1995 F355 GTS: Restoration and Major Service | Page 41 | FerrariChat
Discussion in '348/355' started by MAD828, Jul 15, 2015.
  1. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    The cams were dialed in with degree wheel, the assembly marks were almost spot on, a fraction off.
    I didn’t perform the timing though, I wanted that done by an expert tech. He also installed the cam covers, so here’s hoping it’s bone dry when it’s running and no leaks from the cam covers.
  2. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    BrianNYC14, ShineKen, GSF355 and 2 others like this.
  3. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
  4. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    854
    Europa
    Bob
    It is a mystery to me why anybody would waste time looking at online smut when there are threads like this to feast your eyes on...:p
    tatry68 and MAD828 like this.
  5. WATSON
    21,726
    WI
    I don't think I could bring myself to put that engine back in the car.
    I would have that rolled up to my office where I could stare at it all day.
    Wow.....
    Qavion and MAD828 like this.
  6. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    I know, it’s better than I dreamed it would turn out. I have researched for years and documented a lot of restorations and original cars to enable me to produce this result. Whilst it is a shame it all won’t be seen I know it’s been done and I love driving it, hopefully even more so now it’s properly sorted in every area.
    spaghetti_jet and WATSON like this.
  7. Qavion
    Qavion F1 World Champ
    11,557
    Ian Riddell
    Elliott has the only Ferrari engine which requires sunglasses to look at :cool:
    Bold words. A 355 is only as good as its weakest link. I think I can smell a resistor burning in your suspension ECU :p
    MAD828 likes this.
  8. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    I touched wood after making that statement hah! If anything electrical goes wrong I know who to call.
    Qavion likes this.
  9. JLF
    JLF Formula 3
    1,657
    Are companies that vapor blast hard to find or can most media blast places do that?
  10. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    I googled it and found someone local. I suggest that for you. It is not a dark art and a lot of people do it here now. There are also a lot of sandblasting cabinet videos that show how to convert it to wet blaster for a similar finish.
    JLF likes this.
  11. Andy 355
    Andy 355 Formula Junior
    Jun 2, 2013
    434
    Looks fantastic Elliott! Lots of attention to detail and it shows. You must be looking forward to hearing that baby sing!
    MAD828 likes this.
  12. jkstevens2
    jkstevens2 Formula Junior
    Aug 25, 2015
    278
    Winter Park, FL
    JK Stevens
    Jesus, thats the truth! This is way better than porn!!!!!
    spaghetti_jet and MAD828 like this.
  13. jkstevens2
    Aug 25, 2015
    278
    Winter Park, FL
    JK Stevens
    Bravo, I am in total admiration! Did you take the motor down to the piston rings? If you did a complete head job including valves are you concerned that the valves will seal so tight that they will push oil into the cylinder, resulting in a burning oil condition..? I have always been told this, one must come with the other but I have never experienced it myself.
  14. Shurik355
    Shurik355 Formula Junior
    May 19, 2013
    297
    USA Tulsa, OK
    Alex Velet
    This is the best and cleanest 355 restoration i've seen or heard of! Truly work of art. This deserves a trophy or actually a gold medal.
    Elliott, good to find you on F-Chat here :D
  15. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    Thanks Shurik!
  16. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    I replaced the one way check valves as they were badly heat soaked and brittle, also the T connector snapped like a twig so that was replaced with new. New coolant sensors and started to run the vacuum lines.
    I need to source a 3 way Y connector for the evaporator line on the intake as the one on it was snapped and discovered on removal.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Robb, A348W and swoshsteffo like this.
  17. BrianNYC14
    BrianNYC14 Formula Junior
    Dec 6, 2014
    754
    North Carolina
    Brian E
    Smiling the whole time I'm looking through this, very beautiful, and thank you for sharing.
    MAD828, tatry68 and Robb like this.
  18. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    Today made some big progress.
    Installed the wiring harness as I had removed it all to reboot and repair the heat shielding in parts. It was a bit of a pain to get it right, thankfully I had another 95 Berlinetta next to it to reference some wiring and it’s correct orientation. Now all the boots are new and will protect the wiring and connections as well as look the part.
    GSF355 likes this.
  19. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    GSF355 likes this.
  20. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    BrianNYC14 and GSF355 like this.
  21. Qavion
    11,557
    Ian Riddell
    Was it difficult figuring out which connectors to install on which fuel injectors or did everything fall into place? I had to go to the wiring diagrams and buzz out the wiring when I installed my new harness.
  22. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    The harness has numbers on the injector plugs so you know which one goes where.
  23. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
  24. Qavion
    11,557
    Ian Riddell
    Ah.. too easy. I wonder why my new harness didn't have them.
  25. steved033
    steved033 F1 Veteran
    Apr 12, 2017
    7,792
    Atlanta, GA
    Steve D.
    Did you red loctite that impeller nut, or did it have a safety washer (with the little bent tang)? It's a bit of safety. (I did mine when I did the curved alloy impeller pump in my 348)
    sjd
