1998 550 Maranello "sorting" thread--DIY | Page 15 | FerrariChat
Discussion in '456/550/575' started by moorfan, Aug 15, 2011.
  1. dersark_painclinic
    dersark_painclinic Formula Junior
    Mar 8, 2005
    981
    Glendale, CA
    Lazik Der Sarkissian
    Terry, my WSM covers through section L, and I do not have the section M or bodywork. If you are interested in that I will take the pain and scan the whole thing and send it to you, it will take some time. let me know. Sark
  2. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    Sark, I'll gladly swap you a visor fix for a copy :)
  3. moorfan
    moorfan Formula Junior
    May 11, 2009
    809
    Central Virginia
    Pete
    Sark, I just saw your questions in a prior post. My motoreva meter worked just fine. Of course I don't have any other meter to compare it to.
    Regarding your fence issue, it definitely has to be fixed. I'm not sure how long it has been since your last "major" but technically you can remove just the timing belt on the one side, locking the cam cogs in place, and then remove the gilmer gear with the impact gun. The problem is you need to make sure your crankshaft doesn't move relative to your cams, and leaving one belt on one bank may help hold it a bit.
    However, if one fence is bad the other is probably near bad also.
  4. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Dave, I will try to scan it and put it on CD, I will mail any body a copy wants it or put it on forum available to others. again I don't have the section M ( which I don't know what it is ) or bodywork. My WSM covers section A - L ( includes). At the end of each section there is a torque table + tools. Give me some time I will get it ready. Thanks for your offer presently my visor is OK. Sark
  5. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Pete. which tools to use to lock the cam cogs. Thanks. Sark
  6. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    I know that people have created their own "cam locking" tools, but I would advise strongly to NOT use any tool that grips the gear cogs themselves (where the belts will contact the gear). Any marking of these surfaces *may* lead to premature belt wear.
    I believe the WSM shows gripping the inner surface of both gears at 3pm and 9pm respectively with a vise grips.
    Since you must use a new timing belt, you may wish to replace both.
  7. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    Thanks Sark, I have the 550 and 575 Manuals on CDs but I hate them. I had the 355 factory manuals in binders and they are much easier to use. I think "M" has to do with re-machining engine parts but I'm not sure.
    As for your passenger visor, if it's used much it will break, they all do sooner or later, just depends on how much they are used, but don't worry, you'll have a fix in the bank. I'll get it off to you soon.
  8. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    #358 dersark_painclinic, Nov 5, 2011
    Dave, I just checked my WSM index, the section M is for body work which I do not have. The last section is N which is maintenance. Cann't you print from the CD you have. Let me know, I will send you a copy as a X mass gift. Sark
  9. billwest
    billwest Karting
    Feb 28, 2008
    60
    AL
    Bill
    Pete -
    Congrats (again) on the great job - sounds like you're up and running. Hopefully you can get the video loaded.
    Bill
  10. BRADAN
    BRADAN Two Time F1 World Champ
    22,661
    West Babylon, NY
    BRADAN
    Good to see you back Terry!
    Don't sweat the leak, it happens to the best of us. Be happy it's not a cam seal.
  11. plip
    plip Formula Junior
    Aug 25, 2003
    292
    Switzerland
    Gianni Olivieri
    Welcome back Terry !
  12. Cribbj
    Cribbj Formula 3
    Pete, take a moment and tell us how much you're enjoying driving it finally! :)
    Didn't you have a grand total of something like 15 minutes behind the wheel before it went on the lift back in August?
  13. wbklink
    wbklink F1 Rookie
    Sep 2, 2009
    3,420
    Los Angeles
    Bill Karp
    Welcome Back !
    cheers,
    Bill
  14. FPFaeth
    FPFaeth Formula Junior
    Dec 3, 2009
    663
    NY
    Frank Faeth
    Terry, I don't know you very well, but you've helped me a few times and I have always found your input/responses/help to be of the highest sincerity, professionalism and knowledge. The sit was far poorer without you on it. Welcome back. Regards, Frank
  15. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    Thanks for all the encouragement guys! She's actually still sitting on the lift, as I am sorting through a few issues. I have a few scattered coolant leaks, and I believe I've determined that my coolant tank pressure cap is bad. I think a lack of ability of the coolant system to "pop-off" is causing these little leaks. I've ordered a new one.
    I have a drop of oil that appears at the bottom side of the timing cover where I replaced the new gasket every time the car cools down from being run, inbetween the oil filters. Very small drop. I will NOT redo the timing cover gasket this soon so I have tightened the bolt around that area and placed some silicone sealer.
    I have a few other little issues, such as a p1115 (02 sensor heater failure) code that I need to look in to as well.
    The car is getting readied for detailing anyway so I hadn't planned on driving it yet.
