1995 F355 GTS: Restoration and Major Service | Page 12 | FerrariChat
Discussion in '348/355' started by MAD828, Jul 15, 2015.
  1. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    cool...looking forward to your impressions of the Fiorano springs
  2. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    #277 MAD828, Jan 5, 2016
    The stock muffler had some surface rust and general corrosion. Cleaned her up nicely, with a wire wheel, rust remover, rust convertor, tin foil and heaps of elbow grease.
    Still a few spots to clean up on the exhaust but I will leave that for another day, happy to see it looking a lot nicer.
  3. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,758
    Lake Villa IL
    Well that definitely brightened it up! Are you using a very fine wire wheel so it doesn't scratch it or was the wire wheel not used on the muffler body?
  4. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    Fairly coarse gold wire wheel only used to to remove heavy corrosion along the muffler seams and a few spots on muffler body.
    Steps
    1: degrease muffler and clean
    2: remove heavy corrosion with wire wheel (bottom and topof muffler)
    3: Rust converter to sit for 1 hour, scrub and reapply where necessary
    4: Using a damp towel wipe muffler clean
    5: Have a roll of alfoil, dip in water and rub muffler body to produce a nice original finish
    6: wipe down with methylated spirits
    7: protect with wd40
  5. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    #280 MAD828, Jan 8, 2016
    My bypass valve doesn't rattle however the top was painted at some stage and looks tatty. Also when I removed it previously I discovered it was missing the metal O-ring seals which cost a fortune.
    Luckily I had a friend who upgraded to a Capristo valve despite his bypass valve being in great condition. I got it, and polished her up to like new and fitted it up now with the metal o ring seals. Overall it looks a lot better and sounds great too. I will clean up my old valve just in case.
  6. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    #281 MAD828, Jan 8, 2016
  7. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    Great job. Your car looks awesome. You have inspired me to remove my shields. I like them less and less every time I look at them.
  8. DaisyCutter
    DaisyCutter Formula Junior
    Jul 15, 2014
    255
    Sweden
    Dayan
    Elliot, such an impressive dedication to improving the condition of your car.
    I am currently in the process of restoring the interior and engine bay of my Berlinetta so reading this post has been an inspiration. You've prompted me to look even closer at every element of my car.
    And you are Australian so that makes it just that much better!
    Regards,
    Dayan (Ex-Melbournian living in Sweden).
  9. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,758
    Lake Villa IL
    Yes this is what you call doing it right! Looks clean and gorgeous, thumbs up on the shield removal.
  10. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    Thanks gents! The list of things to do is getting smaller. I still cant believe I have my dream car, and its a definite labour of love.
  11. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    Take them off! If you want you can always reapply it looks cleaner without and was only ever meant for the race cars anyway. Doesn't need an addition badge to tell everyone its a Ferrari.
    G'day Dayan! Post up some pics of your restoration. All the best with it.
    Still tossing up on the grill : ) Your under carriage is my inspiration now!
  12. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Very nice mate!! Beautiful day for it. :)
  13. DaisyCutter
    Jul 15, 2014
    255
    Sweden
    Dayan
    Within the first 2 hours of ownership, the first thing I did was carefully remove the shields. For me they just aren't needed and clutter the lines of the car, especially set against the Giallo paint. Personal preference of course.
    Removal of shields also allows the rather pretty little side repeater lamps to breathe a bit.
  14. vjlax18
    vjlax18 Formula Junior
    687
    Nottingham, MD
    My car came with cheapo sticker shields on it and I ordered new metal ones as soon as I received the car. I still haven't put them on as I'm not sure about whether I want them on or not. I even went so far as to buying the nicer stickers that look good from a distance and put magnetic tape on the back of them. I put them on and look at the car and them take them off. I still can't decide.
  15. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    + 1 on removing the shields......looks very clean
  16. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    #291 MAD828, Feb 3, 2016
    Some little updates for now:
    Replaced the oil blow by return lines with new OEM versions. Managed to find a NOS top pipe and a Ferrari remanufactured lower pipe.
    Also purchased a second set of new valves just for the plastic screw on caps. When my wheels were refinished they threw out the plastic caps and installed the old Ferrari badged caps! Annoying as I wanted the plastic caps for originality. All sorted now.
    Next up is probably to buy Tubi insulated headers as a preventative to the known issues of header failure.
    Have to fit the 355 challenge suspension mounts and fiorano springs too.
  17. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    yup.....its all in the detail
  18. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    and tubi headers are an excellent upgrade.
  19. ferrari bud
    ferrari bud Formula Junior
    Jun 29, 2014
    261
    SF Bay Area
    Chris
    Any good recommendation/vendor for Tubi headers?
  20. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    I'm probably going to get it from an Australian vendor. Doing a group buy with another forum member to get a cheaper price. They currently list at a whopping $7500 AUD. Bestexhaust.com.au
  21. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Verry pricey
    But they are supposed to be the best
  22. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    #297 MAD828, Feb 29, 2016
    A few parts came in from Eurospares readying myself for the Tubi headers. New gaskets, exhaust bolts and nuts plus a few misc items I wanted to replace with new.
    Also took the time to pull apart exhaust mounts to put through my vibratory tumbler, zinc plated and yellow passivate. I'm helping to restore another 355 at the moment with a friend so we did a bulk lot of plating, hence a few plated bits in the pic that belong to his car too.
    I will be ordering the Tubi headers next week. Will document that install and will try to get the fiorano springs installed and the challenge front suspension mounts fitted in the one hit. Will be keeping busy doing all that I'm sure.
  23. phrogs
    phrogs F1 Veteran
    7,345
    Kzoo Michigan
    I tried plating, just never looked right.
  24. PAP 348
    Dec 10, 2005
    100,220
    Pap
    I wish I had your time mate, I don't have time for anything anymore but work, kids and work at home.
  25. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    I would be looking to correct that PAP! It has been 11.5 months since purchase so this project hasn't happened over night. But you have owned the 348 many years now so those belts have to be done soon no excuses!
    I don't have the most patience for a slow build so Im getting stuck in when I can.
