1992 512 tr A/C charging port (R-12) | FerrariChat
Discussion in 'Boxers/TR/M' started by oldcoin, Oct 9, 2020.
  1. oldcoin
    oldcoin Formula Junior
    May 1, 2006
    258
    Reno NV
    Tony Mitchell
    Can anyone tell me where the 1992 512 tr A/C charging port (R-12) is?
  2. raysur
    raysur Formula Junior
    565
    So. Cal.
    Jeff
    You should have two caps on top of your compressor. Look where the two hoses feed into the top of the compressor.
  3. oldcoin
    May 1, 2006
    258
    Reno NV
    Tony Mitchell
    I guess what I should have said is Which of the 2 valves is the low pressue / filling side?
  4. raysur
    565
    So. Cal.
    Jeff
    Low pressure is the larger line/larger cap.
  5. oldcoin
    May 1, 2006
    258
    Reno NV
    Tony Mitchell
    Both lines and both caps are the same size.
  6. raysur
    565
    So. Cal.
    Jeff
    Look for the hose that is connected higher. That is your low pressure hose.
  7. oldcoin
    May 1, 2006
    258
    Reno NV
    Tony Mitchell
  8. oldcoin
    May 1, 2006
    258
    Reno NV
    Tony Mitchell
    Ray, Thanks for trying to help. I cannot tell which is higher. Visibility and access is sub optimal.
    Tony
  9. raysur
    565
    So. Cal.
    Jeff
    Post a picture of your compressor and I'll circle it. The low side line connects at the 12 o'clock position on the compressor. The high side connects around 2 o'clock (standing at the rear of the car looking forward).
  10. Steve Magnusson
    25,140
    There should be some markings (usually cast lettering) on the back end (or maybe top) of AC compressor housing to identify the function of each fitting -- something like DIS (Discharge = high side) and SUC (Suction = low side).
    MOSS, turbo-joe and INRange like this.
  11. INRange
    INRange F1 World Champ
    10,201
    Virginia/Florida/Caymans
    JD
    It would be a lot simpler to hook up a set of gauges. You have a 50-50 chance of getting it right the first time. It won't blow the gauges. If it is out of R-12 then you have look at the back of the compressor to sort out which line is which. When you do, mark the suction/low pressure line with a blue marker.
  12. oldcoin
    May 1, 2006
    258
    Reno NV
    Tony Mitchell
    Issue solved. The charging port is the port closest to the center if the motor. I had to loosen and move rearward the coolant overflow reservoir to connect to the port.
    raysur likes this.
  13. oldcoin
    May 1, 2006
    258
    Reno NV
    Tony Mitchell
    Thank you all for your help.
    raysur likes this.
  14. Clyde Romero
    Clyde Romero Formula Junior
    Sep 6, 2019
    691
    Atlanta Georgia
    Clarence Romero
    when looking at the compressor from the rear its the hose on the left side
