1998 550 Maranello "sorting" thread--DIY | Page 17 | FerrariChat
Discussion in '456/550/575' started by moorfan, Aug 15, 2011.
  1. fatbillybob
    Aug 10, 2002
    29,427
    socal
    http://en.wikipedia.org/wiki/Piano_key_frequencies
    In my quest for everlasting cheapness the squirrel cage started turning in my head. If you look on wiki the 88 piano keys each have a scientific name and frequency in hertz. I pulled out my kid's Seiko sat500 chromatic tuner ($30) which is used to tune her flute. It will listen to a sound and on the screen tell you if the sound is "C3" or "F#2" etc which correspond to a HZ frequency. So 126hz is between C3 and B2. 130hz is the 28th key on the piano if you tune by ear or "C3" as reported by the seiko tuner. These tuners are at you local music store just make sure your tuner breaks out the different keys of say "C" vs. some tuners that just register all 6 keys of "C" as "C". I hope that makes some sense. My thinking is you could strum your timing belt within earshot of the tuner and if it says "C3" you are at 130HZ. If it says "G#2" (G sharp 2) then you are at 103hz.
  2. dersark_painclinic
    dersark_painclinic Formula Junior
    Mar 8, 2005
    981
    Glendale, CA
    Lazik Der Sarkissian
    Sorry Pete, I had no intention to irritate you. This theory may explain. Bearings either seized or abnormally high build up resistance inside the bearing caused over heathed which transfered the heat to the belts caused stretching and meanwhile caused the grease leaked out. But both bearings toghether?, thats the question. Sark.
  3. moorfan
    moorfan Formula Junior
    May 11, 2009
    809
    Central Virginia
    Pete
    Sark,
    No worries my friend. I'm sorry that my reply came across that way.
    I sincerely believe that I have two separate problems here....the first being belts that I put on too loosely and the second being the leaking bearings. Based on the fact that they feel fine I'm guessing they were overfilled.
  4. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    Carl, I think you just found a cheaper harmonic tensiometer!!!!
  5. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    Pete, I don't think so as an instrument tuner often needs the tone to last a while, a belt stops resonating too quickly for it to work properly I think.
    I used a magnetised paperclip, a coil from an old relay and an oscilloscope in great effect for this purpose.
    FBB, the reason a sum of the two tensions is taken is because there is the possibility of having the long stretch tensioned correctly but still with a lot of slack on the other stretch; such because of the friction in bearings and cam lobes etc.
  6. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    You know FBB will test it out....lets see what happens. I vote that it may work!
  7. dodici
    dodici Karting
    Mar 24, 2007
    102
    Bay Area, CA.
    Dale
    The musical instrument tuner didn't work for me a few years ago when I tried it. But I was able to tune an old guitar to the required frequency and pluck it, remember the note in my head and use a mechanics stethoscope on the belt close to where it contacts the pulley. I could hear the belt frequency when I thumped it and simply matched the two. Works well!
  8. tajaro
    tajaro Formula Junior
    Mar 22, 2009
    686
    Gulfport Florida
    Erik V
    Cool adaptation... I remember 30 yrs ago trying to tune my Jag's six Webers with a 3 ft section of garden hose... A mechanic ( at Thoroughbred Motors as I remember) told me to start with the first carb- stick the hose in the throttle plate and the other end in your ear and remember the sound- tune the 5 others to the same exact tone and you're done.
    Worked great- of course I was so poor I would have tried anything...
  9. dodici
    dodici Karting
    Mar 24, 2007
    102
    Bay Area, CA.
    Dale
    In those days I only had three webers(275) and sure wish I had known that trick then.
    Thanks, I won't forget it.
  10. fatbillybob
    Aug 10, 2002
    29,427
    socal
    I'll try to test the idea this weekend.
  11. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Pete, by any chance you can post a picture of the tool you used to lock the cams for belt chang. Thanks Sark
  12. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    Sark,
    I am not doing a "lock and swap". I have the cams out and lifters out and will retime the motor when reapplying the belts. Should go much faster this time as I've done it once already :)
  13. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    So I recently received all the parts I need to redo my timing job and it is "timely" (no pun intended) as there has been more discussion in other threads about belt tension.
    Today I reapplied new timing belts and tensioner bearings to my 550 and this time I had planned to set the belts to "WSM" specs. And I mean 575 WSM specs, which states that the tension of each banks long timing belt segment is 126 Hz.
    After applying timing belts, reinserting dowels in cam gears and rotating the engine over several times I measured the belt frequency on each side. "Letting the tensioner spring set the tension" does not achieve the desired tension...too low. So after increasing the tension on each bank I noticed that I was getting numbers all in the same rough ballpark but they would change as I rotated over the engine. Because of the multiple parts of the timing system and the possibility of retained tension in any part of the gear train causing variable readings I decided to take 6 measurements on each bank with one engine rotation in between each measurement. I got the following results:
    Bank 1-6 Bank 7-12
    136 123
    117 127
    123 134
    125 130
    122 135
    136 117
    Averaging these numbers produces 126.5 Hz for bank 1-6 and 127.6 Hz for bank 7-12.
    Perfect. This is where I will leave them and I will begin timing the motor. Once the timing procedure is done I will check them again to make sure they haven't changed.
  14. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Pete, if tesion sets atumatically and lock it when spring streches maximally, how do you INCREASE the tension manually to reach the desire readings?. The other thing is WSM says rotate the engine twice, wondering several rotation streches the belt. correct me if I am wrong. Sark
  15. fatbillybob
    Aug 10, 2002
    29,427
    socal
    I can see how this method can give wonky results. There is no WSM for the proper method of avoiding a wide disparity. A belt at the long side under mild tension in the driven direction could yield a very different frequency than the same long side with some static laxity that could be induced just from pressure on the camshafts from the relative lobe positions and the valve springs i.e. the reverse direction. There is always sort of a dwell, if you will, and no one tells us how to account for that. Perhaps the WSM idea of adding the measurements of the longside and the short side and the sum of the frequency being "X" is an attempt to equalize out this exact problem. But that is just a WAG.
