whatever.
    No Radio but wiring all in place. Windows are slow but go up and down just fine - window switch on passenger door is not functioning.
    The car has the factory tool kit which appears complete the best that I can tell. Tools, screwdrivers, pliers, belts, bulbs, fuses, etc.
    The tires have plenty of tread left and are in good shape, I did not dig to find a tire receipt however to verify miles.
    The brakes are in good shape, unsue of mileage, but good shape, I am getting a small squeak but think its just an aggressive pad.
    There are no warning lights, no check engine lights, no stored codes and no running issues with the car. It was aligned and balanced before I got it. I have driven it a few times and it handles great.
    Dash lights are bright and working well.
    Clock is flashing 0:00 and I haven't looked at trying to set it.
    AC is cold and blows great.
    Car drives out well, shifts smoothly, and sounds amazing.
    The paint appears to be original, the color is good, the front end would benefit from a respray due to rock chips consistent with the mileage but overall the car presents very well. It does have a very very slight buffer mark on the drivers door edge, wont photograph, though is very minor and probably wont be seen. The passenger door does has a couple small knicks in the edge where the door opens.
    The turn signals have seen better days and a bulb is out on one of the side marker lights.
    The exhaust heat shields are missing
    The top also is in great condition with good seals.
    As mentioned above I am only selling due to an unexpected move and am losing money on it as it sits. I sold the 355 wheels I just bought for it as well so it will come as pictured.
    36k firm
    blkdiablo33, NeuroBeaker and Fabate87 like this.
  2. krazykarguy
    krazykarguy Formula Junior
    388
    Fort Mill, SC
    Matt
    Where in SC?
    CarFax?
  3. brent Lachelt
    brent Lachelt Formula 3
    1,766
    Glendora,California
    Brent R.Lachelt
    I will be shocked if this car isn’t sold by the end of August. GLWS
    ernie and Adam Gasper like this.
  4. jferrante
    jferrante Karting
    101
    Car is in NJ, u have a printed Carfax and it is clean can also provide the VIN if needed
    Sent from my Pixel 2 XL using Tapatalk
  5. Adam Gasper
    Adam Gasper Karting
    Jul 15, 2018
    80
    Adam Gasper
    +1
  6. Fabate87
    Fabate87 Rookie
    Feb 16, 2014
    42
    Chicago
    nice car, is it all numbers matching with clean accident history? Have you performed a leak down test since the rebuild?
    crinoid likes this.
  7. NeuroBeaker
    NeuroBeaker Moderator
    Moderator
    Oct 1, 2008
    30,086
    Huntsville, AL., USA
    Andrew
    Some would call that an anti-theft device. :D
    Looks like a great car that someone will enjoy driving and working on. I wish I was in a position to snap it up. Good luck with the sale!
    All the best,
    Andrew.
  8. Marcopolo3382
    Marcopolo3382 Karting
    Sep 24, 2017
    78
    Marco Daniele
    The 348 has a dogleg shift pattern which was changed with the 355
  9. jferrante
    jferrante Karting
    101
    SOLD Pending payment - thanks Fchat
  10. Gle8
    Gle8 Formula 3
    Dang, I guess let me know if it falls through?
  11. bavareze
    bavareze Rookie
    Feb 15, 2017
    12
    please PM me if this sale does not happen as I am also interested.
    Thanks!
  12. bavareze
    bavareze Rookie
    Feb 15, 2017
    12
    did you close the deal? maybe you want to give me a call 310 384 7428 thanks. been looking for a targa 348 for a while...
  13. jferrante
    jferrante Karting
    101
    Sold
    Fabate87 and NeuroBeaker like this.