    Thanks,
    Pete
  16. Trabots
    Trabots Formula Junior
    May 15, 2011
    500
    Perth, West Aust
    Willy Stobart
    Terry, I too am very pleased that you have returned. I hit the send key too quickly and I should not have. The right to one's opinion works both ways and I should have just accepted yours and got on with things. Please accept my sincere apology for the disproportionate way in which I dealt with our disagreement. Willy
  17. Dazzling
    Dazzling Formula 3
    Nov 18, 2010
    1,133
    Adelaide
    Darren
    +1 big....well done
  18. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    I finally managed to post a video, albeit brief, of the engine running after all these services. I chose to film the exhaust because under the hood all you seem to hear is fan noise :)
    [ame]http://www.youtube.com/watch?v=7OCDfaxpk58[/ame]
  19. Konadog06
    Konadog06 Formula Junior
    Aug 22, 2007
    963
    Daytona Beach, Florida
    Bill
    After all that work it must be the sweetest of music.
    Let us know impression's after some seat time.
    Bill
    FL
  20. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    I have been off the radar for a little bit, completing the detailing on the 550 and sorting out a few minor issues.
    I had a persistent p1115 code, which is the code for lambda sensor heater failure pre-cat on bank 1-6. I double checked the wiring that I did for the GCK. All good. I checked both fuses for the heater circuits, both of which were fine. Lastly, I did a ECU reset using the overnight battery disconnect procedure. Code came right back. Finally, I ordered a new O2 sensor to replace the one in question, which looked fine.
    After another overnight battery disconnect, the code is now gone.
    I also bypassed the factory exhaust system, which I discovered can easily be done with NO additional materials and just a rearrangement of the existing factory vacuum hoses. The net result is that all 4 pipes are always open at all times during the engine running. After spending time with this:
    [ame]http://www.youtube.com/watch?v=mu_x0_-0yRA[/ame]
    I have decided that this is how my exhaust will stay for the forseeable future! :)
    The prior video from a few posts back was with the factory exhausts in the factory bypass configuration.
    In the near future also I will add some detailing information specific to the 550.
  21. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    #371 moorfan, Nov 20, 2011
    I have now been able to spend two days driving the Maranello since all the work has been completed.
    The car is an absolute beast. Man. This thing can spin wheels in 3 gears if done correctly and will snap my neck with torque. It is idling extremely well, revs freely to 7500 RPM, and shifts very nicely. Clutch takeup is perfect. It actually rides quite nicely but *may* need an alignment in the front.
    Problems:
    1. Persistent ABS/ASR/Brake warning. When the car is on, the "brake" and "ABS" icons are continuously lit on the left side of the dash cluster, and the multifunction display flashes continuously alternating ABS, then ASR, then back again. There is little information on this problem on Fchat but what I have been able to glean is that this commonly occurs when the front wheel speed sensor(s) are bad. The speedo is working correctly so apparently that rules out the rear speed sensors.
    I took out both of the sensors on the front wheels and they look normal. Does anyone know whether these can be checked with a multimeter somehow? Since I don't own any of the SD systems I'm wondering if I'm going to have to have this checked at a dealer. There are no codes in OBD2 associated with this problem and the brakes operate as normal.
    2. Squeal from the brakes every time they are pressed, mostly audible when nearing standstill.
    That's it. For now. I do plan to change the oil in spring again to ensure that any contaminants that were caught in the oil from all the work get flushed out.
    Next up, interior work.
  22. fou
    fou Formula 3
    Feb 1, 2007
    2,237
    Central Virginia
    Call me the breeze
    #372 fou, Nov 20, 2011
    Pete, told you when I visited, every 550 i ever drove spun wheels going from 2rdto 3rd. Have fun. Cannot help you with the other things. Let me know when you want to try and keep up with me some day hehe? I would not worry too much about the brake squeal. Par for the course until you replace pads. Not sure what pads are on there, but not problem.
  23. fatbillybob
    Aug 10, 2002
    29,393
    socal
    Solutions for your problems:
    Street tires will break traction in 3 gears! There is no soultion to this with street rubber. I like changing tires and I own my own tire machine for doing race tires. The Marry will not break in third on Toyo R888 DOT race rubber. Check your local laws and wallet (due to frequent tire changes) before using the R888. It and the Nitto NT01 are the most streetable DOT race tire. Once you go to race rubber you are not going back so don't start if you have an addictive personality.
    Brakes: There are many pads that do not squeel but I drive in a spirited fashion sometimes on track. So I run a rull race pad that works fine cold. Carbotech XP-10 front and XP 8 rear is a good streetable combo that does squeal that is a worthy track pad. The squeal is intermittant. Carbotech also makes other pads that are no squeal for street. Ask for Adam they know me.
    ABS light: make sure wiring is clean, even connections of the wire to the pins. I seem to think, I remember some ground on the knuckles?
    Isn't it nice to own a stealth street weapon?
  24. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    ABS/ASR problem solved. Start with the basics first.
    The ABS/ASR was working before I started my major service. The one thing that I did do was unplug the harness to the ABS pump to check for corrosion, so the first thing I did was go back to the pump to check that.
    Whaddya know...I had not re-plugged the connector correctly to the ABS pump. Once I fixed this all lights went out. :)
  25. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Pet, I try to remove the green conector at the back of the alternator, I do not want to force it but does not want to come out. Is there any trick into it. Thanks, Sark.
