1st Engine Start After Winter Help | FerrariChat
Discussion in '360/430' started by fezza, Jun 6, 2019.
  1. fezza
    fezza Rookie
    Nov 23, 2004
    46
    North East - UK
    Andy
    Hi,
    Going to start the F430 after 6 months of storage over winter. Is there away of removing the fuel pump fuse so that I can build up oil pressure by cranking the engine with out starting? If so where will I find the fuse. On my Porsche 993 I just used to disconnect the coils.
  2. cpep
    cpep Formula Junior
    438
    new york
    CHARLIE
    Right-hand side passenger compartment fuses and relays
    To access them, remove the protection panel and box covers 1.
    No. A Description
    PDF1 10 +15 RH Motronic, Pin 86 on PDR8 and PDR9 relays
    PDF2 7,5 Rear fog lights
    PDF3 7,5 External rear view mirror defroster
    PDF4 I5 RH Lambda sensors
    PDF5 15 Stop lights
    PDF6 25 +30 Windscreen wiper
    PDF7 30 Heated rear window
    PDF8 10 Positive from main RH relay. (PDR10)
    PDF9 20 +15 Radio, rear view mirror switch, fuel tank flap, direction indicators switch, cigarette lighter, parking sensors
    PDF10 30 +30 Radio, radio amplifier, parking sensors
    PDF11 - Position available
    PDF12 15 Air fl ow meter, exhaust bypass valve, antievaporation diagnostic pump, anti-evaporation valve, immobilizer relay, intake manifold valve, A.C. relay
    PDF13 5 +15 Alarm system, immobilizer
    PDF14 5 +30 Alarm system, immobilizer
    PDF15 — Position available
    PDF16 15 RH ignition coils, RH injectors
    PDF17 15 Windscreen washer/ wiper
    PDF18 15 +30 key
    PDF19 — Position available
    PDF20 10 RH Timing variators
    PDF21 7.5 +30 RH Motronic
    PDF22 - Position available
    PDF23 30 RH Motronic (main)
    PDF24 10 +15 ABS - ASR - ESP
    PDF25 15 +30 Fuel pump relay 1 (PDR8) and fuel pump relay 2 (PDR9)
    PDF26 10 +87 Tyre pressure monitoring system (TPMS)
    Relay
    PDR1 - Immobilizer (spec. BOSCH switch)
    PDR2 30 Key-operated devices
    PDR3 30 Heated rear window/ rear view mirror defroster
    PDR4 20 Rear fop lights
    PDR5 30 +30 Windscreen wiper
    PDR6 20 +15 Windscreen wiper
    PDR7 20 +Heated seats
    PDR8 20 RH fuel pump - Speed 1 (BOSCH)
    PDR9 20 RH fuel pump. - Speed 2 (BOSCH)
    PDR10 20 Main for RH Motronic CBOSCH)
  3. frafoss
    frafoss Rookie
    Jun 8, 2015
    19
    Norway
    Frank Foss
    Why?
    Why?
  4. mello
    mello F1 Veteran
    5,489
    CA Bay Area
    Steve
    Unless you have a pre-lube system installed, the cranking in itself will put some wear on the engine. With or without fuel. Why bother? It's just the nature of the ICE.
  5. dreichman
    dreichman Formula Junior
    Sep 9, 2011
    425
    Denver, CO
    [emoji2361] really?
