1999 F355 GTB OVERHEATING!! | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by bobby355, May 22, 2009.
  1. f355spider
    f355spider F1 World Champ
    18,055
    First question: Yes
    Second question: Yes
    Third question: No
  2. Rifledriver
    37,288
    That is what I am talking about. I have replaced many for a non op fan and they never set a CEL.
  3. f355spider
    18,055
    Understood, thanks Brian for the clarification. :)
  4. bobby355
    bobby355 Karting
    May 21, 2009
    244
    Sweet i'm glad to hear that there might still be hope for an easy fix here.
    Can someone point me directly to the part that i need? I don't think i'm absolutely clear as to whether i'm changing the temp switch for the ECU or if i'm changing the coolant temp sensor..
    Thanks.
    BB
  5. bobby355
    bobby355 Karting
    May 21, 2009
    244
    #30 bobby355, May 25, 2009
    Are we talking aobut part #125769 WATER TEMPERATURE SENDING UNIT, 348/355 (BOSCH # 0280130026) ???
    Thanks!!
    Bobby
  6. f355spider
    18,055
  7. bobby355
    bobby355 Karting
    May 21, 2009
    244
    I am realizing now as I go over my service records that the water temp sensors #125769 has already been replaced on this car about 10k miles ago. I've already bought the part so I guess i'll change it anyway hoping that my RH fan will miraculously start working.
    Could my RH fan not working have anything to do with part# 148677 which is the WATER TEMPERATURE TRANSMITTER??
    Thanks for the help again guys.
    BB
  8. f355spider
    18,055
    No. Note it says "transmitter" not "sensor"....the #148677 is used for the water temp gauge on your dash.
    BTW, have you pulled the fuse panel in the passenger footwell and inspected it for melted plastic or bad contacts yet? You need to look at the back side of it for damage.
  9. bobby355
    bobby355 Karting
    May 21, 2009
    244
    As you can see i'm clutching at straws at this point.
    I pulled the actual fuse box itself and gave it a good look and i didn't see any damage on the back side of it. My eye isnt' trained to see these sorts of things, but there was nothing obvious like burned plastic.
    Any other ideas on why teh RH fan won't work?
    Thanks.
    Bobby
  10. 335s
    335s Formula Junior
    Jan 17, 2007
    870
    SF Bay Area
    T. Monma
    Jeez...I've been watchiung this one from afar...
    I would concur with all that RifleDdriver , etc has offered you...but the last quip as to grasping for straws seems to indicate your own acknowledgement that oit is now time fro some real grunt work....
    In 129 cars, theere is the real and truly the case issue of amp pin connector failures within the harnesses and boot heads....
    Rifledriver has an SD-1-I do believe- so proximity to him and a time and materials bill is the likely resolution to, ultimately, performing a wire by wire, and pin to pin proofing of the harness, sensors, ECUs, etc to the channel affected.
    A shop with the pin boxes, and the layovers, is also a very useful shop for this...but it is TIME consuming..which means costly....I once spent 3 weeks chasing down 1 AMP pin for the suspension in a harness/boot head which was the culprit, only to find that the harnesses were NLA, and , you'll really die hearing this-AMP had not made those pins in years, and we needed to chase down last known buyer in Belgium(he offered to give me several hundred as a sample, as his minimum order had been 17, 000 pins!...True story....
    The moral of the story is that this is emminently fixable, just not likely easily, nor likely quickly.
    The key is competence in either your own diagnostics skill sets, or those of your sevice facility's.
    good luck, plese let us know what is the final solution...
  11. bobby355
    bobby355 Karting
    May 21, 2009
    244
    I'm going to give this one last college try and change the water temp sensor since i already ordered it. If no luck with that its off to the shop.
    Thanks for all the guidance everyone. Will let you know if i get it fixed or drive the car off a bridge.
    Bobby
  12. eric355
    eric355 Formula 3
    1,235
    Toulouse (France)
    Eric DECOUX
    Before changing the sensor, have the car plugged to a SDx, or a cheap OBD2 reader. It will show you what the Motronic is considering for the coolant tempearture, in real time, even during driving. It will then be easy to check if the temperature is consistent with the coolant temp gauge.
    If yes, no need to change the sensor, your problem is between the motronic output (including the Motronic itself) and the fan i.e. wire between motronic and relay including the intermediate 14 pins connector, relay, fuse, wires between relay and fan. Is the relay commanded by the Motronic when the temp is high (can you ear a "click" if you remove and re-install the relay)? Does the fan blow air when you by-pass the relay with a short piece of wire? You can quite easily isolate the arear of concern.
    If no, changing the sensor wont ensure you are OK after that. You have first to check that the wires between the Motronic and the sensor are OK. With key in position II, unplug the sensor and check that you have some voltage between pins and ground (# +5V).
  13. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    Was the car fixed? If so what turned out to be the problem?
