1998 550 Maranello "sorting" thread--DIY | Page 35 | FerrariChat
Discussion in '456/550/575' started by moorfan, Aug 15, 2011.
  1. Rifledriver
    37,335
    We still have the same goal and polishing the cannonball gets us no closer.
    In fact it is often detrimental to a finished product.
  2. moorfan
    moorfan Formula Junior
    May 11, 2009
    809
    Central Virginia
    Pete
    Brian's points are well-taken. I for one hate the degree wheel. Its a pain in the ass, and then if you hit the pointer stalk it is so much more work to go back and find TDC again.
    When I time bank 7-12, I will illustrate how to do it without a degree wheel.
  3. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    #853 moorfan, May 5, 2015
    Now that correct timing has been set on the intake cam, the next step is to set the same bank's exhaust cam.
    To do this, leave the engine AT TDC on the non-firing stroke, where you had just stopped it to measure intake cam lift.
    Move your dial gauge over to one of the two exhaust tappets, applying the pointer as parallel as you can get it to the direction of tappet travel. As was alluded to earlier, this is why I have a solid curved pointer.
    Once the pointer is applied to the tappet, zero the gauge.
    Continue to rotate the engine in the driven direction beyond TDC of the non-firing stroke. As soon as the crank begins to turn the dial gauge will deflect and eventually stop as you rotate the engine further. Exhaust timing is correct if the gauge reads 0.69mm +/- .05mm.
    The process is the same for adjusting the exhaust cam as for the intake, with the exception of the fact that you cannot tap the cam into place while watching the dial gauge like you can with the intake cam. You have to trial and error it repeatedly, making fine adjustments in a systematic manner, until you have the exhaust cam torqued in spec.
    Perfectly in spec, the assembly marks of my 1-6 exhaust cam look like this (Photo 1)
    NOT spot on.
  4. fatbillybob
    Aug 10, 2002
    29,393
    socal
    But very close as expected.
  5. dersark_painclinic
    dersark_painclinic Formula Junior
    Mar 8, 2005
    981
    Glendale, CA
    Lazik Der Sarkissian
    Pete, both 550/575 WSM recommend TDC at firing for valve tuning.
  6. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    Sark...refer to post 298 in this thread. That's where I defined what I am referring to as "firing" versus "non-firing". Maybe the WSM says it differently.
    The way I am using the terminology, TDC on the "non-firing" stroke is where the intake valves have just begun to open and the exhaust valves are just about finished closing.
  7. Rifledriver
    37,335
    You are misunderstand the directions and why this can be a very hazardous job for those without a basic understanding of the theory of operation of an Otto Cycle engine. If you were in possession of that understanding you would know that is not possible.
  8. Cribbj
    Cribbj Formula 3
    #858 Cribbj, May 6, 2015
    Pete / Sark, I believe what Brian & the WSM are referring to is the crossing, or sometimes we refer to it as TDC at "crossover" or overlap, just after exhaust stroke where the piston is at TDC and is about to begin the intake stroke, as Pete said.
    It's the 0 point in the valve timing diagram below (Brian, please correct me if I'm wrong):
  9. Rifledriver
    37,335
    Nope. You're not.
    And this is why I have refused to write this type of column for multiple magazines. It just serves to encourage those that have no business doing it.
    Just like the Saturday afternoon car shows pimping parts on TV.
  10. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    John,
    Thank you for the diagram. Is it a general one or one specific to the 550?
    It is a very good diagram because in the timing check description in the WSM they refer a couple of times to the "crossing" without defining what that means to us laymen.
    Sark, I know that the timing description in the WSM states "with cylinder 1 at TDC during COMBUSTION", but that is just the place they are telling you to zero the dial indicator for reference. At that point the cam lobe is not touching the tappet. They then tell you to rotate the engine over 360 degrees, approaching the "crossing", which is what I am referring to when I say "TDC of the non-firing stroke".
  11. Cribbj
    Cribbj Formula 3
    Pete, it's one I constructed for the 550 by measuring tappet movement.
    There was a device years ago that was called a Cam Doctor, and it would "map" a camshaft lobe by using a linear encoder that had a wheel attached to it. Very precise and accurate, but they're no longer made, and I don't know that anything else has taken its place. It used a version of BASIC running under DOS and generated a data file that we'd then pull into Lotus 123 and get a graph like this.
  12. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Pete, Here we are, that is what I meant.
    Thanks again.
  13. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    #863 moorfan, May 6, 2015
    Is there such a thing? :)
    I will now time the 7-12 bank without using a degree wheel, using only dial indicators.
    The first dial indicator is placed into the spark plug hole of cylinder 12, and a second dial indicator is placed onto one of the intake tappets of cylinder 12. With the cams in a position approaching the "crossing" (intake cam lobe is almost ready to start exerting pressure in the intake tappet but the tappet can still rotate freely in its seat), you zero the gauge on the intake tappet. (Photo 1).
