2001 360 Blower Motor Issue | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by mxbennett, May 30, 2021.
  1. Qavion
    Qavion F1 World Champ
    14,601
    Ian Riddell
    Unfortunately, that voltage/amp table only goes up to 2.9 amps...
    Here's one that goes up to 10 amps, but it may still be a little low.
  2. hessank
    hessank Formula 3
    1,967
    Canada, Florida
    Fred
    " ..... With the jumper fitted...
    If your fan doesn't turn at all, then it's a power issue or fan issue.
    If your fan runs at MAX speed, then the fan is ok.... unless it stops some time afterwards, then it's also a fan issue (overheating, etc).
    If the fan runs indefinitely, then it's a fan speed controller or HVAC ECU issue (or in rare cases, the fan speed knob on the A/C control control panel)... or wiring....... "
    Great. Thanks for taking the time Ian
    Qavion likes this.
  3. Qavion
    14,601
    Ian Riddell
    Just to clarify. If the fan is ok with the jumper and it runs indefinitely... but you were having issues with the fan previously.... then it's a fan speed controller or HVAC ECU issue (or in rare cases, the fan speed knob on the A/C control control panel)... or wiring....... that is causing that previous issue.
    hessank likes this.
  4. hessank
    hessank Formula 3
    1,967
    Canada, Florida
    Fred
  5. thefredo
    thefredo Rookie
    Feb 8, 2025
    10
    WA
    Geoffrey Arone
    FOLLOW UP: I bought the £10 part from MG Rover Spares: https://www.dmgrs.co.uk/products/mk2-45-zs-atc-transistor-pack-repair-kit-jgn000010-diavia-133000-3-and-133000-2?_pos=1&_sid=a2a2ebbbe&_ss=r and completed the work this weekend and it worked! Pulling out the original was by far the worst part. If you have any experience with soldering, it's straightforward. You basically clip out the existing transistors, melt out the existing solder, and fit the new ones. Here are a couple of pics:
    hessank and Qavion like this.
  6. NimrodStorm
    NimrodStorm Rookie
    Sep 8, 2025
    1
    Sam Storm
    Thanks for all the great info here.
    I had the transistors replaced recently in the fan speed controller (hedgehog (part 64280200)) as the fan would work intermittently / whenever it felt like it. Now the fan runs at full speed the whole time whether the car is running or not. With a jumper fitted the fan also runs at full speed. I've been told it is likely the motor pushing too much electricity through the fan speed controller causing the transistors to fail instantly. Could anyone let me know which motor could be the culprit please? According to the workshop manual there are a number of motors directing airflow. I'm guessing it could be either of them but if anyone had any experience of this it would be greatly appreciated.
