2 post lift recommendations | FerrariChat
Discussion in 'Technical Q&A' started by MDshore348, Dec 11, 2005.
  1. MDshore348
    MDshore348 Formula 3
    Dec 24, 2004
    2,460
    Maryland
    Darron
    about to purchase a 2 post lift , was wondering if anyone has some positive experience with any models they could recommend. not looking for top of the line, just reliable mid level. i would however like a 10k capacity for occasional larger vehicles...
  2. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    I got an eagle lift.... depends on what you want to do. FOW uses Rotary lifts. What ever you get make sure its asymetrical so you can open doors easily. It's widely accepted that Mohawk makes the best lifts but your gonna pay for it.
  3. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    You think Mohawk is better then Rotary?
    We have a 4 post Rotary at the office.........
  4. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    I didn't say Mohawk was better than Rotary. I said it's widely accepted. I researched buying a lift for a year before I took the plunge. In my opinion for what I spent what I got is the best lift for me. I'm not running a business with it.
  5. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    I wasn't arguing the point.......... Just the opposite
    You said " It's widely accepted that Mohawk makes the best lifts but your gonna pay for it."
    So if they make the best, I was just asking why you felt that way. I haven't done much research at all.
    I know there are a few lift companies that make residential lifts that are not comparable to the Rotary. I've just never had any experience with Mohawk, that's why I asked.
  6. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    No problem. when I was researching buying a lift I spoke with several manufacturers including Mohawk. All the other guys all but conceded that mohawk was better in almost every way. But, at double, triple and quadruple the price most played up the value factor over Mohawk. I look at Mohawk seriously, but I could wrap my mind around 7-12K for something I could get for 3K. I know a few folks who have them and swear by them. Same with Rotary. It was simply more lift than I really needed.
  7. MDshore348
    Dec 24, 2004
    2,460
    Maryland
    Darron
    I didnt know you had a lift Barcheta ...
    i was wondering , if those chinese models were all that bad ? you can get a 10k lift for 1650.00 plus delivery .
  8. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,950
    MD and NE
    Robbie
    I have a really nice one post lift. Totally transportable, you can move it around to any part of the car w/o moving the car. Really nice one - think it is made by Craftsman. Darron two of these welded together would make a nice 2 post lift.....
  9. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    I just bought a two post lift that is also an alignment lift with runways.......
    I'm not sure if I'm going to keep it.
    I bought it because:
    1. It was a Rotary and I know how solid they are
    2. I wanted the 2 rolling jacks
  10. fmaderi
    fmaderi Formula Junior
    May 8, 2005
    258
    clearwater Fla/NY
    frank maderi
    i use a foward[texas co.] 10,ooo A .with 10 k being wider and lower it works for me.this is a proff lift that is made to go up n down for many years.[$3400].you are able to switch arms from side to side so you can enter lift foward or backwards.ive used mohawk rotary they are all good machines.the best thing i ever did was get a portable 4 post drive on.makes work on newer cars a blessing.ever work on a car door without having to bendover. good luck forza
  11. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    I'm sure some people buy them.... I was talked out of it by Eagle and they sell the same thing. It's called a Mechanix. Cheaply made overseas with the gears and hydraulics coming from here. The basic difference was the quality of constuction with the lift itself. Thinner steel, not reinforced, not as good a warranty... for a few hundred more I'd rather have the confort of knowing the lift's not going to bend in half if i put too much stress on it. :) YMMV...
    ................or you could go Aeriola's redneck rigged solution.... :)
  12. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Start asking around for lift suppliers in your area.
    I've got a ~10 years old assymetric clear floor lift made by Nussbaum. Typical German engineering. While rated for 7K, I'm pretty sure they used the same mechanicals for their 10K & 15K lifts & just went with higher hp pumps.
    Birdman has a quite a bit newer Rotary lift, again, assymetric clear-floor. Nicely made.
    We both bought our lifts used from garage supply wholesalers who had taken them in trade on newer lifts. We negotiated installation as part of the purchase. Were hard to beat for ~$2200 delivered & installed.
    BTW, since the SUVs have gotton so big, & there are a lot of small trucks out there, 10K now seems to be the std lift for new installations.
