News
2008 430 default F1 auto/manual
Discussion in '360/430' started by AndrewCrane, Feb 1, 2008.
  1. AndrewCrane
    AndrewCrane Karting
    Sep 25, 2007
    76
    Chobham, Surrey, UK
    Andrew Crane
    Hi - is there a trick to change the default configuration of my gearbox to manual instead of auto when it is first started up please?
    Andrew
  3. RSM
    RSM Karting
    Feb 12, 2007
    155
    Yes... I would like to know as well?..... :)
  4. 05F430F1
    05F430F1 Formula Junior
    Oct 22, 2005
    945
    Todd
    HUH? The only way it should be in auto when you start it is if you have the manetino set to snow/ice or norm driving. Otherwise, it is always Manual..... confused at question. the car is a MANUAL car if it is F1, 'auto' is a fake auto and a 'choice you need to choose by pushing auto button or setting manetino switch to '*****' driving. So it always starts in 'manual mode'
  5. AndrewCrane
    AndrewCrane Karting
    Sep 25, 2007
    76
    Chobham, Surrey, UK
    Andrew Crane
    They changed the default setting on startup back in 2006 and it now starts up in auto mode.
    It did occur to me that by pulling the left paddle for three seconds sets the box in some undocumented mode. This might well provide a method of changing the setting -- I'll play with it later. My other thought is that there might be an adaptation setting for the transmission ECU available via the CAN-BUS/OBD2. I don't have any compatible software at the moment -- does anyone have the SD3 who can have a poke around?
    Regards
    Andrew
  6. 05F430F1
    Oct 22, 2005
    945
    Todd
    ok, sry to hear of your troubles but my 05 wasnt like this and my 07 isnt either. Mine is an F1 Manual car and starts in manual and ends in manual, well because it IS a manual.
  8. Nielsq
    Nielsq Karting
    Dec 23, 2006
    245
    NY Metro Area
    Nielsq
    My '07 F1 always starts in manual. Never used auto. Maybe if car is turned off in auto, it starts in auto, like my '05 Maserati Spyder.
  9. BritBlaster
    BritBlaster F1 Rookie
    2,856
    Bellevue, WA
    Paul
    My 2007 F430 always starts in manual, and has to be forced into 'auto' (which I tried for about 10 seconds *once*).
    My suspicion is that this is a Euro (or just UK) spec requirement. (I know that 'auto' is required for certain sound-level regulations.) Maybe the default can be overridden by a setting changed with the SD3 -- your dealer should be able to help.
  10. fc2
    fc2 F1 Veteran
    Nov 2, 2006
    5,136
    Silicon Valley Ca.
    Frank C.
    My US '07 430 F1 always starts in manual mode as well.
    Frank
  11. ttforcefed
    ttforcefed F1 World Champ
    15,741
    ditto
  13. RBK
    RBK F1 Rookie
    Jul 27, 2006
    3,052
    Calif and Nev
    Bob
    My 06 is an F-1, when started, I must shift unless I want to go all the way to (near) rev limiter then it shifts. What am I missing here? How can it start in automatic if yoiu do not push button or change setting? Best
  14. Bandorka
    Bandorka Karting
    Oct 9, 2007
    189
    Budapest
    András
    My beauty is 2007 dec production and always starts in auto mode. No matter in which setting I turn off ignition. What is that mysterious left paddle setting???
  15. AndrewCrane
    AndrewCrane Karting
    Sep 25, 2007
    76
    Chobham, Surrey, UK
    Andrew Crane
    Well I just want mine to be like yours. Perhaps I'll send it back to Ferrari as a fault.
    Regards
    Andrew
  16. cpiguy
    cpiguy Formula 3
    2,097
    Westlake Village, CA
    Arnie Friedman
    Mine behaves exactly the same.
