2000 360 Spider Gauges stopped working | FerrariChat
Discussion in 'Technical Q&A' started by freddi67, Mar 26, 2020.
Tags:
  1. freddi67
    freddi67 Rookie
    Apr 7, 2012
    3
    i have a 2000 360 Spider that was put onto a battery tender and left for a week. ( a ctek 3300smart charger ) Car runs and drives great but now I have no gauges. No tach speedo fuel temp anything. No dash lights. They all worked fine before being parked. I’ve checked all the fuses behind the drivers seat all are ok. Is there another a fuse somewhere else? Could the tender have fried something? Thanks in advance!
  2. Qavion
    Qavion F1 World Champ
    11,555
    Ian Riddell
    There are some instrument fuses in the forward luggage compartment (LHS). You have to remove a carpet panel to access them.
    Caution: Fuse 14 gets power directly from the battery.
  3. andy308
    andy308 Formula 3
    Jan 16, 2005
    2,020
    Sarasota, FL
    Andy
    If you find you actually have a problem with the cluster, remove it and these guys can fix it for you:
    http://ferrarioc.com/
    Rojo and Qavion like this.
  4. freddi67
    freddi67 Rookie
    Apr 7, 2012
    3
    Thanks so much for the info guys! Sorry it took a bit to get back but was sent outta the country for a bit. I think she’s got a ghost in her somewhere. All I did was flip the battery disconnect in the luggage let it sit for a few and turned it back on. Presto everything works. Can’t explain it. I guess like restarting your cell phone. Thanks again you guys are awesome!
    Qavion likes this.