    Continue approaching the crossing, until the dial indicator in the spark plug hole indicates you have just reached TDC (the Ferrari way). I had previously set this dial indicator to zero for ease. At this instant, the reading on the other dial indicator should read .70mm +/- .05mm. Adjust the cam as needed (previously described), and torque down the intake cam bolt. Once the bolt is torqued, rotate the engine over several times and make sure that everything is correct. (Photo 2).
    With my 7-12 intake cam timed correctly, this is what the assembly mark looks like (Photo 3)
  14. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    #864 moorfan, May 6, 2015
    Now that the intake cam is perfectly set and torqued, remove the dial gauge from the intake tappet and move it to one of the exhaust tappets of cylinder 12.
    Rotate the engine over 720 degrees and stop it on exact TDC at the crossing. At this point, zero the gauge on the exhaust tappet (Photo 1)
    Now that the gauge is zeroed, you can continue to rotate the engine in the driven direction past the crossing and note where the dial gauge on the exhaust tappet stabilizes. The gauge should read 0.69mm +/- .05mm at this point. After adjusting the cam and torquing the bolt, rotate the engine over again and repeat the reading. After adjusting, readjusting, cursing, and retorquing for about 45 minutes this is the final fully torqued product. (Photo 2)
    Correctly timed, my 7-12 exhaust cam assembly marks look like this (Photo 3)
  15. Rifledriver
    37,335
    Your dial indicators appear in the pictures to be parallel to each other. If the indicator measuring valve movement is not parallel to the valve the measurement of valve movement will be off.
  16. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    I knew you would notice!
    I can assure you that they are not "actually" parallel, they are more divergent than they look...but there is no question that the indicator stalk is not EXACTLY in line with the axis of travel of the tappet. I am limited by my equipment. This is why I fought so hard to get it right on the money, so if I was off a bit because of this angle issue that it would still be within reference range.
    If you think it would end up out of range due to this issue, maybe I should order some more "angular" dial indicator holders to make it perfect? Any suggestions? :)
  17. Rifledriver
    37,335
    It really does make a difference but obviously the degree cannot be known from where I sit. I made a set of indicator extensions from aluminum welding rod, threaded at the end with various curves to reach around the cam and allow as perfect alignment as I can achieve by eye.
    I have experimented a bit to satisfy my curiosity with the need for good alignment and it makes a bigger difference than most suspect when it looks just a little off.
  18. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    Understood. Well my philosophy on something like this is do it right or don't do it all. My idea for the perfect way to do this would be bolt a steel plate to the head "sill" on which a high quality magnetic base dial indicator holder can sit; one that has many angular adjustments possible on it.
    Some of these magnetic base indicator holders I have seen and used are rather chintzy....do you have a favorite brand of holder that is sturdy and durable?
  19. fatbillybob
    Aug 10, 2002
    29,393
    socal
    #869 fatbillybob, May 7, 2015
    Hi Pete,
    If the end of your dial gauge looks like mine I use 1/8" bras brazing rod which is so soft you can screw it in the end of the gauge and it will thread the brass. I got tons of it and can send you some in a #10 envelope today and you will have it before the weekend. I just use it straight and then bend the last 1-2" to get around the shaft.
  20. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    #870 gsjohnson, May 7, 2015
    Ok I'm not showing the pics of the contraptions that I fab'd for this :)
  21. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    Carl, thank you for your kind offer.
    In truth I have a couple of those tip kits that have all sorts of curved pointers for this purpose. That isn't my issue. It is that the valve tappets in this car are angled "outwards" a bit relative to the spark plug holes so that in order to get the best reading the axis of my dial gauge needs to be tilted. With it bolted directly to the head, the tools I have do not allow for a rotational adjustment of the actual gauge to make the shaft's travel exactly parallel to the axis of travel of the tappet.
    I think this is what Brian is referring to.
  22. Rifledriver
    37,335
    I have worn out a number of them but Starret or Mitutoyo get my vote. I bolt a flat steel plate to the valve cover studs to mount them to. It still needs a curved extension to get around the cam though. On any of the 4 and 5 valve motors the followers are just not big enough to get to well any other way.
  23. fatbillybob
    Aug 10, 2002
    29,393
    socal
    #873 fatbillybob, May 7, 2015
    Oh...I just accomplish that with a ghetto magnetic stand that seems to be very adjustable and stable. I just used a plate drilled for the cam cover bolt width to bolt the rig down steady. Besides you are just guessing by eye the parallelism of your set-up to what you perceive the valve to be at. I think there would a wide variation of what people would "see" as parallel. Along the lines of adding undue complication to a simple operation maybe John with heads off his motor could build use a test rig to slide our dial gauges in just for this operation? I'd like one screw in easy like your TDC unit.
  24. Rifledriver
    37,335
    #874 Rifledriver, May 7, 2015
    The eye is an uncommonly accurate measuring device if you are using it correctly. Been shown to be true in many ways.
    I don't think calling it an eyeball guess is any more fair than criticizing the effectiveness of any poorly employed tool.
  25. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    #875 moorfan, May 7, 2015
    Is there any value to those infinitely adjustable types, like below?
