1995 F355 GTS: Restoration and Major Service | Page 13 | FerrariChat
Discussion in '348/355' started by MAD828, Jul 15, 2015.
  1. Markphd
    Markphd Formula Junior
    Mar 10, 2012
    713
    Beautiful work!!! These things never are overnight when done right. You are giving me motivation to get back out there tonight.
  2. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,115
    Josh @jtcarprojects
    just went over everything you did, great job love it
  3. dohc_RWB
    dohc_RWB Rookie
    Feb 5, 2015
    11
    Canada
    What a thread ! Congratz !
    DOHC :)
  4. JoeTSI
    JoeTSI Formula 3
    1,433
    Huntsville, AL
    Joe K.
    As someone else who also suffer from OCD car detailing syndrome, I thoroughly enjoyed your thread and look forward to continued posts as the car evolves. Great work!!!
  5. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    #305 MAD828, Mar 3, 2016
    Thanks gents! Today marks 1 year to the day that I drove down to pick up the car! I didn't even test drive it or do any inspection, I was getting it no matter what! Glad it has worked out so well and I'm very happy with the progress I have been able to make with the car over the last 12 months.
    As a treat the car will be getting Tubi headers to celebrate!
    A pic from the day I drove down to collect her with a friend in his C63. I will get the car out for a drive today.
  6. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    sweet....enjoy :)
  7. WATSON
    23,698
    WI
    Jealous. 20 degrees(f) here with snow for tomorrow.
  8. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    #308 MAD828, Mar 15, 2016
    I swapped out my HVAC overlay panel for the new improved version from sticky RX:Ferrari F355 HVAC Overlay ? Sticky RX Refinishing Solutions
    The finish is smoother and much more OEM like. The graphics, font and line thickness are all factory correct.
    Here are the pics of the new overlay and side by side with the old HE version.
    I'm really happy with the difference it has made to the look of the centre console, especially the brightness of the blue and red dots - they are much more vibrant as per factory.
  9. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    #309 MAD828, Mar 15, 2016
    Had my first mechanical hiccup last outing. When sitting in traffic I noticed the temperature gauge would climb and fall back to normal once moving. Which hinted to a radiator fan problem. Only the RHS was kicking on and the LHS wasnt working despite the water temperature reaching the threshold for activation.
    I looked first up at the fuse board in the footwell and the 30amp fuses were fine for both sides.
    So it was either the fan switch or the fan itself.
    Jacking up the car, removed the wheel and front fender liner to take a closer look. I stuck a paperclip into the fan switch connector to trick the fan into powering on. It did, but is was just the sound of the motor spinning!
    Upon removal of the fan the fan blade itself was detached from the motor with the internal spline having stripped out the fan blade housing. Not sure how this has occurred?
    The date marked on the fan is 3/95 so it is likely the original fan. I can buy a replacement used fan blade component and refit or I can take this as an opportunity to buy a new fan unit to be safe. The last photo is what the inside of the fan should look like.
  10. phrogs
    phrogs F1 Veteran
    7,346
    Kzoo Michigan
    If you were closet id give you a fan blade.
    I bought new ones as this happened to one of them figured replace both.
  11. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,346
    Robb
    Car looks great.
    New overlay is fantastic. Great work.
    Robb
  12. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Cheers mate, I will get to them when I can. :D
  13. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Looks good man, job well done. :)
    Good find and lucky it's an easy fix. :)
  14. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    No worries, may I ask what you replaced the fans with, which model Spal? Just reading about the differences and might source from the Fan man as per a post on here.
  15. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    Following this great thread on radiator fans: http://www.ferrarichat.com/forum/348-355-sponsored-bradan/300662-new-updated-f355-radiator-fan-information.html. I purchased two SPAL fans with part number 30102113.
    I figured if I replace one the other will probably let go and the shipping price was the same for 1 or 2. Better to be safe than sorry. At $200 USD each its good insurance for a cool running motor and protecting the fuses from blowing with the increasing resistance as the electric motors age.
  16. Pangea
    Pangea Formula Junior
    Mar 27, 2011
    442
    Nick
    Nice job Elliot. Looking good. N.
  17. PAP 348
    Dec 10, 2005
    100,220
    Pap
    I was going to suggest replacing both mate, as you know the other side was only 5 minutes away from dying in the arse also. :)
  18. Ferris Bueller
    Ferris Bueller Formula 3
    Mar 23, 2004
    1,864
    New Jersey
    Dominic
    The new overlay from StickyRX looks perfect.
    I sent all my sticky parts from my 430 to them too.
    I know they will be better then perfect when I get them back.
    Very impressed with the quality in StickyRX items and methods
  19. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Not only that.Dave only charge's $45.00 for the 355 overlay that's a great deal..I paid almost double that.
  20. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    You just can't beat the price or quality of the HVAC Overlay offered by Dave at StickyRx
  21. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    #321 MAD828, Mar 16, 2016
    A few bits and pieces tackled today.
    The rear leather trim covers were needing attention in the creases to remove the 20 years of dust and grime that had accumulated and the only way to do the job to my satisfaction was to remove all the trim.
    I had the help of this video from Dave:https://www.youtube.com/watch?v=VSBdaBqRHE4
    Its not too hard to remove, but its tricky to put back in. The hardest part is fitting in the engine bay to remove the 5 nuts that secure the 2 long centre trim covers as they are secured from the firewall from the engine side and via self tapping screws accessible from the interior.
    I used AMMO leather cleaner and moisturiser - I normally use leatherique but I love Larry's other products so I gave these a go. His products all smell great too.
    While the interior was out I used AMMO shag fabric cleaner to remove the dirt stains in the carpet, came up a treat.
    The rear windows could now be properly accessed and cleaned at the rub line where the leather trim cover normally would sit. I also took the opportunity to use 303 aerospace protectant on the rear window rubber seal which was looking a bit dry.
    After leather was cleaned and moisturised I re-installed it and I'm very happy with the result.
  22. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    #322 MAD828, Mar 16, 2016
    Another item addressed today was to remove the aftermarket pioneer head unit. I never listen to music in the car and the radio did not look right for the age of the car.
    The 95 models in Australia were not delivered with a factory radio, it was a dealer fitted option. I have the rare leather covered OEM radio plate that came with the car on delivery so I decided to fit that. I really like the clean look. The wiring harness was tucked away and I can refit, if required the head unit.
    Another couple of pictures of the newly mounted HVAC overlay with comparison. The interior is nearly completed now, its a lovely place to be.
  23. Robb
    Robb Moderator
    Feb 28, 2004
    14,346
    Robb
    Great work as usual. I don't listen to the radio really either...
    I have an original radio delete plate but haven't swapped out the radio yet... The alpine unit I have looks very good and I might actually use it on an 8 hour roadtrip to Santa Fe NM or Pebble beach...
    Robb
  24. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    The radio is a nice to have item for sure, especially on an 8 hour trip! I will be taking the car for a 3 hour journey if I need music I can listen to my iphone I guess. I made the switch mainly for concours judging for when I show the car later in the year.
  25. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Good choice bro, looks better with the blanking plate in there. :)