  16. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    #416 dersark_painclinic, Dec 25, 2011
    Today I decided to take the timing cover off and check the over all belt conditions and also check the belt tensions with the Motoreva tool I purchased. The tension I recorded is 85HZ on the long side and 205 HZ on the short side of the belt. These belts and bearings are almost four years old. Cheking by hand might feel like they are little loose not very sure?. Also I found out that the pasenger side drive gear's inner fence is loose. what is next?.
    sark
  17. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    Sark, those two numbers suggest that there may be some loading in the system to me, in that most attempts when I get somewhere around 120Hz on bank 1, I get about 170-180 on bank two. Rotate the engine over by hand and try to let it stop "on it's own" so your hand efforts are not loading the timing system in any way. Then check 6 sets of numbers and average.
    However, with a loose fence it's time to do a major and remove those gilmer drive gears to send to Dave or have someone weld the fences. It is nice to see your belts have held tension fairly well!
  18. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    #418 dersark_painclinic, Dec 25, 2011
    Pictures I took associated with the belt tension
  19. fatbillybob
    Aug 10, 2002
    29,427
    socal
    What is the 575/612 spec? Wasn't it something like 285hz combined? If so that's the dwell the factory might be taking out of the system by having that weird additive spec..
  20. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    575 spec is 126Hz on the long segment alone.
    612 spec is 330-360Hz of the combined two runs on each bank.
    And I agree with you. I believe that was the whole point of adding the two segments was because of the variability in measurements of just the long segment.
  21. fatbillybob
    Aug 10, 2002
    29,427
    socal
    Well if I was using such a method we need to think of what the probelms are then how to solve them. My initial thinking is that the problem is that the belt tension changes with every degree of crankshaft rotation because the lobes of the camshafts place variable pressure on the belts through the cogs as the camshaft rotates through its motion. I "think" we can all agree that is where the primary variation would be. Now for solutions:
    Pete you did some kind of average over several revolutions but if the stopping point is always the same place will the average be the right one? I'm not sure what you actually did. I'm thinking of 2 ways to do this.
    What is you rotated one revolution and kept tension on the crank so that the cam shafts are firmly held in the driven direction then measure the long side? Do that for 4 revs and then average the number? Perhaps there is enough stichion in the system that keeping pressure on the crank in the driven direction is not required?
    Method two: what if you left your degree wheel on and then measure the long side at cyl #1 at approx TDC the #2 at TDC then #3 at TDC then #4 at tdc ... etc. and averaged those numbers? Repeate for the 7-12 bank
    Follow my pea brain logic guys:
    Another question I have is was the 575 tension in the WSM of 126Hz with the old or new belts? TAZ? I'd like to know what a test 550 combined tension is long side and short side if the tension is 126 on the long side of the 550. Pete? If Pete's tension is +/-350 like the 612 then I am OK with that. However, lets say the tension was dramatically lower than 350 combined AND the 575 number was on the old belt style then we got a problem and the 126hz number is spurious. If TAZ is right that the new belt is stiffer then the harmonics totally change vs. the old belt and the old belt HZ frequency spec cannot be used. Pete could that have been the reason for your loose first set of belts? If the 575 OEM 126Hz spec is for the new belt and the 575/550upgraded/612 all have the same timing system and the combined Pete 550 at 126hz longside + xxx short side are no where near the OEM 350HZ then does that mean Ferrari is making up specs that sound good and that there is a wide latitude of what is an acceptable belt tension because we can assume there are plenty of dealer fixed cars running at these tensions 350combined or 126longside? If the answer to the last question is yes, that explains why for 30+ years I have been able to set belt tension by hand with 100% success because there is a wide variation of what will work. So now have I completely confused the heck out of you guys? Sorry I go no answers.
  22. tazandjan
    39,392
    FBB- I have a very early 575 WSM I will check for an Assembly Number, but I think both the 126 and 330-360 numbers are probably correct. There is a good chance the last few 550s had the new belts, too, but no accelerated age testing was performed on the 550s.
    Sark- The belts stretch and the Hz specs are only for new belts. Nothing in the tech data calls for rechecking tension.
  23. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    #423 moorfan, Dec 28, 2011
    I have begun putting the maranello's timing system back together. Timing the motor over again took less time this go around probably because of familiarity. As previously detailed the timing belts are tensioned to WSM spec.
    Photos 1-4 show the engine's timing system reassembled. All bolts are torqued CORRECTLY. Photo 4 shows the new "new" timing bearing on bank 7-12. These particular two bearings came directly off Paul Hill's shelf in the UK, although I really wish they said "Hill Engineering" instead of "SKF". We will see how THIS set does.
  24. tazandjan
    39,392
    It looks like the car used for the 575M WSM was Assembly Number 44064, which may have been the 34th 575M built. The AN for the belt change was 43847, so it looks like that precedes the WSM. So the 126 Hz and 330-360 Hz specs are both correct.
    When I replace my belts in a year or so, I think I will also replace the tensioner springs. The same spring, part number 121249, $4.90 each from Ricambi, was used all the way from the Testarossa to the 612.
  25. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    I instaled the John Deere ND alternater with swaped original voltage regulator, it works perfect. Thanks Cribbj and Pete for all the help I needed for this project. Also I should mention Taz and Fatbilly by helping me on other projects I had in the past. happy New Year to all of you. Sark
