2004 Tahoe | FerrariChat
2004 Tahoe
Discussion in 'General Automotive Discussion' started by classic308, Feb 20, 2005.
  1. classic308
    classic308 F1 Veteran
    Jan 9, 2004
    6,820
    Westchester, NY
    Paul
    I have a new (less than 2K miles) Tahoe that is starting to give me concern. Since new, a substantial amount of water vapor has been coming out of the tailpipe and it continues long after the car has warmed up;this morning, the water started dripping out of the back of the muffler also.
    Is it me or should I be concerned?
  2. Dino Martini
    Dino Martini F1 Rookie
    Dec 21, 2004
    4,619
    Calgary Alberta
    Martin
    cataltyic converter - It converts motor exhaust into carbon dioxide, and water.
    Nothing to be worried about
  3. classic308
    Jan 9, 2004
    6,820
    Westchester, NY
    Paul
    Want to paint the garage floor in the spring and was concerned about the amount of water; have an Isuzu Trooper, does it for 10 minutes at most then stops;Chevy keeps doing it.....
  4. UroTrash
    Jan 20, 2004
    40,744
    Purgatory
    Clifford Gunboat
    I read between the lines you worry for a warped head or some other reason for coolant to be getting into the combustion chamber?
    For 20 bucks you can answer that and many other questions.
    This place seems straight up, I have used them:
    http://www.blackstone-labs.com/
  5. kaamacat
    kaamacat Formula 3
    Jun 13, 2004
    1,623
    Cumming GA
    BobR
    classic308. If you have a blown head gasket, you should A) be able to almost have a "sweet" smell near the tail of the vehicle............ and B) no doubt, if that car is warmed up, and your outside temp is above 40-50, there should be ZERO white smoke from that exhaust.
    Again. The only time your'e gonna see vapor (as-it-were) is if its a super cold day out. (just like breathing into the air).
    If you are in doubt, get it checked out and DOCUMENTED by the dealer.
    Bob
  6. 348 Turbo
    348 Turbo Formula 3
    Jul 17, 2002
    1,837
    Forget it. The thing is about to blow up. I'll take it off your hands for $3,500. ;)
  7. damcgee
    damcgee Formula 3
    Feb 23, 2003
    1,864
    Mobile, AL
    This guy is scam artist. Don't listen to him.
    I'm confident I'll be able to correct your problem for slightly less than $10,000. Just deposit the check into my Nigerian bank account.
  8. classic308
    Jan 9, 2004
    6,820
    Westchester, NY
    Paul
    My Tahoe redeemed itself tonight in this snowstorm here in the Tri-state area; ran like a champ on the Hutch and 684;many accidents and lots of BMWs and MBs stranded on the side of the road including an X5 whose owner apparently thought the the laws of physics didn't apply to him-he ended up stuck in the center median after passing me less than 5 minutes before. This x5 and and one other car were the only ones that passed me on 684. I must tell you that there were quite a few Saabs holding their own in this weather. Very impressive....
  9. FarmerDave
    FarmerDave F1 World Champ
    Jul 26, 2004
    15,782
    IgnoranteWest
    It's aaaalways another expensive lab test with you doctors isn't it.
  10. UroTrash
    Jan 20, 2004
    40,744
    Purgatory
    Clifford Gunboat