  17. azew
    azew Formula Junior
    Jul 4, 2006
    463
    New York
    My 599 is having this issue as well -- though my F430 Coupe does not - time to call the dealer, I suppose
  18. rscholl
    rscholl Formula Junior
    Dec 4, 2003
    296
    Houston,TX
    My 07 430 always starts in manual mode. I've never even driven it in auto. What's that? ;-)
  19. Steve711
    Steve711 Karting
    Oct 9, 2007
    105
    Maybe the "auto" button is stuck so that each time you start the car it engagues the auto mode. The parking light is the same kind of button and it gets stuck pushed in on my 430
  20. AndrewCrane
    AndrewCrane Karting
    Sep 25, 2007
    76
    Chobham, Surrey, UK
    Andrew Crane
    No unfortunately. It switches to auto mode as soon as the engine is turned off.
    Regards
    Andrew
  21. F430Rod
    F430Rod Formula Junior
    Feb 17, 2007
    476
    Orange County
    Rod
    Buy a 2005 or 2007 then. :D Get an odd year to get rid of your odd problem. :D
  22. RSM
    RSM Karting
    Feb 12, 2007
    155
    My car starts in Auto mode every time??... 2007 Aug production. Guess this is a requirement in certain markets.
  23. AndrewCrane
    AndrewCrane Karting
    Sep 25, 2007
    76
    Chobham, Surrey, UK
    Andrew Crane
    My dealer said it was done for the American market. Well having read the responses to my initial post, this is clearly BS. I think on the balance of probabilities, the best explanation in this thread is noise regulations. If it changes early, it will be quieter. So RSM -- are you from Europe?
    My dealer also said there was no way to change the default. Again, I say BS. It's clearly an ECU parameter and so can be changed. The question is, how? There's no way it will be a ROM-out job or a different part number for the ECU -- that's just too complicated. The only three other options are DIP switches or jumpers on the ECU (unlikely), a secret button pushing combination (most likely as this way it can be changed trivially by the dealer) or an ECU coding change (again very likely).
    Regards
    Andrew
  24. RSM
    RSM Karting
    Feb 12, 2007
    155
    I live in India....Bangalore - My car was bought from the Singapore/ K.L. market allocation.
  25. windsock
    windsock Formula Junior
    557
    Arlington, Washington
    All the cars have this function. To dissable the auto startup. Start vehicle it should be in Nuetral and by your description the auto lamp should also be illuminated. Push the Auto button in the console the auto lamp should now be out. Turn the vehicle off and wait until the gear indication turns off. Restart the vehicle it should now be in manual mode. I verified this with a 2007 and 2008 model. If it does not there is a malfuntion. This same procedure works for the 599 and the 2008 612 with the exception that the 599 and 612 enter what is called easy auto which has a down arrow next to it indicating that any input from a up or down paddle will result in manual operation. If the car is then put into automatic mode via the center console button and then turned off when you next time you start the vehicle it will display an automatic without the down arrow indicating full auto. PM me if you still have questions.
  26. AndrewCrane
    AndrewCrane Karting
    Sep 25, 2007
    76
    Chobham, Surrey, UK
    Andrew Crane
    This is what my 430 does. I have had it in this mode without realising the significance of the down arrow. Following your instructions, this is how it now starts and I have to say I think I prefer this to straight manual. It gives you the choice of pulling off in town in auto and then as soon as you feel the thing isn't responding how you want it to, you're back in the familar territory of manual.
    Thanks Windsock, you have made me smile and ended my obsessional google searching. Now why did my dealer not know this (or choose to tell me) and why isn't it documented in the manual? Any more tricks up your sleeve?
    Regards
    Andrew
  27. luicci
    luicci Rookie
    Jul 12, 2008
    33
    Every time I start my f430 the f1 transmission will be in AUTO mode, is this normal?
    BTW I'm starting it the right way, wait when the key is in the ignition before starting it and waiting for it to idle.
  28. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    6,779
    Wash DC area
    Robert
    See post #22 in this thread. Welcome to Fchat! You will find many of the topics have been discussed and a quick answer is usually just a "search" button away. Hope this helps.
    Robert
