1999 360 Modena/Clutch Change | Page 3 | FerrariChat
Discussion in '360/430' started by wilsemail, Mar 23, 2008.
  1. wilsemail
    wilsemail Karting
    Sep 30, 2007
    76
    Anaheim, California
    #51 wilsemail, May 9, 2008
    Okay folks, finally got around to working on clutch again. I decided to go with the Hill Engineering Thrust Bearing. So, after some cleaning of the inside of the trans clutch area, I reassembled the thrust bearing assembly. Even though I have the manual trans, I went with the F-1's support pin on the side because it just looked stronger than just the roll pin design of the manual. I have the 6-bolt ring gear and all the clutch parts now, so I'll be working on this in the next few days. I'll keep you posted.
  2. jbdmd
    jbdmd Formula 3
    Sep 30, 2007
    1,147
    Phoenix
    Doc Jay
    you are my hero
  3. utah997
    utah997 Formula Junior
    Apr 24, 2007
    399
    Utah
    Doug
    Same here. I saw the first pic with the rear bumper off and thought I was going to be sick. I wish I had that skill set...
  4. tstafford
    tstafford Formula Junior
    Mar 4, 2006
    754
    Nashville
    Tim
    This thread is amazing. Hats off to you guys. I feel like a complete dillweed for having my mechanic install my air filters and cats!!
  5. toshiba
    toshiba Formula Junior
    Jan 14, 2008
    725
    Santa
    dude, air filters.
    were all not mechanics here, but air filters... best way to learn is have a couple hours ( **** always goes wrong) and then start easy like air filters . right now I'm taking off my springs, and let me tell you ,there were some times were I'm going " ok , i'm screwed, gonna have to pay someone to put them back on..."
    to original post: you are brave my friend.
  6. tstafford
    Mar 4, 2006
    754
    Nashville
    Tim
    I would have done it myself (I swear), but since it was in for the cats, I said what the heck! :)
  7. wilsemail
    wilsemail Karting
    Sep 30, 2007
    76
    Anaheim, California
    Can anyone tell me torque specs for the flywheel to crank,
    Pressure plate to flywheel.
    Ring gear to pressure plate?
    I can't find any low $ literature.
    These would help immensely.
    Thanks, in advance.
  8. Donie
    Donie Formula Junior
    Jan 14, 2006
    346
    Spain/Ireland
    Torque Specification
    Flywheel......................83 Nm
    Pressure Plate..............18 Nm
    Crown Wheel/Ring Gear...15Nm
    As requested.
    Regards,
    Donie
  9. ChuckStyl5
    ChuckStyl5 Karting
    Mar 28, 2004
    180
    The Armpit
    just a lil opinion of mine would be to replace the transmission mount while you have it out .. there is a better stronger one out now ... just my 2 cents tho...
  10. wilsemail
    wilsemail Karting
    Sep 30, 2007
    76
    Anaheim, California
    Excellent suggestion, yes, I already did, it was beat. And it is much nicer looking. I used my wheel bearing remover to change it out. Thanks!
  11. wilsemail
    wilsemail Karting
    Sep 30, 2007
    76
    Anaheim, California
    Valuable information....I was gonna guess. Thanks alot.
  12. wilsemail
    wilsemail Karting
    Sep 30, 2007
    76
    Anaheim, California
    #62 wilsemail, May 27, 2008
    Back to work. I was installing the clutch when I noticed that it was out of round!! It's a good thing I wasn't using the clutch line-up tool, or I wouldn't have noticed that it wouldn't center on the outside. (see picture of disc material riveted on off-center) I couldn't believe it either. Don't think that a part from the dealer is necessarily good. They exchanged it, but wouldn't give me the new box. (Gonna sell it off to someone else...#1236, watchout) Anyway, it assembled well after that. I've been working on it over the Memorial Day weekend, and again today. The clutch master won't bleed though. I'm kinda wondering what to do about that. I looked under the dash and noticed it was leaking inside the car. I ordered a new one, it will be here tomorrow, hope it will bleed. The bleeder block in the back looks pretty straight forward, is there some kind of trick?
  13. F360-1386
    F360-1386 Formula 3
    Oct 8, 2006
    1,685
    Markham, ON, Canada
    51216M
    Wow - excellent efforts and great thread ! I think you can open your own F-Car Garage for the FChat members.
  14. wilsemail
    wilsemail Karting
    Sep 30, 2007
    76
    Anaheim, California
    #64 wilsemail, May 30, 2008
  15. andrewecd
    andrewecd Formula Junior
    Dec 17, 2006
    543
    Andrew
    Great job!
    Now when you put your foot on the clutch you know exactly what is going on down there and that is a satisfying feeling.
    So what did you use to paint the box and oil sep tank?? Is it a clear gloss or matt finish? Spray can - engine paint etc
    What's next? ha ha
  16. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,164
    Wash DC area
    Robert
    Congrats!! Many happy driving miles!!!
    Thanks again for such a detailed and informative thread!
    Robert
  17. wilsemail
    wilsemail Karting
    Sep 30, 2007
    76
    Anaheim, California
    There's no paint on there at all. That's what makes it so beautiful. Glass beaded aluminum is awesome. I did, however, spray about 5 layers of Duplicolor Clear Engine Enamel 1200 degree stuff on there. (From PepBoys) Don't go crazy shaking this can looking for a rattleball, it's not there. Duplicolor told me since there's no pigment, it's the only one that doesn't have a rattleball, there's nothing to stir....I wish I knew that before I beat it to death.
    Yes, wonderful feeling to know what's going on in there. And quite honestly, this Hill Engineering Thrust bearing I would use again, regardless of what's in the core, because there is so much more than just the inner bearing in play here, and they seem to have done a better job than the original. The tensioner, on the other hand, I think is a different story. The core is more critical.
  18. OKA
    OKA Karting
    May 7, 2008
    217
    Houston, TX
    Sam
    Thanks for this wonderful thread. Great job.
  19. andrewecd
    Dec 17, 2006
    543
    Andrew
    Yes it does look awesome. Gives it a beautiful raw, purposeful look. How could you possibly paint any of that black again!
    Rattleball story funny. Guess you were thinking you had a dud can.
