1995 F355 GTS: Restoration and Major Service | Page 40 | FerrariChat
Discussion in '348/355' started by MAD828, Jul 15, 2015.
  1. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
  2. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
  3. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    #978 MAD828, Nov 23, 2019
    CV’s re-greased and new inner boots fitted. Replaced the bolts that secure them to the axle flanges.
    Fresh HE tensioner bearings, hydraulic tensioners and alternator pulley fitted up.
    Engine and gearbox mounts have been changed out, now with the challenge type engine mounts.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Challenge, WATSON, baschul and 2 others like this.
  4. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    CV’s before re grease and assembly. The replacement end caps came in bright silver zinc so I had them re plated to yellow chromate with the other parts as it was when new.
    Qavion and JoeTSI like this.
  5. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    13,891
    Robb
    Gorgeous stuff.
    Robb
  6. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
  7. jkstevens2
    jkstevens2 Formula Junior
    Aug 25, 2015
    278
    Winter Park, FL
    JK Stevens
    I am a Mondial 3.2 owner looking for the next adventure.......I really enjoy working on my 3.2 myself and this thread has just given me the confidence to continue my search for a F355 GTS. What a beautiful car, both inside and out!
    MAD828 likes this.
  8. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    Thanks! Good luck on your search. The 355 is a great car to work on, and to drive.
  9. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    Parts are back in after final finish with vapour honing. I opted to try this process instead of vibratory tumbling as I couldn’t find a supplier local that offer plastic media tumbling. I’m very happy with the result of the wet blasting. Parts look fresh out of casting.
    ShineKen, Robb and Qavion like this.
  10. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
  11. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
  12. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
  13. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,503
    Lake Villa IL
    Amazing work! It's too pretty to put back in the car :D
    Robb and MAD828 like this.
  14. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    Tell me about it! Atleast I will feel good knowing it’s all been done. When the cam covers go back on and the plenums are installed it should look pretty sweet. Will take pictures for keepsake.
    Robb likes this.
  15. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    10,656
    CT
    John Kreskovsky
  16. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    I will get on to it John!
  17. johnk...
    Jun 11, 2004
    10,656
    CT
    John Kreskovsky
    I try to keep my cars nice, but I'm also a "ain't broke, don't fix it" type. But I'm getting jealous. My usual reply would be, waste of time and money. But this is just too nice.
    Incredible work. Truly picture perfect! And best thread on Ferrari Chat since I can remember.
  18. steved033
    steved033 F1 Veteran
    Apr 12, 2017
    7,721
    Atlanta, GA
    Steve D.
    I'm speechless. I LOVE the vapor hone finish!
    sjd
    Shurik355 and MAD828 like this.
  19. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    Thanks for saying so John. I appreciate the “if it ain’t broke don’t fix it” mentality as well. I just really enjoy getting it to this level. I enjoyed it for 5 years almost with minimal mechanical work and now it’s time to do it once and do it right so the next 20+years will be a smooth ride and just the basics. I always wanted a F355 when it was new and seeing as I was 10 when it came out this is the closest I can get.
    Shurik355, 308 GTB and GSF355 like this.
  20. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    Yes I can believe how good the parts came out! Wish I vapour honed the heads too! Fantastic method and great results.
    steved033 likes this.
  21. jkstevens2
    Aug 25, 2015
    278
    Winter Park, FL
    JK Stevens
    Just for my own knowledge..........Are you doing all this work yourself?
  22. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    Yes Im doing it myself. Only jobs farmed out are to specialists like the plating, injector cleaning, vapour honing and head rebuild. I had a tech remove the heads, lap the valves etc and re torque the heads, he will also assist with dialing in the cams.
  23. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    854
    Europa
    Bob
    After you have dialled the cams it would be interesting to know if the factory cam marks align. I dialled my cams and the marks were absolutely precise. Others have experienced slight misalignment. There’s no right or wrong (so long as the cams are dialled with a degree wheel), but it is interesting to know.