  13. MDshore348
    Dec 24, 2004
    2,460
    Maryland
    Darron
    actually now im getting cold feet, may end up getting a 4 post lift , i may need to move it around to get a large boat in the shop ...
  14. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    I bought a Rotary because a car dealer I talked to claimed they tried others and the rotary was their favorite, but I don't think they tried a Mowhawk. I saw several Mowhawks at another dealership and boy are they built.
  15. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    I agree. if you are going to get a 2 post it's best to go assymetric and with a clear floor configuration. Mohawk does have a neat twist on the two post. They have this option you can get called the speed lane that is basically two ramp fittings that let you drive onto the lift just like a 4 post.... I haven't seen that anywhere else... I was going to go the same way Verell :) but those kinda deals go quick around here.
  16. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    That's just like what I purchased on a used Rotary w/ alignment.
  17. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    Are all four wheels off the ground (pretty cool if they are)? The Mowhawk one is is similar to the low profile lifts that FOW uses. All four wheels still hang. Only the body is lifted.
  18. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    No, it's like driving on a four post......... but it has 2 rolling jacks to lift the wheels off.
  19. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    That's even better..... do they detach? Will they fit anything other than a rotary lift? That's the perfect solution to storing your car with another below if you need to. hmmm. you got me thinking now about getting some.
  20. MDshore348
    Dec 24, 2004
    2,460
    Maryland
    Darron
    what, getting another fcar or a place to store one? :)
  21. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    S class
    Hopefully
    Can't build a larger garage like some people!!! :)
  22. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    A 550 eventually. But If I can raise the whole car without having to "engineer" some wooden boards that would be sweet. Right now i'd have to remove the wheels and let the suspension hang... not good.
  23. Mike Florio
    Mike Florio Formula Junior
    Jun 19, 2003
    599
    NW Rural Nevada
    Mike Florio
    I installed a Bend-Pak about 4 years ago - asymmetrical, clear floor, 10K capacity. Cost about $2200 delivered. Most of the dealers in Reno have Bend-Paks, they are made in California and have US hydraulics. I'm no expert, but the engineering looks pretty good to me.
    Two boxes of Krispy Kreme doughnuts and about a gallon of coffee got a 6-man working party over here to install it. These farm boys know about heavy equipment! They did such a good job I even bought pizza afterward.
    One regret - it would have been nice to have the wide floor model. even with the asymmetrical posts things get kinda tight - remember you place the car center of gravity between the posts. On Fcars that may block the door from opening. My full size truck just about fit between the posts.
  24. spang308
    spang308 Formula Junior
    Jul 17, 2004
    893
    York, PA
    Darron,
    For what it's worth I have a shop full of rotary lifts (9000#) and they work great and are built very well. There is also local support to repair them in the area. We also have two 4 post Rotary lifts, and I usually use them when I work on my car. If you get 4 posts with the rolling jacks underneath, they work very nicely. As a bonus, the ramps double as a work bench which is handy when doing suspension and brake work. If I were buying just one, it would be a 4 post. That way you can use it for everything including alignments if needed.
  25. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    I like the Mohawk SpeedLane idea. Have been thinking about making something like it out of loading ramps.
    Does it lift by the wheels, or just fit flat under the body pan? Ahh, this explains it:
    http://www.atlanticautosuppliers.com/pdf_files/mohawk_lifts/brochures/speedlane.pdf
    (edit) This explains it even better, it's the Mohawk Speedlane Manual:
    http://mohawklifts.com/library/manuals/speedlane.pdf
    You slide rubber pads in place to pick up the correct spots on the frame. Hmm, looks like it adds about an inch to the lift arms. That'll most likely be a problem for Ferraris. I suspect you'll need to support & extend the rear ramps & put something under the front to keep it from droping down so far. Still a good idea.
    BTW, if you're designing a garage for a lift, have 1" or 1.5" deep recesses poured into the floor for the posts. That way the lift arms can come all the wsy down to the ground. My lift posts have ~10mm thick steel mounting plates that sit on top of the garage floor. The arms come down until the bottom of the arm touches the plate. If I could have mounted the posts in recesses, the arms would fit under the car w/o me having to drive it up onto boards.
