348 - 2.5 ECU .... oxygen sensor | FerrariChat
348 2.5 ECU .... oxygen sensor
Discussion in '348/355' started by marc556, Jul 25, 2020.
  1. marc556
    marc556 Formula Junior
    590
    Wiltz (Lux)
    Marc Foyen
    Dear all,
    When I went in my garage this morning, my goal was to replace the FPRs.... but I saw that on the left side, the oxygen sensor wires are destroyed by the boot clamp of the wheel shaft.....
    So I have to replace it (348 with 2.5 ECU).
    when I check the cross reference guide, it seems that the mentioned original Bosch sensor (13120) has 4 wires...
    Do you have the right ref nb? May i use a standard bosch sensor and weld the old connectors?
    If yes, what is the ref ?
    but I need the followed connexions.
  2. m.stojanovic
    m.stojanovic F1 Rookie
    3,287
    Serbia - Niš
    Miroljub Stojanovic
  3. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    3 wire sensor..... one plug with two and one alone
  4. m.stojanovic
    3,287
    Serbia - Niš
    Miroljub Stojanovic
  5. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    #5 marc556, Jul 25, 2020
    is it the same thread ?
    the plugs are the same, but sensors are identical?
  6. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Probably the wiring is too short....100 mm shorter than original
  7. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Does someone know the Bosch ref. For the 348 original 3 wires oxygen sensor?
  8. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    It is stamped on your existing sensor for reference.
  9. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Yes I know, but the car is not at home ... so I'll check next weekend.
  10. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Here is the original BOSCH REF. 0 258 003 009
  11. m.stojanovic
    3,287
    Serbia - Niš
    Miroljub Stojanovic
  12. m.stojanovic
    3,287
    Serbia - Niš
    Miroljub Stojanovic
    It is quite possible that your engine (one bank, I believe) running rich was caused by the faulty O2 sensor. When an O2 sensor goes bad or is disconnected, the ECU will go into the "open loop" mode on that bank. In such a case, the position of the adjuster screw on the MAF comes into play. The adjuster screw is a potentiometer actually connected to the ECU only, not to any part of the MAF circuitry. If your adjuster screw is positioned at "rich" you would then have the symptoms you earlier described - hard to start when hot, petrol smell, rich running.
    So, before you install a new O2 sensor, check the position of the adjuster screw on both MAFs - unplug the connector and connect an ohmmeter to the pins 1 & 6 (the two outer pins) of the MAF. The reading should be ~ 383 Ohm. If not, turn the adjuster screw until you get this value.
    Qavion likes this.
  13. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    I shall check and keep you informed...
