2005 360 Value cover and cam seal leak | FerrariChat
Discussion in '360/430' started by enzoformenh, May 29, 2020.
  1. enzoformenh
    enzoformenh Formula Junior
    638
    NH
    Mike F
    Took my 05 360 spider in for the annual oil change and the tech discovered that the value cover was leaking. Car has 11,000 miles. Not too surprised because it is 15 years old. I was surprised when they found the cam seals leaking oil onto the timing belt gear. I did a search and I saw a lot of talk about the Cam covers leaking but not much about the cam seals. Glad they caught it before it caused the belt to fail. I guess that is another argument for making sure you have the timing belts done every 3 years on the 360s. Anyone else have this problem?
  2. 02360spider
    02360spider Formula 3
    1,730
    Dartmouth
    Richard oliveira
    Mine cam and valve cover are both leaking also I'm going to do it my next belt service.
    Sent from my SM-N975U using Tapatalk
